Old 01-03-2016, 12:33 AM   #3541
AnonymousBlackX
AnonymousBlackX's Avatar
AnonymousBlackX is an unknown quantity at this point
Originally Posted by KAT-PWR View Post
Yes, you will still need it especially in the rear
Are there a set of MBBattles that require no modification? Aka no rolling or camber? I honestly do know if my fenders are rolled but I wana stay away from modification
My 240
youtube.com/AnonymousBlackX
AnonymousBlackX is offline   Reply With Quote
Old 01-14-2016, 07:05 AM   #3542
stuckonfresh
stuckonfresh's Avatar
stuckonfresh is an unknown quantity at this point
I would try to measure it out on the car first (pm me if you'd like to know how I do this). I'd say 17x9 or 9.5 in their low offset (+15) would probably work well; even 18's. I'd pick up the wheels, check their fitment on the car then order tires accordingly, keeping in mind the tire's given width is in mm. the tire's profile will help give you any extra clearance that may be needed. I'd check rimtuck . com and tyrestretch . com too for ideas.
On a different note, this question is for everyone using an 11.5" wide wheel in the front: what kind of caster settings are you using and what/ how much work did you have to do to the inner wheel wells up front for clearance?
stuckonfresh is offline   Reply With Quote
Old 01-15-2016, 06:20 AM   #3543
I'm Redline
I'm Redline's Avatar
If you want MB Battlee's or Weapon's, the 17x9 +15 will reequire no modification...but you will have to stay about 1/2" UP from the tire, ie, NO LOW for you. With a simple roll from 10 - 2, you can drop those all the way to the edge of the sidewall
My work in progress...
Old 01-22-2016, 07:01 PM   #3544
s13poop
s13poop's Avatar
s13poop is close to perfections13poop is close to perfections13poop is close to perfections13poop is close to perfections13poop is close to perfections13poop is close to perfections13poop is close to perfections13poop is close to perfections13poop is close to perfections13poop is close to perfections13poop is close to perfection
Send a message via AIM to s13poop
Just tried test fitting my new wheels I bought them because of a really good deal
Here's the setup
Work Vs-xx
17x9 +36
17x9 +47
Looks like I'm having some rubbing/clearance issues on my coils
Would I be fine with Ichiba ver 2 spacers 25mm all around? Or What do you guys suggest??
This would be going on a s13 coupe
s13poop is offline   Reply With Quote
Old 01-22-2016, 07:41 PM   #3545
CrimsonRockett
The Architect.
CrimsonRockett's Avatar
Trader Rating: (392)
Feedback Score: 392 reviews
You can easily run a 30MM spacer up front and a 25MM spacer in the back.
What kind of tire sizes were you planning on running?
-Jspec-
Instagram/CrimsonRockett
Old 01-23-2016, 10:12 AM   #3546
I'm Redline
Here's the setup
Work Vs-xx
17x9 +36
17x9 +47
Think about it this way:
Perfect fitment on any stock s-chassis is
17x9 +15
This fitment fits all years on stock suspension, or lowering springs to a 0 gap, or coils down to a 0 gap with no need for roll or pull.
Knowing these measurements, you can now say your WORKs will fit easily with
Front spacer should be ~20mm spacer
Rear should be ~35mm
You can also go 15mm front and 25mm in back and you will be ok, but you will tuck a lot more. the 20mm/35mm will make it close to flush
Old 01-23-2016, 09:09 PM   #3547
s13poop
s13poop's Avatar
17x9 +15
Makes a lot more sense now that I think of it that way
Thanks guys for putting it into perspective for me!
Old 01-27-2016, 06:30 PM   #3548
thekyroshon
thekyroshon's Avatar
thekyroshon is an unknown quantity at this point
Have a s13 silvia. Wanting to run 18x11 in front and 18x12 in rear with 55mm front and rear fenders. What offsets would I need. My car will have tubbed front
Sent from my SM-S975L using Tapatalk
thekyroshon is offline   Reply With Quote
Old 01-27-2016, 09:29 PM   #3549
deolio
deolio's Avatar
11 up front is a bad idea unless you don't want to turn.
Old 02-01-2016, 03:08 PM   #3550
JustA240
JustA240 is an unknown quantity at this point
Searched to no avail,
S13
18x10-4 up front, 225/35
Bad time? or nah?
JustA240 is offline   Reply With Quote
Old 02-01-2016, 03:28 PM   #3551
theStig880
theStig880's Avatar
theStig880 is on a distinguished road
S13
Bad time? or nah?
You should be fine. I had a 9.5j -5 with the same tire size recently on my s13. According to willtheyfit you'll be 7.4 mm towards the strut and 5.4 mm closer to the fender. I had full camber on my coilovers (Pbm) and had more than 7 mil extra space to the fenders and more than 5.4 to the strut as well. I can't comment on rubbing at lock but I didn't rub with my size at all. No tubs but I have beat that area pretty substationally too.
Follow me on Instagram or don't @cason880
theStig880 is offline   Reply With Quote
Old 02-02-2016, 08:37 AM   #3552
dronell19
dronell19 is a jewel in the roughdronell19 is a jewel in the roughdronell19 is a jewel in the roughdronell19 is a jewel in the roughdronell19 is a jewel in the roughdronell19 is a jewel in the roughdronell19 is a jewel in the rough
Just a quick question, found pictures but unsure if those cars use spacers or not.
17x9 et22 all around. Problems or clear all 4 corners? TIA.
dronell19 is offline   Reply With Quote
Old 02-03-2016, 04:59 AM   #3553
I'm Redline
Seems legit...
http://www.rimsntires.com/specspro.jsp
Old 02-06-2016, 06:41 PM   #3554
jared420sx
jared420sx's Avatar
jared420sx is on the path to ruinjared420sx is on the path to ruin
Trying to tuck a 18x10 +25 on stock fenders. Is it possible? I want a decent amount of tuck.
