Old 12-28-2016, 11:13 AM   #1
Resq
Resq is an unknown quantity at this point
My exhaust got louder and my clutch feels like it's slipping.
Hello Zilvia I'm a new poster with limited experience in mechanics I bought my S13 out of pure love for the car scene. Recently I had my fuel pump, clutch, flywheel, headers gasket and tranny changed at once. After all this my car got louder for some reason. When I'm on a steady acceleration in 1st gear the car makes a popping noise like if it's struggling to push air out. It almost sounds like its backfiring. My clutch feels like it's slipping on idle my RPMs drop to almost 0, it doesn't idle over 1k. Also in neutral when moving the shift knob left and right it feels like it gets stuck moving it from the far left to the far right around the 5th/R gears. It also feels like I'm not pushing out the same amount of power I was before all this. Any ideas on what could be causing this? Also my exhaust is throwing a grayish smoke. Smells like burnt plastic.
Resq is offline   Reply With Quote
Old 12-28-2016, 11:54 AM   #2
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
run to the store and grab yourself some socks then stuff them in the exhaust as far as you can. it will muffle the exhaust down and wont be so loud anymore.
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 12-28-2016, 12:05 PM   #3
Resq
Can you not
Old 12-28-2016, 12:12 PM   #4
snags
snags's Avatar
snags is an unknown quantity at this point
If it happened that recently after having work done, maybe bring it back to the mechanic.. sounds like your clutch may not be bled properly..
As far as being louder, its probably because you have just installed your headers.. either that or you blew out your factory exhaust sock silencer
snags is offline   Reply With Quote
Old 12-28-2016, 12:13 PM   #5
s13silvia123
easiest way unless you want to use a 1/2" thickness Plate about the diameter of your exhaust then weld it inside your exhaust.
Old 12-28-2016, 01:42 PM   #6
Resq
The only thing they did to the headers was change the gasket from it. It's the same headers from before. The sound when in steady acceleration is like a backfire but a lot more nasty sounding.
Old 12-28-2016, 02:15 PM   #7
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
what do you mean, the clutch feels like its slipping at idle? like the car is in neutral but you still feel the car moving forward???
Old 12-28-2016, 02:28 PM   #8
zacharybackus
zacharybackus is an unknown quantity at this point
zacharybackus is offline   Reply With Quote
Old 12-28-2016, 02:48 PM   #9
Resq
It feels like the clutch is slipping (,) at idle my rpm drops to almost 0.
Old 12-28-2016, 03:00 PM   #10
brndck
brndck's Avatar
that makes no sense. answer my question
1: when you have the car in neutral, with the car on flat ground, and your foot OFF the brakes, does the car try to move forward?
if your idle is dropping to 0 and the engine stalls out, you need to fix this issue first. if you are getting a bunch of smoke out the tail pipe, and you had NO smoke before, you need to go back to the mechanic.
Old 12-28-2016, 03:20 PM   #11
LockOn!
LockOn!'s Avatar
LockOn! is making a name for him/her selfLockOn! is making a name for him/her selfLockOn! is making a name for him/her self
LockOn! is offline   Reply With Quote
Old 12-28-2016, 03:22 PM   #12
Resq
No it doesn't try and move forward it just stays stagnant.
Old 12-28-2016, 03:24 PM   #13
Mr.s14.5
Mr.s14.5 is an unknown quantity at this point
lol this thread
Mr.s14.5 is offline   Reply With Quote
Old 12-28-2016, 03:25 PM   #14
Mr.s14.5
s13silvia123 you get the troll of the year award please dont stop.
Old 12-28-2016, 03:31 PM   #15
Resq
Originally Posted by Mr.s14.5 View Post
lol this thread
Lol sorry for trying to get help when I legit have no one else to ask. MY BAD
Old 12-28-2016, 03:33 PM   #16
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
we just have a load of members who like to talk shit... ignore them
Old 12-28-2016, 03:59 PM   #17
brndck
brndck's Avatar
ok. so the clutch slipping has nothing to do with the rpm dropping to zero. separate issues.
now. when you put the car in gear, and let the clutch out, does the car move?
if so, when you give it gas, do the rpms shoot up without the car speeding up?
