Old 08-01-2016, 06:18 PM   #121
TheRealSy90
TheRealSy90's Avatar
Seems like he revised the plate so that you wouldn't have to modify it. Isn't that a good thing?
Such a good signature.
Old 08-02-2016, 01:36 AM   #122
MattTenFour
MattTenFour is an unknown quantity at this point
Absolutely. I wanted to make sure I wasn't missing something. The instructions that he provided did not reflect any changes to the design and said you have to grind down a portion of the starter. Just trying to iron out the details while the engine and transmission are out of the car and everything is still easy to get to.
MattTenFour is offline   Reply With Quote
Old 08-02-2016, 09:08 AM   #123
Kylepaschke
Kylepaschke is an unknown quantity at this point
Originally Posted by RickS14 View Post
I would like the input on the cbf.wonder how the throws feel also from left to right. Seems like gktech took a while to release what they offer because they did a fair amount of real world use. Plus the unit looks pretty solid.cbf doesn't seem to have any lower support like serial nine and gktech shifters do. I'm a doing a 2j s14. I'm really thinking about keeping my gktech and just modify the shifter.
Its very tight left to right however I haven't driven my car yet
My friend Landon said his was very tight left to right too but once he started driving it really acts normal.
Ill report back once my car is running
Kylepaschke is offline   Reply With Quote
Old 08-02-2016, 09:29 AM   #124
RickS14
RickS14's Avatar
RickS14 is an unknown quantity at this point
Thanks.
RickS14 is offline   Reply With Quote
Old 08-02-2016, 01:26 PM   #125
Johannes
Johannes's Avatar
Johannes is an unknown quantity at this point
It's gonna be off. But I think it if you cut the shifter and bend it forward you could get it in stock location under the boot trim and centered. Check out the 2jz swap thread someone has posted pics already. As fas as the gktech one goes.
It seems like Nissansota is running thicker JZ-CD adapters than us though. Our Collins adapter is a bit thinner than that and would move the shifter forward. Might still be a tad bit long.
Johannes is offline   Reply With Quote
Old 08-02-2016, 02:36 PM   #126
TheRealSy90
The everything cd009 swap thread.
But his adapter also uses a different bellhousing than the Collins adapter so without a measurement of overall length to compare to its difficult.
Old 08-02-2016, 09:30 PM   #127
Nissansota240
Nissansota240's Avatar
Nissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really nice
Here's the measurements on my DL adapter I'm running
And the length from the face of the bell housing to the bolt holes for the shifter
Sent from my SCH-I545 using Tapatalk
DLG - DIRTYLOVE
Nissansota240 is offline   Reply With Quote
Old 08-02-2016, 09:47 PM   #128
RickS14
RickS14's Avatar
Thank you for that.
Old 08-17-2016, 07:07 PM   #129
Johannes
Johannes's Avatar
Just placed an order from a group buy going on @ cbf performance. This shifter is adjustable fore & aft as well as side to side so it fits many application. Orig price is $350. Group buy is $185.
My setup is a 2J ->CD009 with Collins adapter.
Here's the link to his ig page:
https://www.instagram.com/cbfperformance/
Link to group buy:
http://www.cbfperformance.net/store#...egory=19722030
Sent from my SAMSUNG-SM-G935A using Tapatalk
Old 08-17-2016, 11:19 PM   #130
2muchboost
Trader Rating: (33)
2muchboost is an unknown quantity at this point
Feedback Score: 33 reviews
Almost certain this will work for the LSX setup but can anyone confirm before I place an order?
2muchboost is offline   Reply With Quote
Old 08-18-2016, 05:51 AM   #131
rbs14kouki
rbs14kouki's Avatar
rbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to all
We just did a cd009 to rb25 in a r32 gts
Collins plate was ruff and no instruction at all . Machined down the bellhousing to accept the plate
Put every thing on the engin to figure out that the starter doesnt fit . Bellhousing need more grinding
With the rb25 kit . The transmission is clocked like 4 or 5 degre (dont know if its an accident by collins) so shifter is tilting toward the driver(rhd) abit
We installed 2 shifter . Firstly the serial nine
We liked it because we could fine tuned our shifter position with our tilted problem ... but shift throw is super short and super easy to miss 3rd or 4th for other gears ...
Second shifter and the one that is staying in GkTech
Shifts are precised and not to short ... realy what i was looking for . Reverse lock out that work 100%
Sit abit more back compare to serial 9 but were gona live with it since its a way better unit to our eyes
AV FABRICATION
Built thread sr20vet s14
http://zilvia.net/f/showthread.php?t=535574
rbs14kouki is offline   Reply With Quote
Old 08-18-2016, 11:43 AM   #132
NorcalAP2
NorcalAP2 is an unknown quantity at this point
Originally Posted by Nissansota240 View Post
Got a perfectly working speedo, will do a lil write up later this week .
would love to hear how this was done if you used an AEM infinity ECU
NorcalAP2 is offline   Reply With Quote
Old 08-18-2016, 01:08 PM   #133
RickS14
RickS14's Avatar
The gktech is a nice piece I sold mine already because I want to keep oem interior. So I'm going with serial nine. Any one have experience with the cbf?
