![]() Join Date: May 2003
![]() Not a bad day at the dyno today.
I stopped at 843 when I blew the weld on my intake manifold. You won't see the 843 graph because I forgot to clamp the dyno pick up signal after regapping the spark plugs but the dyno still recorded the pull. Still more left in the motor but I'm gonna leave it right there after repairing the weld on the intake. I honestly didn't even get a chance to advance timing either. ERU performance (Engines R Us) long block with custom ERU Pistons made by Wiesco ported head BC STG 3 cams JWT Cam gears 11mm L19 head studs 6766 twin scroll turbo Fuel Injector Development 2000cc injectors ECU Master Standalone flex fuel setup for sequential injection and ignition Twin Walboro 450 fuel pumps ATI Dampener Kenne Bell Boost a Spark OS Giken Triple disc Z32 tranny Stock water pump, a/c, & power steering Here is the dyno video: https://youtu.be/DYO3tYf8fkc ![]() Here is what the intake looked like after that pull. ![]()
842whp KA-T "Anyone can make power but how long can you make it last?" |
#2 | |
GM2 (SW/AW)
As your sig says, anyone can make power, but apparently it only lasts a 843hp dyno run... lol
Needs more in depth information on this vehicle, this is kind of bland info. There may be more left in that engine but that turbo is generally only rated for mid 900's Anyway, I do enjoy seeing another KA being utilized ![]()
KA-T for life! Current for sale advertisement ![]() |
I have caught Soooo much grief over the dam welds braking on the intake
![]() Its fixed now and I'm very happy with the numbers. I will retune the car again some day in the high boost area and see what I can really squeeze out of this motor. I currently have almost 5K miles and motor is doing great.
![]() Join Date: Jan 2005
![]() ![]() ![]() ![]() ![]() Feedback Score: 8 reviews
Impressive, Glad to see you're still in the game doing big things. how much power are you shooting for after you fix the intake?
s14 kouki ka-t |
Intake is fixed and I'm just driving the car enjoying myself with it. I was at mid 500's for 5+ years. Its a total different world driving at 700 daily. I will do it eventually but to be honest it has been a drain on the bank account to get the car to this point reliably. I took the car on a 5 hour trip out of town and beat the piss out of then drove back 5 hours last week with no issues. So 843 is good for now. I will try to break 900 mark one of these days but with Eagle rods I'm a little concerned. There are so many misunderstandings and misinformation on E-85 it is not even funny. Man be very careful who you listen to and what you read. None of it was correct for my setup however I will say I am 10.5:1 compression so I'm closer to the edge of the E-85 fuel but wouldn't trade it for the world. The torque is great and the response is awesome even with my intake.
#12 | |
#13 | |
![]() Join Date: Jun 2015
#14 |
Okay Dunc, good to see you on zilvia.
I'm guessing because cylinder pressures and his continued head light issues?
MRP Manufacturing |
#15 |
yea, its really the cylinder pressures and adjusting the timing properly. I finally cured my head lifting issues by using washer inserts. But I detonate on E70 fuel compared to E80 and higher. I have heard so many posts and people say " I run the same boost and timing regardless. It doesn't matter." Maybe because they are all low compression motors. I can only speculate. But for my high compression motor. I had to pull 5* timing out of the motor to keep it from knocking and even then I just stopped at 23psi. Don't feel comfortable trying to push the motor any more on such crappy fuel. Once the summer blend is back. I have no issues with knock. All honesty if I had to do it all over I would have gone 9.5:1. Gives you cushion for knock thresh hold.
842whp KA-T "Anyone can make power but how long can you make it last?" Last edited by duncan351; 12-19-2016 at 05:21 PM.. |
#16 |
![]() Join Date: Mar 2008
Looks like you're making power all the way to 7500rpms which is pretty impressive for a KA. Are there any other mods that you didn't list that helped you accomplish this? Are you still using the stock crank?
#18 |
It's not really that uncommon even without the ATI damper (which is common for going passed 7500. Big cams, big revs.
MRP Manufacturing |
#19 | |
Sent from my SM-G935T using Tapatalk |
#20 |
Harmonics are a bitch...
#22 |
![]() Join Date: Jun 2003
Trader Rating: (130)
what are your wheel specs? how much stance do you have? how many followers?
just kidding. this is badass. |
#25 | |
#30 |
Honestly I stopped counting years ago. If I want power and want it reliably I spend the money. You can't get performance and be able to drive across the country without spending some serious coin. Its worth every penny.