Old 12-28-2016, 04:03 PM   #18
Resq
Yes and sorta when it's in gear the car moves forward when putting gas but it does feel like I've lost a lot of power. Also when I downshift the engine doesn't really get as loud as it used. Sorry if I sound like a total moron I just have littler experience with Manuel cars.
Old 12-28-2016, 04:26 PM   #19
LockOn!
LockOn!'s Avatar
Frankly sounds like a couple different issues at the same time. Personally I wouldn't have driven it away from your mechanics shop, but you should get back their ASAP and get it straightened out if you actually paid someone for this work and have the papers to prove it.
It'll probably get you a lot further then Zilvians' speculation and flaming. Good luck
Old 12-28-2016, 04:38 PM   #20
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
The bottom line is that you don't even have the automotive knowledge to accurately describe what's going on. Take the car back to the mechanic, give them a shot to make it right. After that, maybe another shop is in order. You've got a few totally different issues. I suspect that a shitty mechanic is the REAL issue...
Old 12-28-2016, 05:33 PM   #21
mechanicalmoron
Go watch some youtube videos on how to drive a manual transmission, and use what you learn to eliminate any parts of your question that describe you just not knowing what you're doing.
Might be that there's nothing wrong, from your description. It's possible to make a manual car do all those things, depending on how and what you do wrong.
Old 12-28-2016, 08:01 PM   #22
Resq
Here's a video of how it sounds on steady idle, when I got the car it sure as hell didn't sound like this it's a lot more aggressive and louder at the end of the video is a example of how it would sound when I'm driving also if you could hear the pause after revs that's when the RPM's drop to almost 0 it doesn't stall btw.
https://youtu.be/O8b-QobURAc
Old 12-28-2016, 10:46 PM   #23
1on1
1on1's Avatar
1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all
What type of fuel pump did you purchase? Are you throwing a check engine light (yellow light with an engine sign)?
instagram
1on1 is offline   Reply With Quote
Old 12-29-2016, 07:05 AM   #24
Resq
The OEM one no check engine light
Old 12-29-2016, 09:10 AM   #25
w0nderbr3ad
Trader Rating: (50)
w0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to all
Feedback Score: 50 reviews
Send a message via AIM to w0nderbr3ad
Sounds like an exhaust leak to me.
The only vid I can compare it to.
http://www.youtube.com/watch?v=RyaI55Rgiko
w0nderbr3ad is offline   Reply With Quote
Old 12-29-2016, 09:40 AM   #26
5280VertDET
5280VertDET's Avatar
5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light
First, there is most definitely an exhaust leak. Take it back and get that fixed.
Second, the easy way to determine if your clutch is going out is to put the car in 4th or 5th, rev it and drop the clutch from 4-5K; if it dies that's good, if it revs up and doesn't die, not so good.
EDIT:
clutch, flywheel and tranny changed at once.
Being that you got your clutch replaced, it shouldn't be doing anything different. HOWEVER, now that you have a new clutch, you engagement point is VERY likely different than it felt before the work was done. Have them adjust the engagement (It's here and in the FSM: http://zilvia.net/f/showthread.php?t=273470) or get used to the new engagement point.
No idea on the smoke or smell, but maybe it is residual from the install; grease, left over plastic from sloppy work, or some rubber hose butted up against the headers thats burning?
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 |
5280VertDET is offline   Reply With Quote
Old 12-29-2016, 01:29 PM   #27
Resq
Thank you all for your replies and helpful input, I'll keep you'll updated on what happens. I appreciate you all. 🙏🏽🙏🏽🙏🏽
Old 12-30-2016, 09:48 PM   #28
mechanicalmoron
EDIT:
There's not shit for adjustment.
I mean, you can tell the difference, but it will function properly at any point in the adjustment range, as I recall.
Old 01-05-2017, 12:35 AM   #29
Resq
Alright took the car to a new shop to get a 2nd opinion on Monday, I was told it's the MAF sensor and my spark plug. Guy told me it would run about $600 just for the MAF sensor alone. Does this sound like it could be causing my issues?
Old 01-05-2017, 06:20 AM   #30
snags
snags's Avatar
if it was the maf it would be throwing a code that you could verify yourself. also if he says the plugs are bad, change them yourself
clutch 5 speed swap, flywheels clutch s13, fuel pump, s13 240sx, trans s13 transmission
