![]() Join Date: Oct 2016
![]() ![]() ![]() ![]() ![]() Feedback Score: 1 reviews
Sr20det Idle Loop when cold
I daily drive my car, basically everyday, and the only time this happens is during winter when its cold outside. My car will idle from 1200 rpm, to about 2k rpms then go back to 1200 then back to 2k over and over and over again. Ive swapped IACV but maybe I got a bad one again? Only other thing I could think of is me not running coolant lines to throttle body but ive never heard of anyone having this issue because of that. Maybe because of my colder thermostat and ecu is trippn? Car runs SOLID. Just this issue when cold.
Any info helps, thank you ![]() This is the 3rd winter in a row with this going on and im over it
@Michayyl |
yeah I know that, but everyone on forums is saying they've never had issues when bypassing them. they say its mostly for places where it gets super cold. (im in las vegas)
its not that it just sits there and idles high either, it literally loops from 1200-2000 when the temp is cold outside, car can be warmed up and itll still do it (by warm I mean 145+) ive tried capping them off too, for throttle body and iacv coolant lines thinking maybe cold air is making it act all weird, no change
@Michayyl |
#4 | |
At least, on a honda. I don't know about an SR. |
![]() Join Date: Jul 2005
Hah.
Well here is what i recommend if you don't wana hook up the coolant Install a ball valve (yes from home depot) between the IACV and the cold pipe. then simply regulate the idle down as low as you want... Assuming there are no vacuum leaks. Remember that airflow = idle speed. So if you have high idle speed its getting too much airflow. It can be getting in say, behind the intake manifold or something. So do a pressure test is what I am saying. then add the ball valve if necessary I guess. I got the idea of the home depot ball valve from my father who installed one on his sr20 without me knowing. I started it cold and it idled low and smooth, whereas they usually rocket up in idle speed when you first start "cold" (florida 80*F) I was like oh shit something is wrong! but then I saw the home depot part and /facepalm but you know what, it fuckin works! |
![]() Join Date: Jun 2003
Trader Rating: (130)
step 1, check for vacuum leaks.
step 2, repeat step 1 cuz it sounds like you have a vacuum leak. |
#7 | ||
@Michayyl |
have you cleaned out your IACV?
perhaps its sticking, and cant operate smoothly. i fill em with electronics cleaner or carb spray, then us a power probe to actuate it, and typically they have a ton of buildup in them. Ive seen ones that could barely click open because they had so much crap in em. are you still running a stock ecu or aftermarket? |
#9 | |
@Michayyl |
![]() Join Date: Mar 2009
Especially if you're running a "greddy" intake manifold that puts the IACV on the bottom, the tend to fill up with oily residue more quickly.
Have you made sure that your throttle plate is FULLY closed at idle? A lot of people make the mistake of adjusting the throttle plate stop when doing idle adjustment. It should be fully closed and the IACV provides all idle air... |
#11 | |
I did but it was a long ass time ago, ill give that a look I might have it slightly open then +iacv its just getting a lot of air flow.. hopefully that's it and I just overlooked something super simple lol
@Michayyl |
iacv, idle, idle issue, sr20det |
