Old 01-29-2012, 07:00 PM   #1
boostfreak27
boostfreak27 is an unknown quantity at this point
New Garrett GTX2867r
So it is time to replace the turbo on my Sr. as the seals are going out and leaking oil. The gt2871r was my original and simple choice. After hearing about Garrets new expanded line of their gtx turbos I decided to stretch my budget and see how these perform on the sr. So I ordered the Gtx 2867r and am setting it up for an external wastegate. Turbo came in yesterday, and i still have a few loose ends that i need to finish before getting the car on a dyno for a tune. I haven’t seen anyone run one of these on an Sr yet so I’m excited to see how it does. Just thought id give everyone a heads up , and hopefully we will have some dyno graphs to check out soon!
boostfreak27 is offline   Reply With Quote
Old 01-29-2012, 07:14 PM   #2
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
please give details, dyno graphs, etc,
before and after?
these are still single scroll, no? pix of exhaust side?
Old 01-30-2012, 01:29 AM   #3
AdrenalineS14
AdrenalineS14's Avatar
AdrenalineS14 is an unknown quantity at this point
Mmmmmmm I def wanna know the results! Def interested in how this turbo performs!
AdrenalineS14 is offline   Reply With Quote
Old 01-30-2012, 01:44 AM   #4
Croustibat
Very interested too. A friend of mine is going to fit it on its CA, and i might as well next time i blow a turbo.
Old 01-30-2012, 10:16 AM   #5
Seraphim38
Seraphim38's Avatar
Seraphim38 is an unknown quantity at this point
Send a message via ICQ to Seraphim38
Yup I am curious as well, though I have a 2871R .64 with less than a thousand miles on it that I will be updating with the T25-EWG-44 .72 housing, which means I won't be buying the OP's discussed turbo any time soon...
Seraphim38 is offline   Reply With Quote
Old 01-30-2012, 10:37 AM   #6
didderson
didderson's Avatar
didderson will become famous soon enoughdidderson will become famous soon enoughdidderson will become famous soon enoughdidderson will become famous soon enough
Send a message via AIM to didderson
Keep us in the know man!
didderson is offline   Reply With Quote
Old 01-30-2012, 02:59 PM   #7
boostfreak27
Yes, the turbo is still single scroll. I never had the car on a dyno before, but im sure there are plentyof base line dynos you can compare to.
Engine mods are:
CP pistons
H- beam rods
Comtech hg
Arp head studs and main bolts
Bc valve spring and retainers
C/S ras
Tomei 260 cams
Megan exhaust mani
Front mount
Nismo 740 cc inj
Greddy ProfecII boost controller
Aem Fic
Looking foreward to getting this thing done. Ill post a pic of the turbine housing soon.
Old 01-30-2012, 05:10 PM   #8
!Zar!
!Zar!'s Avatar
I must say this is indeed interesting.
Old 01-30-2012, 05:24 PM   #9
Walperstyle
Walperstyle's Avatar
Walperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really nice
Send a message via MSN to Walperstyle
This effieiency of these turbos is amazing. Way less chance of compressor surge. I wish I would have purchased one of these, but they are expensive.
KA-T ORG-Function over Flush
Walperstyle is offline   Reply With Quote
Old 01-31-2012, 06:46 PM   #10
inis
inis is an unknown quantity at this point
Hi,
Although I dont own any of the cars on this site, or even a car with a SR engine. I've been watching this thread. I'm placing my order for the gtx2867r this thursday. I was told it has a anti-surge housing but its hard to tell in your pics. Can you verify this?
Looking forward to dyno results.
-Inis
inis is offline   Reply With Quote
Old 01-31-2012, 06:55 PM   #11
2stepGoesPowPow
2stepGoesPowPow's Avatar
2stepGoesPowPow is an unknown quantity at this point
Originally Posted by inis View Post
Hi,
-Inis
What are you getting the turbo for?
2stepGoesPowPow is offline   Reply With Quote
Old 01-31-2012, 07:32 PM   #12
inis
I have a built zx2 with the zetec powerplant. Engine is fully built, coated internals, cnc'd head with a hand pnp, OS valves, arp throughout, aftermarket block, aftermarket mains, coated acl bearings, 3 stage dry sump with a peterson tank, aftermarket intake mani, crown vic tb, 2.5" ic piping, hargett clamps, full mandrel bent 304SS exhaust w/v-band clamps throughout. Megasquirt for tuning.
Just recently (a week ago) sold my gt2860rs, had a tial v-band housing laying around so I'm doing that with this turbo. I've yet to order. Pulled the engine last sat to do a few other mods to it..and found oil in the exhaust port of cylinder 3. I've yet to investigate it but I think its the valve stem seals. Not to worried about it.
Old 01-31-2012, 07:40 PM   #13
2stepGoesPowPow
I have a built zx2
You should get a 240
Old 01-31-2012, 07:47 PM   #14
Walperstyle
^ford escort? Pending your fuel choice and tune, you could get 400hp+ with this turbo, and the housing makes it way better to avoid surge. If you go to Garrett's website you can see graphs of how this stacks up with the regular turbo's, as well as go through the 'turbo selection app' to figure out approx what turbo best fits your car.
