08-31-2015, 08:38 PM | #6751 |
You don't "need" any adapters however the rear knuckle is optimised for the S14/S15 rear subframe however you can get around this by quite easily welding in new mounting points for the front of the rear LCA.
08-31-2015, 10:09 PM | #6752 |
ok this is suspension related, so i figured id ask the gurus in here
so my current coils dont really go low enough for me they are 9k rates in the front with a 7 inch spring if i wanted to change the springs out and get like 5 inch springs with the same rate or slightly higher rate would that affect the coilover?
@tannermwilson |
09-01-2015, 07:49 AM | #6753 | |
Low, handling, cheap. Pick only 2. Remember though, people here are about handling. Picking low and cheap means you are posting in the wrong thread. |
09-01-2015, 07:51 AM | #6754 | |
If you can still preload the spring with a 5in spring length, then no, there will be no effect on the coilover. I had to move to 6in in the front to get the ride height I wanted as well.
09-01-2015, 11:32 AM | #6755 | ||
what springs did you end up getting for your coils? swift, hyperco?
@tannermwilson |
09-01-2015, 11:36 AM | #6756 |
I bought Stance springs.
09-02-2015, 10:09 AM | #6758 | |
Some people just want to maximize the handling of their really low cars. I'm going to be tucking tire all around, but my roll centers will be fine after I get some rear knuckles.
09-02-2015, 10:42 AM | #6759 |
Some people do, but if you try a quick search on his posts, you will see that he is not exactly doing what you are doing. He just wants to go low enough to drive on the frame rails.
09-21-2015, 11:32 AM | #6762 |
Anybody else have reviews on the gktech roll center knuckles? The ones that bolt up under stock knuckles. Highly considering going this route, as most peoples cut and weld knuckles don't offer roll center correction for that price. Also they claim 60 degrees which should be more than enough for anybody.
09-21-2015, 02:20 PM | #6763 | |
09-21-2015, 05:06 PM | #6764 |
I've got the rack spacer on both ends already. With 1.5" extended s13 flca's, the steering rack would still bottom out in both directions before the tie rod got close to the control arm, using stock knuckles. Steering rack is relocated forward in the subframe as well. I figured with two rack spacers the rack should travel enough for the tie rods to touch the flca, so idk what's going on. Of course I can adjust the tie rod shorter to the point that it touches when the rack is fully in, but then I have almost no angle when turning the other direction.
Essentially, I could make the car have a ton of steering angle to either direction, not both. But with it centered, the rack bottoms out before I get close to the max angle at the knuckle/flca. |
09-22-2015, 08:49 AM | #6765 |
So who's making the best setup for grip right now? Driftworks? Wisefab? TDP? GKTech? I currently have Geomaster 2 knuckles but am considering making the switch to GKTech.
I'll likely be getting GKTech's front and rear LCAs too since those are the only arms left on my car still stock and un-adjustable. My 285 Hoosier A6s up front are ripping the ball joint out of my FLCAs anyway haha.
My S13 SR Street Mod Build |
09-22-2015, 09:54 AM | #6766 |
Trader Rating: (24)
Feedback Score: 24 reviews
Aren't you on fortunes still?
I'd start there. There are no spindles on the market that I've found fit the bill of stock-ish ackerman, quicker steering ratio, and have roll center correction. I had a set made to do just that. The best option was the billet GKTech setup with modular bits, but obv. they're not making them any more. |
09-22-2015, 10:27 AM | #6767 | |
My TDP setup will do that, and with more roll center correction than every other kit. Setup for maximum front grip, I don't think there's a better kit on the market.
09-22-2015, 11:20 AM | #6768 |
Does anyone know if shortening adjustable RLCA's would have and effect on blowing out boots? From my understanding, boots tear because they're being stretched. I'd almost think that shortening the RLCA would maybe help with this. (PBM RLCA).
