![]() Join Date: Dec 2009
s13 clutch pedal inhibitor switch bypass
Hello zilvia I know you will say search but my scenario is a little different,I have a intermediate no start which I thought I had fixed by replacing the ignition switch,but turns out I didn't and since I cant replicate this no start all the time its kinda difficult to find.Tomarrow I plan on doing a voltage drop and pinpointing the problem but I think its the clutch pedal relay that makes it so you must press clutch to start car.The problem is I have no blue inhibitor relay at all or any clutch related relays and the clutch switch has already been bypassed so the previous owner ran wires god knows where this is why I need help.
So what I want to do is bypass the whole interlock relay and clutch switch and run a wire straight from the back of the ignition switch starter wire to the starter signal on the starter.Doing this I have read people say to just do this but you would think I would need to run another relay at least?Then I read the solenoid does not need a relay because the solenoid acts like a relay?And just run wire straight to it...also will this bypass the original fuse or will I need to add a in line fuse?Thats all I just want to be sure thanks. |
#3 | |
![]() Join Date: Jun 2003
Trader Rating: (130)
you need to do some digging, figure out exactly what wiring the car DOES have, and then start doing some testing. when you turn the key to the crank position, do you have voltage at the starter? if not, why not? |
#4 | |
Sorry to confuse what I'm saying is I want to bypass all this unknown part that should be relay and clutch switch and run a wire from ignition start straight to starter solenoid via signal wire just not sure if I need to add a new relay when I do this?Sorry to confuse you. |
![]() Join Date: Sep 2005
If you're adding a new circuit, be it for convenience, or just getting rid of the old wiring. You should incorporate relays and fuses. Track only well that's different. All 12v sources get a fuse, you don't need a relay to trigger 12v to 12v but If this was a push button start option, I would use a koeo 5v (lower than battery) source to allow triggering of the starter.
#7 | |
I thought I covered that pretty well. If you want to make a proper circuit it needs these things for protection. Will it work without them yes. You could even wire redundancies like the oem. That relay doesn't control the starter like you think it's part of the redundant wiring, just like the clutch pedal switch.
So wire it how you want!
![]() Join Date: Oct 2006
Are you talking about the clutch safety switch that's on the actual clutch pedal? What I did was actually splice that plug together to get to eliminate that switch. You can go a little further and hook it up to another switch kind of like a kill switch of sorts. What I do is use a push button switch to allow for the car to crank. Hopefully this helps.
the new relay is wired in all is good but something odd happened a few times today,when turning the key "off" completely the starter engages for a second making the grinding sound then shuts off? I think the few times I started it without the relay a few weeks back did indeed damage the ignition switch why else would random power go to the starter when turning off key and this does not happen every time...Also is this relay sufficient enough for the starter amp draw?its a ebay special 12v dc 30a/40a relay?
#12 | |
GM2 (SW/AW)
Can I ask why you'd buy/use an eBay relay when 4/5 prong 30/40A relays are sold almost everywhere?
Are you aware of how a relay operates with the pole and coil inside?
KA-T for life! Current for sale advertisement ![]() |
