Motorsports and Skilled Driving Discussion for Organized Racing and motorsports and tips and techniques at becoming a better driver. |
01-11-2011, 12:12 PM | #1 |
Take a hole saw, and go to town on a new sheet of plywood. Fill the holes with foam cutouts glued in with gorilla glue. At least try to cut that weight in half, then glass over it. Will still be very stiff at half the weight
01-11-2011, 10:37 AM | #2 |
Damn bro 40lbs on the front end hanging forward is REALLY a lot of weight... but I totally understand its a budget thing.... But yeah I have wet lay fiberglass on it as well just 1 layer... Might do a 2nd layer this month to check rigidity.... I wish I had a picture of my car from the latest iteration of my splitter, but no one was taking pictures sucks....
Turn and Burn! |
01-11-2011, 11:15 AM | #3 |
Shit 40 lbs.!!!! I use 1/8" end grain balsa covered with 1 layer of 10oz matt,on both sides. Same basic shape as the one above with NACA ducts towards the outside for brake ducting. NACA ducts face down & inhale from the bottom.
Get that table of the front of your car. Im just joking ,but for reals.
MR JACKSON. |
01-11-2011, 12:55 PM | #5 | |
Or you can mold in a NACA duct just behind where the door opens and duct it similar to the above. This is what I wanted to do to my car. Kinda like the stock duct on a MK4 supra!
MR JACKSON. |
01-11-2011, 01:33 PM | #6 | |
Turn and Burn! |
01-11-2011, 11:34 AM | #7 |
yea its definitely too heavy... its a BIG splitter though, it goes back just past the steering rack to protect EVERYTHING in case a cone or something were to get stuck under there. i dont want something to hit my belts or oil pan or steering rack.
I also have aluminum plating running the leading edge about 4 inches to guard against scraping through the wood. (rubbed right through my last one till it was paper thin) i run my car really low and i'm drifting it anyway so unfortunately i cant talk like i'm a track racer. I do however feel that in a track situation my splitter would function very well save for the added weight.
01-11-2011, 03:12 PM | #8 |
Me personally I dont like stuff hanging under the car. The deflectors Im not so convinced, i get the concept buuuuut.
Another idea is . Where the rear seats bottom part use to be you can cut it and put a NACA duct ther faceing down then plumb as I said before. What is your current brake set up
MR JACKSON. |
01-11-2011, 04:08 PM | #9 | |
300zx all around with no ebrake. XP12 in the front and Hawk Blacks in the rear.....
Turn and Burn! |
02-14-2011, 01:51 AM | #12 |
Damn Casey, your car has come a long way since I met you at VIR. I knew when I saw your previous duct work the car was destined for greatness. Hopefully when I get back to the states I can take the Evo up to VIR for some HPDE lessons.
02-14-2011, 10:34 PM | #13 |
Nothing much except turbo is dead and I don't have the money to buy the CHRA.... Saving up for an engagement ring.... But I almost have the suspension dialed in and working on a 4.4 gear for the rear end....
Turn and Burn! |
02-15-2011, 12:39 PM | #14 |
^^^Nice,congrats. Im puting together a new motor for this year.SR, top mount T3-60-1/.68 hot side,HKS step 1 cams,knife edged crank,ceramic coated pistons,750 injectors,haltec platinum. Looking to put down 400ish lollol . Should be ready to rock in April.
MR JACKSON. |
02-15-2011, 05:05 PM | #15 |
You going 272 to get that power you think on a DynoDynamics?
Thanks! I feel she is the one... I mean the girlfriend, not the car hahaha..... But we all know what is up! hahahah
Turn and Burn! |
02-15-2011, 06:11 PM | #16 |
Trader Rating: (106)
Feedback Score: 106 reviews
I'm just working on my E30 since it's the more important of my two money pits. I drive the BMW every day, the 240 just keeps the floor from getting dirty underneath it...
:ghey: However, if things go right I will be working on a SR20VET setup that I will hopefully get to use at some point. Not to mention the entire rest of my car that I still have to finish... |
03-03-2011, 08:20 PM | #19 | |
Are those 17's or 18in wheels in this pic? How close are your FLCA's to the brake rotors?
04-15-2011, 09:46 AM | #20 |
Racerubber.com/Lapbattle.com 240 (a.k.a. Thunderdome)
Still needs a lot of work. The car has demonstrated great potential for a budget build. We have been slowly chipping away at it when time between our programs allows it. SR powered, fairly stock engine. Still approx. 2-3 seconds off the silver/gold GT-3 cup cars, we lose a lot of time to their better Aero, and higher HP numbers on the big straights. Yep tire is flat.
the clock IS ticking! |
04-15-2011, 02:00 PM | #28 |
lovin this thread and that splitter hahaha....
04-19-2011, 12:47 AM | #30 |
Ill have to dig around for more pics. Here is an early snapshot.
Tires 280/650 fr 280/680 r (maybe 305 this year...) Suspension JIC Brakes Stop Tech 355 fr Z32 r Tuning Jim Wolf Technology
