Old 02-02-2016, 04:05 PM   #19111
lewisfk
lewisfk's Avatar
lewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond repute
odd ball question, I have a brand new walbro 255 fuel pump I bought for my sr20. I wanted to know if it will fit a GM sending unit.
lewisfk is offline   Reply With Quote
Old 02-02-2016, 07:59 PM   #19112
corkscrew
corkscrew's Avatar
corkscrew is an unknown quantity at this point
Anyone with a greddy intake mani have issues with a high or fluctuating idle?
corkscrew is offline   Reply With Quote
Old 02-02-2016, 08:22 PM   #19113
kashira kureijii
kashira kureijii's Avatar
kashira kureijii is making his/her stupidity well-knownkashira kureijii is making his/her stupidity well-knownkashira kureijii is making his/her stupidity well-knownkashira kureijii is making his/her stupidity well-known
This was a while back, but just to sorta show a conclusion and give more info,
The S15 T28 oil drain Hose will not work on an RB. The hose is to short, and not the right diameter.
I couldn't find any OEM ones so I just made one, which was sorta obvious from the beginning but I thought I should try to use the T28 drain and make sure.
Thanks Corbic for the correct advice which I declined to heed.
Originally Posted by bigs View Post
Just get a big sticker that says "copyright infringement"
kashira kureijii is offline   Reply With Quote
Old 02-04-2016, 05:24 AM   #19114
corkscrew
corkscrew's Avatar
Old 02-04-2016, 11:19 AM   #19115
Gingersmurf
Gingersmurf is an unknown quantity at this point
Originally Posted by kashira kureijii View Post
there is no such wheel as a weds zeta 03........i thought it was kinda obvious....
............you're welcome I guess. ..........I feel bad now.......I mean it was sorta funny right?
Lol, just saw you replied. I knew your comment wasn't helpful, i was being facetious. Thus why it took so long to find them, searching for a wheel with no indication of what they are is difficult.
KAs are like Frank's RedHot, Nissan put that shit in everything
Gingersmurf is offline   Reply With Quote
Old 02-04-2016, 02:58 PM   #19116
vlrb30
vlrb30 is an unknown quantity at this point
hey guys, i did a search but didnt find any answers.
I have a s14, it has needed its front left wheel bearing replaced for over a year, but i've been a total cheepskate and not done it. anyway lately, (this year) been hearing a squealing coming from front left, as an engineer it sounded to me like the bearing spinning in its carrier. This is because it is continuous and changes with the speed of the car, i.e it is not the brakes i'm fairly certain.
Anyway its in the workshop getting done now at long last, but my mechanic said it just sounded like a rumbly bearing he couldn't hear it squealing. I should be probably posting this tonight after i'm sure that the new bearing didn't fix the problem, but if it wasn't the bearing causing the squealing any ideas what it could be? Cheers
vlrb30 is offline   Reply With Quote
Old 02-04-2016, 03:00 PM   #19117
vlrb30
oh and also the mechanic said the bearings carrier, i'm assuming its the hub, though i don't know what the exact assembly is like, looked like it was in good condition and the bearing hadn't been spinning in it
Old 02-04-2016, 04:32 PM   #19118
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
replace the bearing, youll be fine.
Old 02-04-2016, 04:33 PM   #19119
SoundEfx
SoundEfx's Avatar
SoundEfx is an unknown quantity at this point
I know that the S13 and S14 front coilovers are interchangable, but the rears are not due to length and upper stud spacing.
If someone tries to hand me a S13 coilover trying to pass it off for a S14, what are the measurements I can perform to ensure that I'm getting a proper S14 rear coilover?
SoundEfx is offline   Reply With Quote
Old 02-04-2016, 05:19 PM   #19120
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
It's like 8" longer. Not a subtle difference.
Also the s14 front coilovers take a larger bolt than s13, just fyi.
google images search s14 coilovers and s13 coilovers and look at the relative lengths between the front and the rear. That'll give you an idea.
I think you're overthinking used coilover buying.
Old 02-05-2016, 02:31 PM   #19121
dz1
dz1's Avatar
dz1 is an unknown quantity at this point
Ok guys i need your help I have a 1995 240sx
One of my corner bulbs went out so I bought an Led now my dash light, my corner light, and tail lights, and license plate lights don't work when I turn them on with the switch.
However I know they work because when I press my alarm button they all turn on as normal.
hazards, blinkers, brakes, headlights high beams work as normal.
All lights work just not with the switch what fuse did I blow?
I only log in when I have money
dz1 is offline   Reply With Quote
Old 02-05-2016, 03:50 PM   #19122
SoundEfx
SoundEfx's Avatar
Thanks man. Honestly, I'm so new to the 240 that I have never seen the coilovers in person.
