#18511 |
Im just getting towards the end of my Rb swap and was looking over things. I have a jdm S14 kouki. I noticed two threaded ends poking out of my firewall, right under the abs. Theres so yellowish fluid in them and I cannot figure out what they are for. Idk what side they would be on, on the usdm models. However they are not the heater core ones as I already have that hooked up. Can grab a pic if needed but as we all know thats a bit of a hassle. Ty for any replies.
#18512 |
Usually will depend on your spring rates and personal preference of stiffness.
Not sure if you're google searches local but try Japan search and America search. I haven't read any recently but I promise you someone has reviewed them before. |
#18513 | |
![]() Join Date: Jun 2014
![]() I have been thinking about 20K to front and 18K to rear. My dad does have 10K front and back on supra, but it's heavier car. But it needs stiffer springs. What I have heard 326power coilovers handle well even the car would be really low. That's what I'm going for. Not too low that I can drive it in Finland tho. ![]()
Juucso - Instagram |
#18517 |
That's all 'positive' ventilation for your engine. The vacuum pulls air from the crankcase and head so the oil does not cavitate and cause loss of lubrication.
You want to keep those in place, but if you do insist on removing them, be ready to buy new lines and catch cans for most of them. You still need at least one in place to allow internal air that is created to get out though. alphabet: Many of the parts ARE interchangeable. go to www.nissanpartsdeal.com and input your year/s for sohc and dohc and you can crosscheck which parts you can swap and those you cannot
1996 Zenki 'Baraketsu Tenshi', Burst Angel My work in progress... |
#18519 |
#18520 |
![]() Join Date: Oct 2010
Hey guys, trying to see what the best ECU set up would be for what I am going for.. just recently bought a garrett gtx3071r twin scroll with t3 v band housing.. block has forged rods, head is stock at the moment.. bought sum 740cc injectors going with twin scroll full race twin scroll t3 manifold, twin scroll full race downpipe, 38mm tial wastegate..now the question would be should I stay stock throttle body? would AEM be a better option than Power FC ? also have an aem wideband and greddy boost controller laying around Im just hoping I don't miss anything before I put it all on and send to tune
#18522 |
Has any one tried running the stock 6 spoke rims off a 07-12 sentra? Having a hard time finding a pic. Im seeing how it would look on a hatch
SUSPENSION>Power |
#18523 |
I have a s13 sr20set I replaced the oil pump and I'm putting everything back togeher but I'm having trouble getting the crank pulley spacer installed. I have the "slot" on the crank shafted at 12 o' clock as pictured in the fsm and lined up the slot on the spacer but it's not sliding in. Any suggestions, thanks for the help in advance.
under cover brother |
#18525 | |
![]() Join Date: Dec 2013
![]() ![]() ![]() ![]() Feedback Score: 4 reviews
Its kinda hard to describe without showing you in person, but the pump will not just slide straight on horizontally You have to sorta angle it and then it slides right on I know cuz when I tried tapping it on horizontally for like an hour I almost busted the seals Don't know if that helps cuz I don't remember very well, but I remember that it wouldn't just slide right on you had to mess with it (angle etc) In a way not said in the fsm |
#18526 |
![]() Join Date: Sep 2012
![]() Feedback Score: 9 reviews
bought a standard works bell hub for my s13 and was wondering if there is any way to modify it to cancel out the turn signals?
Instagram:@juhd_ |
#18528 | |
#18529 |
![]() Join Date: Jan 2013
I'm new to body repair and I am wondering if it is even possible to get this looking new again. What exactly would be done to fix this? Anyone have any idea what this would cost?
I slapped some rock star stickers over the parts where paint chipped off to try and prevent rust. I hammered it back out with a piece of wood but it looks pretty terrible and there is a gap between the tail light and rear quarter. I will get some more detailed pictures up tonight. ![]() ![]() |
#18531 |
#18532 | |
![]() Join Date: Aug 2013
Anyone know of an adapter fitting for the OEM FPR to work on Top Feed fuel rails?
JGY has one that says it should work, I just need the fitting though. http://jgy.cc/240sx/fuel.htm Quote:
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 | ![]() |
#18538 | |
ITS LISA'S FAULT!!!
![]() Join Date: Jun 2003
Trader Rating: (41)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 41 reviews
with <350whp, you will want around 45-50psi of properly adjusted fuel pressure to bring down injector duty cycle (depending on the size of the injectors). the OE FPR is not the way to go to do this. its old and unreliable for tuning applications. upgrade yourself to a Tomei or Aeromotive unit. theres a reason OE bungs arent used on aftermarket rails ![]() |
#18539 |
![]() Join Date: Sep 2004
Trader Rating: (24)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 24 reviews
^5 years at 350+whp with stock fpr. No issues at all...
With an aftermarket rail, yeah, don't run the stock one. but the stock one works just fine. |
Tags |
180sx type x kouki, 1jz, 2jz, 300zx, clutch, faq, ka24de, n/a, non-turbo, question, redtop s13 180sx silvia, s14, search, solenoid, starter, z32, zenki |