You should also consider sticking with hot side no larger then .70 ar. It all depends on what your goals are, but 4 cylinder engines want smaller exhaust housings.
Old 01-31-2012, 08:07 PM   #15
inis
I had great luck with the .86 hotside. Someone with the same gt2860rs made 360whp on 21psi. The new gtx3076r another guy made 602whp on alittle over 30psi.
Currently I'm running 93 but will be swapping to e85 after this turbo. My goal isn't so much as overall whp but because I have a dry sump I can rev incredibly high. A gtx series should suit me fine for higher rpm's.
Escort/zx2 whatever you want to call it.
Old 01-31-2012, 08:25 PM   #16
Walperstyle
What is the displacement of the engine? I have a .82 hotside on a GT35R turbo and I've calculated that not much is going to happen till way later in the RPM range. .64 makes for faster spool.
You have a dyno graph, I always like to see.
Old 01-31-2012, 08:45 PM   #17
inis
stock displacement is 1998, I should be a hair over that with the bore.
On the gt2860rs with .86 a/r I was hitting 1 bar around 3100rpm's. This isn't from watching gauges. This is what datalogs tell me.
The gt35r never worked real well for the zetec.
Old 02-01-2012, 12:33 AM   #18
boostfreak27
Hi,
-Inis
Yes it is an anti surge housing. Sorry for the glare. Ill upload a few mor pics of my progress and turbo tomorrow. Thanks
Old 02-01-2012, 09:50 AM   #19
inis
Awesome can't wait to see.
Old 02-01-2012, 11:00 AM   #20
AdamR
AdamR is an unknown quantity at this point
That's because AR isn't the same for different Turbo groups. A .86 AR on a 35 is much larger than a. 86 on a 28.
AdamR is offline   Reply With Quote
Old 02-04-2012, 12:54 PM   #21
boostfreak27
update:
Okay so time for a little update. Got the turbo mocked up. Everything fit together quite well and looks great. I'm still waiting for my wastegate to arrive, i have a little over 4" to the strut tower. The new Tial vmr wastegate is a little smaller than their previous version so hopefully everything fits! Next step is to install the wastegate and weld up a new 3" intake and dump tube at my shop.
Last edited by boostfreak27; 02-04-2012 at 01:01 PM.. Reason: pictures didnt post properly.
Old 02-04-2012, 12:57 PM   #22
Walperstyle
sweetness sweet
Old 02-04-2012, 01:03 PM   #23
boostfreak27
Sorry about that, should be good now.
Old 02-04-2012, 01:04 PM   #24
EsChassisLove
EsChassisLove's Avatar
Trader Rating: (26)
EsChassisLove is an unknown quantity at this point
Feedback Score: 26 reviews
How much was this?
I have a fresh 2871 on my SR and I am rebuilding right now. I might sell the 2871 and get this bad boy.
IG/TikTok-ThatS14_Z06guy
EsChassisLove is offline   Reply With Quote
Old 02-04-2012, 01:11 PM   #25
Seraphim38
Seraphim38's Avatar
Finally some pics! and not only that, pics include the housing that enables external wastegate mounting! I have been considering converting over to the T25-EWG-44 housing on my current 2871R but so little info exists from actual users.
By the way, ATP sells a v-band 90 degree bend elbow so that you can mount a standard 44mm Tial v-band at whatever angle you want. It's much more convenient than trying to fit the wastegate directly on the housing. $69
MVR 44mm Wastegate 90 Deg Elbow, 100% 304 Stainless : atpturbo.com
Old 02-04-2012, 01:19 PM   #26
EsChassisLove
Trader Rating: (26)
44mm is hella overkill for that little turbo. lol
Old 02-04-2012, 01:25 PM   #27
Freddy
Freddy's Avatar
Freddy is an unknown quantity at this point
oh please provide dyno charts
please
Freddy is offline   Reply With Quote
Old 02-04-2012, 06:19 PM   #28
inis
I had no issues with the gt2860rs and the tial 44v. Considering this turbo is good for nearly 40psi, I say a 44mm wastegate is fine.
Old 02-04-2012, 06:37 PM   #29
Bubba
Bubba's Avatar
Bubba is making his/her stupidity well-knownBubba is making his/her stupidity well-knownBubba is making his/her stupidity well-knownBubba is making his/her stupidity well-knownBubba is making his/her stupidity well-known
I am very interested to see what you do with this turbo on the SR20 since I have been looking at the GTX3071 and 3076 setups for my KA-t.
I'm not shooting for high numbers as much as I am shooting for response time.
Can't wait to see a dyno graph.
Good at wrenching, terrible at electrical. Lord help me... HAHAHA
Bubba is offline   Reply With Quote
Old 02-04-2012, 07:23 PM   #30
jr_ss
This looks promising... I'm currently building a VVL setup with a GTX3076R w/ a .82 hotside.
gt2871, gtx, gtx2867r