Old 08-18-2016, 03:02 PM   #134
TheRealSy90
Same here as I just bought an infinity myself. However I've heard it might be possible that the infinity can convert any speed signal internally and would make the dakota converter no longer needed.
Old 08-18-2016, 09:27 PM   #135
roninwon
roninwon's Avatar
roninwon is an unknown quantity at this point
Send a message via MSN to roninwon Send a message via Yahoo to roninwon
I thought the gktech required no modifications to the interior. Is that wrong?
roninwon is offline   Reply With Quote
Old 08-18-2016, 09:27 PM   #136
TheRealSy90
It doesn't. I believe he is running the trans behind a Jz or Ls though. Gktech is designed for Sr.
Old 08-19-2016, 08:34 AM   #137
RickS14
RickS14's Avatar
Right a jz not sr with Collins plate on a s14. It could work but I want to keep it centered as possible and under oem shifter boot.
Old 08-19-2016, 09:20 AM   #138
Croustibat
Originally Posted by 2muchboost View Post
So I have searched high and low and have not come up with a clear answer. I know the CD009 can handle some good power but what is the "threshold" for it? I have seen them behind 1krwhp 350z in one video, behind an LSx in another, behind an 2J in another but again no clear indication to the sweet spot before it grenades.
Depends on what you do when you first hear wear signs.
I know of one, fitted to a 500+ Whp rb25 / ps13 . I think it started to whine a bit, after a couple of year of abuse as a pro drifting machine taking part in numerous european championships. It only needs new bearings.
If it can take that kind of abuse (it really IS abused), i cannot see a zilvian user destroy one. Unless it is not correctly installed.
Edit:
quick question here. I do not like plate adapters for various reasons, and am interested in the JWT kit. There is something i don't quite understand though. It requires an automatic bellhousing; but is it a Z33 auto bell housing, or a SR20 auto bellhousing ? Has anyone here installed one ?
Since i am using a CA18DET, i think i am getting in trouble here ...
Old 08-19-2016, 09:52 AM   #139
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
Originally Posted by Croustibat View Post
Edit:
Auto Bellhousing from the motor you are adapting to, IE SR- SR Auto Housing. Are the bolt patterns the same for SR/CA?
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 08-19-2016, 10:57 AM   #140
Nissansota240
I'll see what I can do, I'm super busy lately, might have some time next week.
DLG - DIRTYLOVE
Old 08-19-2016, 11:07 AM   #141
TheRealSy90
It uses the auto bellhousing of the engine you have. Idk if they make a kit for the ca18 though.
Old 08-19-2016, 08:52 PM   #142
undant
undant is an unknown quantity at this point
In to see if anyone can perfect the shifter setup when mated to a JZ motor.
undant is offline   Reply With Quote
Old 08-20-2016, 12:30 AM   #143
jackal264
jackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud of
the serial nine cd999 shifter is what you are looking for.
i just picked one up myself. i'll snap a few pictures for you when i get a chance. but my buddy has been running one in his 700hp 2jz s14 for a bit now and its definitely the way to go for 2jz+cd into an s chassis. no cutting of the trans tunnel needed.
retains reverse lockout also.
i know they made a lot on their first production run and they are down to the last hand full already.
https://serialnine.com/contact-info
https://scontent-sea1-1.xx.fbcdn.net...ae&oe=58493A7A
jackal264 is offline   Reply With Quote
Old 08-20-2016, 12:32 AM   #144
TheRealSy90
CBF has a shifter that sits on the inspection plate if you really need it far forward.
Old 08-20-2016, 11:09 AM   #145
Johannes
Johannes's Avatar
Everyone checkout my post a couple of posts earlier. Cbf is doing a group buy on any cd009 -> jz/ls/SR to an s-chassis. Pro series utilizes adjustable fore & aft as well as side to side.
Old 08-20-2016, 11:35 AM   #146
Johannes
Johannes's Avatar
Jason's pro series will be similar to the serialnine cd999 shifter setup, except it's a fraction of its cost. $185 group buy of 50 vs $450.
Old 08-20-2016, 12:54 PM   #147
RickS14
RickS14's Avatar
Waiting to see how the final product will work out.
Old 08-20-2016, 08:06 PM   #148
rbs14kouki
rbs14kouki's Avatar
for a jz to cdxxx i would do the speedtek cut and weld bellhousing with the gktech shifter .... with that bellhousing mod you dont need to cut the tunnel ... check them out on Facebook
AV FABRICATION
Old 08-20-2016, 08:43 PM   #149
lsineon
lsineon is an unknown quantity at this point
lsineon is offline   Reply With Quote
Old 08-21-2016, 03:22 AM   #150
jackal264
this looks super janky to me.
the collins kit (the cut + middle plate) looks way better to me then this option. now if collins would get off his ass and make a plate compatible with the j3 housing we would all be golden. seems like everyone has a j3 housing kicking around but the j1 is far more rare.