Old 02-05-2016, 10:48 PM   #19123
chaseaman
chaseaman is an unknown quantity at this point
s14 s14 sr20det
i just bought an s13 240 with a s14 sr20det there is no powersteering belt or tensioner or pully on the pump dose anyone know where i can find these parts ive looked and cant seem to find aanything any help at all would be great thanks
chaseaman is offline   Reply With Quote
Old 02-05-2016, 11:49 PM   #19124
derass
You can get the belt from any parts store but I'm guessing it's disconnected because it leaks.
Old 02-06-2016, 05:46 AM   #19125
Habibi240
Habibi240's Avatar
Habibi240 is an unknown quantity at this point
Any way to tell if a rack and pinion is good with out the motor in the car ? S13
Habibi240 is offline   Reply With Quote
Old 02-06-2016, 01:07 PM   #19126
mau5trap
mau5trap's Avatar
mau5trap is an unknown quantity at this point
Send a message via AIM to mau5trap
How much would you guys pay for a brand new set of s14 Stance GR+ pro's?
mau5trap is offline   Reply With Quote
Old 02-06-2016, 02:12 PM   #19127
Almighty So
Almighty So's Avatar
Almighty So has a reputation beyond reputeAlmighty So has a reputation beyond reputeAlmighty So has a reputation beyond reputeAlmighty So has a reputation beyond reputeAlmighty So has a reputation beyond reputeAlmighty So has a reputation beyond reputeAlmighty So has a reputation beyond reputeAlmighty So has a reputation beyond reputeAlmighty So has a reputation beyond reputeAlmighty So has a reputation beyond reputeAlmighty So has a reputation beyond repute
^ if they're brand new, why not just check prices online for brand new ones..?
$1300-1400 from Amazon, frsport.
Originally Posted by Phlip View Post
This pissing match is getting old
Almighty So is offline   Reply With Quote
Old 02-06-2016, 02:17 PM   #19128
mau5trap
mau5trap's Avatar
sorry, I forgot to add from a private seller
Old 02-06-2016, 08:58 PM   #19129
Habibi240
Habibi240's Avatar
Offer and go from there
Old 02-06-2016, 09:07 PM   #19130
kashira kureijii
suspension question
So I have read through the first page of the roll center adjustment thread a few times, and I feel like I sorta know what each part of the suspension arm system does, I just don't know where to begin.
Don't say "why did you buy shit you don't know how to use?" please, I am trying to get better at stuffs
here is the setup
Circuit sports suspension arm package
Circuit sports inner and outer tie rods
ST rear swaybar, stock front because the ST front wouldn't clear the RB oilpan
new bushings.
FA 500 coils.
I took both of the subframes down on my car to put the arms and all that shit on, So I'm pretty sure the suspension is gonna be pretty misaligned.
I don't know much about suspension, and haven't really done something like this before. I really want to learn how to do all this correctly.
Should I take the car to get aligned and then adjust from the alignment?
I can't take it to nissan because of the arms, and I am afraid to take it to a alignment place, because they are commonly run by dumbasses who think they expert "mechanics" Do most alignment places have experience with these type of aftermarket arms? or will they see that everything is different (no longer use the alignment bolt in rear) and freak out?
Can I align it myself? What would I need?
Sorry for the suspension noobery
Old 02-06-2016, 10:40 PM   #19131
Bleakley
Bleakley is an unknown quantity at this point
I am not very knowledgeable about suspension, but I used to take my car to SEARS before I met people. I talked to the shop manager about me going into the shop and she didn't care as long as it didn't lengthen the time of the job (edit- I did have steel toes and safety glasses I just happened to have in the car) I told him what I needed, watched him and told him how to spec it (couldn't touch the car due to their safety crap, let alone be in the shop) til I said okay, and that was that. I don't trust anyone with my car anymore and if I can not escort my vehicle through services I can not perform I take my car elsewhere. Simple as that.
Bleakley is offline   Reply With Quote
Old 02-06-2016, 11:00 PM   #19132
Habibi240
Habibi240's Avatar
I've yet to get my alignment but I heard Firestone has a lifetime warranty on alignments but they cost 180
Old 02-06-2016, 11:05 PM   #19133
Habibi240
Habibi240's Avatar
Sounds like the switch
Old 02-07-2016, 07:49 AM   #19134
I'm Redline
I'm Redline's Avatar
I'm Redline is a name known to allI'm Redline is a name known to allI'm Redline is a name known to allI'm Redline is a name known to allI'm Redline is a name known to allI'm Redline is a name known to allI'm Redline is a name known to allI'm Redline is a name known to allI'm Redline is a name known to allI'm Redline is a name known to allI'm Redline is a name known to all
Look in the quote for answers:
here is the setup
Circuit sports suspension arm package Get these on first, making sure to lightly grease all threads and match the stock length parts as close as possible on length adjustments
Circuit sports inner and outer tie rods Put these on next, and adjust all parts so that your wheels are as close to aligned as possible
ST rear swaybar, stock front because the ST front wouldn't clear the RB oilpan BUY thee ST front bar, and fab frame plates to drop it so it clears your RB oil pan
new bushings.Since all your arms came with new bushings, install the rest of the bushing kit. IF you want to use your bushings in the new arm set, make sure they fit, and install them before installing the arms
FA 500 coils. Install at the same time as the arm set, first since you will need them installed
The best you can do by eye is get stuff aligned as close as possible, then slowly drive to your alignment shop. CALL the shops first to be sure thy are experienced in your set up. Our local Firestone alignment crew knows these aftermarket set ups and does a great job adjusting it all. LIFETIME ALIGNMENT is SO worth it!