I have bws coils and a few other suspension parts if that helps w the answer. If anyone has pics that would be great. Its a s13 hatch. I would obviously have to pull and roll the fenders. but really dont like over fenders or flares look. Any help would be really appreciated!
jared420sx is offline   Reply With Quote
Old 02-06-2016, 07:04 PM   #3555
KAT-PWR
KAT-PWR's Avatar
Definitely doable with stretch tires. Rolled with camber. I fit 10j +38 with a 255 tire with room to spare just rolled fenders
MRP Manufacturing
Old 02-06-2016, 07:09 PM   #3556
jared420sx
jared420sx's Avatar
Dam ok thanks dude. I was planning on running a 225/40 in the back and a 215/40 on the front. You got any pics by any chance.
Old 02-06-2016, 07:34 PM   #3557
KAT-PWR
KAT-PWR's Avatar
MRP Manufacturing
Old 02-06-2016, 07:34 PM   #3558
CrimsonRockett
The Architect.
Don't mind my terrible looking hatch, but this is 18x10.5 +15 with a 225/40/18 rear.
Fenders have been rolled, not pulled. 18x10 +25 on stock rear fenders will be a walk in the park.
-Jspec-
Old 02-10-2016, 08:11 PM   #3559
Bleakley
Bleakley is an unknown quantity at this point
Seems 17x9 + 15 is right on the money on an s13. I was just wondering what tire size?
I'm looking at purchasing some xxr 551's in the near future. Here are the specs I was interested in:
Front: 17x8.25, +22 wrapped in 215/45-17s
Rear: 17x9.25, +22 wrapped in 235/40-17s
Suspension will be dropped in the future, but will probably never be slammed. And I'd like to retain full lock-to-lock steering.
Bleakley is offline   Reply With Quote
Old 02-10-2016, 10:45 PM   #3560
derass
235/40R17 is about as wide as you can go with just rolled fenders.
I'd would go with 17x9.25 and 235/40 all around. Better front fitment and keep the neutral balance of the car with a square setup. The 8.25 would not be flush and the staggered fitment promotes understeer.
Old 02-12-2016, 06:53 AM   #3561
Bleakley
I think / am afraid I'll lose steering running a 9.25 run up front. 235 seems a little big up front for a car that's hardly gonna see the track. I sorta dig the staggered look, and it should help get power to the ground.
Old 02-12-2016, 08:50 AM   #3562
Jorgs_7
Jorgs_7's Avatar
Jorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really nice
On the topic of 17x9, I'm thinking of wrapping 17x9 +18 in 245/40 going on a S14, stock fenders
Opinions? Too much meat?
Jorgs_7 is offline   Reply With Quote
Old 02-12-2016, 09:49 AM   #3563
SoundEfx
SoundEfx's Avatar
SoundEfx is an unknown quantity at this point
From my initial measurement of the S14, this is my finding for rim and tire sizes with no fender pull or roll:
Front : 17x8 +25 offset
Front tire: 225 - 45
Rear: 17x9 +25 offset
Rear tire: 255 - 40
I haven't bought the rims yet or test fitted any, but this seems accurate because there is alot more room in the rear than the front.
The 17 x 7 (unknown offset) rims I have on right now only has half inch of suspension clearance in the front, but 1.5" in the rear. This is with 1" of space to the front fender with about the same in the rear.
SoundEfx is offline   Reply With Quote
Old 02-15-2016, 01:53 AM   #3564
Mofuhcka
Mofuhcka's Avatar
Mofuhcka is an unknown quantity at this point
Suggested tire size to shove a 18x11 +7 under stock body S13 coupe
@hcr32love 400whp NEO R32 Sedan
Mofuhcka is offline   Reply With Quote
Old 02-17-2016, 02:32 PM   #3565
OffLimits
OffLimits is an unknown quantity at this point
Hey guys so I'm planning to buy some new rims but tbh I'm not an expert in the tires section. Anyways the specs of the rims I'm looking at are Front=18x10.5+5 4" lip med disc and back= 18x11.5+5 4.5" med disc. So the question is what tires size would this rims need? I would like them to look something like this
OffLimits is offline   Reply With Quote
Old 02-17-2016, 04:19 PM   #3566
Mofuhcka
Mofuhcka's Avatar
How low are you would be a good start
Old 02-17-2016, 04:52 PM   #3567
OffLimits
This is how the car sits with 17's (don't mind the curb rash and scratches rims came with car). I can go lower in the front but in the rear I'll have to tuck the wheel to go lower ..which I don't want
File Type: jpg 12699270_1122542974430692_771342522_o.jpg (155.1 KB, 18 views)
File Type: jpg 12736768_1122542967764026_1208529217_o.jpg (136.0 KB, 16 views)
Old 02-17-2016, 04:54 PM   #3568
derass
Have you searched the wheel fitment threads for what people with that wheel size are using for tires?
http://zilvia.net/f/showthread.php?t=129865
http://zilvia.net/f/showthread.php?t=166563
Old 03-02-2016, 06:07 PM   #3569
billyblaze
billyblaze is a well-known jackass
Have 98 kouki stance coilovers with spl suspension
Want 18 vs kf
Have mb battles
18x9 in front
18x9.5 in back
Slight fender roll is all
I like the look but dont know the offset
No spacers either
I want the same look but with vs kf rims
Any way to figure that out?
billyblaze is offline   Reply With Quote
Old 03-02-2016, 06:09 PM   #3570
billyblaze
Want 18 vs kf
Have mb battles
18x9 in front
18x9.5 in back
No spacers either
