05-27-2016, 07:09 PM | #1 |
S13 ka24det w/ cd009
what's up everyone!
Alright so I'm having a small problem and cannot find much info on this. As above I've got a s13 ka-t w/ cd009 maverick swap kit. It runs drives and blah etc. But the slave cylinder piston popped out the bore on the slave and pissed All the fluid out. So now my problem is the fork/ slave cylinder set up. My cd009 already had the cast fork with short pivot ball. Theres too much play in the fork/slave set up. I don't start engaging the clutch until like 3" or so above the floor. and that's with the clutch pedal rod maxed out for adjustment. I need help from ppl who've accomplish or know about this problem. Please help! |
05-27-2016, 07:16 PM | #3 |
Have you contacted Maverick ?
MRP Manufacturing |
05-27-2016, 07:43 PM | #4 |
Yes I'm currently waiting on a reply but I thought posting here might save me from waiting until monday for his reply. Import face off is in a week so I'm trying to make there.
05-28-2016, 04:20 AM | #5 | |
Simplier said you need something thicker between the clutch and the fork so it contacts it before your at end of travel and buildup hydraulic pressure on the slave Now another option would be you make a slip on extension for the slaves piston to end up about 5/16 to 3/8 longer than you are now. I took a 3/8 bolt drilled it center the size of the piston,cut it the right length, popped that in the drill press and filled the end bullet shape with a round nose. This will solve the over extension problem you encountered. Hope this helps you out |
05-28-2016, 04:38 AM | #6 |
Also important is if you have a single or dual clutch; I needed a shorter carrier since I got a dual clutch but singles should require a tad longer. Initially I overextended the slave must of been really close but never got to the point where I popped the piston out the slave meaning in your case maybe add 1/8 lenght to that piston extender. Shaving of the bellhousing also helps but you guys using an adapter plate cancels out the material removal gain you obtain by machining
05-28-2016, 06:47 AM | #8 | |
Also thanks for the help because this is the best I've received so far! |
05-28-2016, 09:23 AM | #9 |
Trader Rating: (130)
Feedback Score: 130 reviews
juan (bardabe) already went through and listed all the different carrier bearing sizes. lemme see if i can find the link
http://zilvia.net/f/showthread.php?t=622595 tons of useful info in here. |
05-28-2016, 06:19 PM | #10 | |