Can I align it myself? What would I need? You will need the 'string kit' that many drift race shops use
http://www.racerpartswholesale.com/p..._Alignment_Kit
It's pricey, but it does a kick ass job and will get you to within .5* of perfect
We all have to begin somewhere. I am new to 240, but experienced in track applications on suspensions, frames, and proper set up from vintage racing on Mustangs, Cortina's, and Alfa 1600's. I am totally in love with teh 240 for what it is and the huge potential it has to be a great car
To fab a frame plate, simply measure the width of the frame and the length you need. Make sure you take a paper/posterboard, and MAKE A TEMPLATE of the holes. Any fab shop will have sheet steel and can cut and drill for you so long as you give them the proper dimensions and the template for the holes. I am guessing your oil pan is not interfering more than an inch so this is the best way to clear it. You don't want to lift the engine since keeping weight low is key. You will need longer sway bar bolts at this point(your fab plates). Having the front bar for the set will allow your car to be properly set up and statically tuned. The OE bar in front, and heavy bar in back will cause body roll in front, and force a understeer condition in a car you want to oversteer(back drift out, not front snowplowing in corners)
I hope I have not confused you anywhere and that you now have a better idea on what to do to make it all work
1996 Zenki 'Baraketsu Tenshi', Burst Angel
My work in progress...
I'm Redline is offline   Reply With Quote
Old 02-07-2016, 08:11 AM   #19135
kashira kureijii
Originally Posted by Bleakley View Post
Thanks dudes, I think, I understand what needs to be done now. When I installed all this stuff I measured the spacing on each arm, and tried to get them pretty close to similar. for the front I just sorta tried to get them equal length and have the wheels in the same toe.
As for the swaybar, I actually already have the ST front swaybar, and the syko mount kit (which includes the little frame spacer deals.) I was having a little trouble with the brackets the ST kit gives you, as they are just normal brackets and don't have one side longer than the other like the stock brackets(which it what the syko spacer kit is designed for), ST kit gives you a bunch of washers that are supposed to remedy it just by spacing it out with a longer bolt. I'll figure it out though, I'm sure that if I mess with it enough it will work out.
Thanks for the advice dudes. I will take it to Firestone, when I get it all figured out.
Old 02-07-2016, 08:34 AM   #19136
ShakotanGazelle
ShakotanGazelle is an unknown quantity at this point
So wtf holds the trunk lock cylinder in place? My car didn't have one when I bought it so I bought a round Silvia lock and it seems like there's supposed to be some sort of clip behind it?
Also if anyone has what I'm looking for that'd be sweet.
ShakotanGazelle is offline   Reply With Quote
Old 02-07-2016, 01:40 PM   #19137
chaseaman
The belt broke when the provirus owner had it and he took the tensioner off along with the pulley the pump or lines never leaked to my knowledge
Old 02-07-2016, 02:39 PM   #19138
derass
FA 500 coils.
Here's my advice. After you have installed everything, first set the ride height. Setting the TC and Traction rod lengths is a bit tricky without the right equipment, TC especially. Just set TC length to stock, these cars have a ton of caster anyways.
Then set the traction rod length after reading this: http://www.nissanroadracing.com/showthread.php?t=1652
You can do most of the alignment yourself. I use this technique for toe and camber: http://www.negative-camber.org/jam14...alignment.html
Set the camber using the method in the first link. Anywhere between -0.5 and -3.0 is good. Just make sure it's even side-to-side and that there is more in the front than rear.
Finally set the toe. You want about 1/16" toe-in both front and rear.
I find it very suspicious that instead of replacing a $10 dollar belt they chose to remove more parts. That's why I think it was leaking.
Old 02-07-2016, 07:57 PM   #19139
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
mr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond repute
Feedback Score: 31 reviews
Small Questions Thread (SEARCH FIRST! Use this instead of making NEW threads)
I've been searching all kinds of shit for this and am curious. I recently picked up an Ecu for my Sr with a 550cc/n62 tune. I was looking into sti injectors but everything is so conflicting id rather not fuck with it. I've been looking for some FS but everyone and their mom has 555cc and not 550. Am I going to have huge issues with 555's in there instead of 550? If it is then I'll just buy new 550's since I can't seem to find any FS. Thanks in advance !
mr.nismo. is offline   Reply With Quote
Old 02-07-2016, 08:14 PM   #19140
derass
It would just run slightly more rich. Perhaps you could send the ECU back for an adjustment or correct for the larger injectors with an SAFC. Deatschwerks and Five O are both available in 550 and are quite cheap.
