![]() Join Date: May 2012
![]() Contact number is 626-319-2079 located in Los Angeles Pasadena area . I only let you test drive & burn out and do donuts if you have cash in hand. I have videos and what not I have only put on 500 miles into the swap so clutch etc Barely broken in. Reason for sale? I grew out the game. If I don't get price I want I will part out this car . Swap will be sold "plug and play" with harness But for now as is! Car is clean title. Registered! And I have a smog guy to resmog for you for title transfer . In terms of cops I actually don't get pulled over as tracked out as it looks. Cops actually give me respect for it. So I think you'll be good with the law
Parts: Engine: 1994 q45 s2 motor . With 150xxx miles on it . This is baby miles for a VH. There's guys out there boosting it at 180k miles & abusing it. Check out v8nissans.com to familiarize yourself with the motor and community anyways Seals were replaced hoses etc . Motor is running healthy like seriously . I didn't abuse motor as much as I should of . Transmission: 300zx . 350z pivot ball 350z clutch fork new throw off bearing fidanaza 10 pound flywheel Stage 3 act 6 puck clutch & pressure plate. New slave cylinder with Isis hardlines. New starter New alternator New battery (relocated to trunk) New 02 sensors. New iridium ngk spark plugs . New coil packs New fuel injectors (oem) New walbro fuel pump New q45 caliper and brakes up front. New power steering pump Have power steering cooler Mishimoto power steering res. 1 piece drive shaft Welded differential (less than 500 miles) Tack welded strut tower and body. So car is pretty stiff I only change my oil with AMS oil full synthetic . ( expensive ass oil) 100 dollar change oil. Fuck me right ? Swap parts : (all less than 1000 miles) xcessive trans motor adapter. Xcessive motor/ trans mount Maxworx headers (2 3 inch exhaust , x pipe & 3.5 inch magnaflow muffler. (I put muffler so the cops would stop bitchin at me & neighbor complaint haha. Sentra booster (why?) because engine wouldn't fit . Sikky front sway bar Mishimoto X line huge radiator with electric fans Suspension. Brand new flca Tien inner outer rods New Godspeed Coilovers Godspeed camber arms Gs tension rods Sikky sway bar 5 lug converted 300zx rear hubs and front ichiba Also has q45 front brakes with drilled rotors . Exterior . 80mm rear over fenders 40 mm front over fencers Silvia front end with pig nose lip. Greddy rocket bunny wing Yes I still have rear bumper Rims nismo lmgt2 18x11 +12 (rear) 3 piece with 1.5 inch spaced Fronts Varrstoen es6 18x10.5 Oem Silvia bumper, hood, and oem GTR grill Dual projector headlights Interior Momo bucket seat and sparco steering wheel Pros: fun as fuck to drive and drift . Power band is great & the torque you need is right there . Healthy motor , Cons needs paint , speedo doesn't work tac is off a bit driver window don't go down . & oil pan leaks a little but what oil pan ![]() ![]() ![]() ![]() Last edited by jamrome918; 01-23-2015 at 01:08 PM.. Reason: Photos |
![]() Join Date: Jun 2003
Trader Rating: (130)
post in the right section.
Tags |
240sx, s13, vh45, vh45de |