I'm going to be building up a spare subframe as soon as I can find one locally that isn't bent. PBM front and rear knuckles, mix of PBM and SPL everything else. (after reading through this thread, I'm hoping the anti-camber gain won't screw me when tucking rim). The lip of my wheel is still poking about 8mm past the fender. I'm going to try and use the PBM RLCA to suck the wheel in a little. I am going to keep axle binding into consideration. Also, because I'm shortening the RLCA, I'm pretty sure I can't use axle spacers which I was planning on doing. |
09-22-2015, 11:33 AM | #6769 | |
I need FLCAs asap since mine are busted and the ball joints are pulling out. I figured if I was going to be ordering GKTech FLCAs, I may as well order the rest of it with them to save on shipping. Who made your custom spindle/knuckle? I'm not that low, primarily because I will bottom out 315/35/18 Hoosiers up front if I go too low. So I'm concerned that TDP having the most roll center correction would actually be too much for me.
09-22-2015, 07:09 PM | #6770 | |
although read the replies on this http://zilvia.net/f/showthread.php?t=612605 maybe useful as well http://zilvia.net/f/showthread.php?t=555322 |
09-22-2015, 07:31 PM | #6771 | |
Trader Rating: (24)
At $2200+ ship (what seems to be the price) that's about 4x what I spent for my setup. Didn't think of that one just because of price. Lucky: seems like you're trying to hang with PJ and Jason. I hope you're doing 20+ weekend of autox per year lol. And have a truck/trailer for all that. |
09-22-2015, 07:40 PM | #6772 | |
Lucky: The normal kit with 60mm of roll center correction doesn't seem excessive for even a moderately lowered S-chassis, but maybe your car is really that high, hah.
09-22-2015, 07:46 PM | #6773 |
Trader Rating: (24)
You want to keep an autox car as narrow as possible, so widening the front isn't necessarily the way to go.
60mm seems like a lot to me, too, when you only really need about 35-40mm for a car with a 25-25.5" tall front tire at a reasonable ride height. 315s need quite a bit of room to move. |
09-22-2015, 08:24 PM | #6774 | |
I did forget to mention I am really trying to run R33 or J30 axles though because of they're stronger and the rzeppa design allows for more articulation (or so I've read). Really won't know how short I can go on the LCA's until I get the new subframe all ready and in. Not too much info on the internet about people running shorter track widths on LCA's. I know PBM's have had that capability for awhile now but it doesn't seem like many people have a need to do it. |
09-22-2015, 08:34 PM | #6775 | |
S14 KA NA two cylinders, 75whp limper |
09-22-2015, 09:11 PM | #6776 | |
keep us posted |
09-22-2015, 10:24 PM | #6777 |
Any of you guys got there GKTech flca yet ?!
AV FABRICATION Built thread sr20vet s14 http://zilvia.net/f/showthread.php?t=535574 |
09-23-2015, 12:23 AM | #6778 | |
Your blowing boots problem is caused by a car too low. Either get it at a proper height of modify your subframe / bushes to mount it further up in the car. |
09-23-2015, 06:59 AM | #6779 | |||
No trailer currently, I drove 300+ miles each way to the Devens Tour this year and miraculously had no breakages hah. Not going to attempt that with nats though, I'll be looking for a cheap tow rig this off season. Hoping to do most of the east coast tour for 2016 and will be doing an Evo school too. Also, Aaron Shoe, who took 3rd this year behind the two GFab guys in Panda, is local to my region so I have a good benchmark to compare to. My main problem is that I don't really know how good of a driver I am since my car has always been changing as I build it to an SM level. This past year I drove a lot but the car was always "broken". My Nismo GT diff is shot (OSG replacement is enroute currently) and I also just found out about my bad ball joints which was probably causing the understeer I struggled with all season. I have beaten one of my nats winning friends in karting however, so there is that haha. Quote:
Edit: I just looked on their site and actually, it says 90-110mm of correction... http://www.tdp.ie/index.php/tdp-prod...ody-front-kit/ Quote:
Also, I'm probably getting the GKTech FLCAs and will be choosing their shortest (+9mm) option.
