07-06-2014, 12:44 AM | #1 |
Sr20 part throttle faster than full throttle
I put a new turbo and some injectors installed on my car earlier this year and have had nothing but issues with the car since. The first issue was the vacuum readings dropped to around -18hg from -20. No big deal. I finally got a wideband installed and it will idle at 16.5 if there is no correction from the power fc. The bigs issue is that i feel a hug loss of power at any psi the car feels to hit a wall. I can accelerate at partial throttle and their would be no change if I put my foot to the floor, where preciously it was noticable on an S15 turbo. That biggest thing is that my CAS will no long line up in the center. I have to adjust it to get it to line up at 15btdc. So, it does not sit in the middle (although, I was told to do this with the old turbo setup and just kind of left it, but I cant get it to go back)
I am quite confused of what to focus on to figure this out. Anyone have any suggestions? Setup S14 sr20det 2871r 550cc (was told this, will try stockers) Built head minus cams Z maf -Lawz
私の恥ずかしブログです。 |
07-06-2014, 12:51 AM | #2 |
Trader Rating: (130)
Feedback Score: 130 reviews
You're running a power fc? Who tuned it? You shouldn't have to mechanically adjust the CAS.
07-06-2014, 04:33 AM | #3 |
Get someone to set the CAS at its right point. If he cant, it means the timing is out one tooth, so you need to take care of that.
Then get someone to map your car, AND NEVER TOUCH THAT PFC OR CAS AGAIN. |
07-06-2014, 06:12 AM | #4 |
I was running a map from steve shadows. He told me to adjust the cas 5 degrees after syncing the power fc to the ignition timing. Ever since then, I haven't been able to re adjust it back where it is suppose to go.
I know how to set my timing. I took the valve cover off. The links line up on the intake and exhaust side, but the CAS wont line up where it should without being turned. Which throws it off so that it wont align in the center on both sides. Could it be the CAS it self?
私の恥ずかしブログです。 |
07-08-2014, 08:52 AM | #5 | |
Gone to the darkside... E36 on Rezax/FN01RC combo |
07-12-2014, 08:07 AM | #6 |
I appreciate it. I have set the CAS before but, this time, it wouldn't line up. That is why I mentioned it.
I think what is really worrying me is: on my PFC commander, my injector duty % reads about 49-54% on a wot pull. The thing is that it never increases no,matter how much boost I am running. I could see 54 at 18psi, but I could see it at 10 or 12 too. My afrs do not read lean and are fairly rich, actually. I realize this is at different load points, it just holds back. If set to 18psi and do a WOT pull, it feels the same as it did at 10 or 12psi when boost locks in. Anyone have a pfc with 550s have some of those duty numbers you can share?
私の恥ずかしブログです。 Last edited by Mr. white; 07-12-2014 at 02:37 PM.. |
07-12-2014, 10:43 AM | #7 |
Why not contact Steve and do some diagnostic work with him. Maybe there is something fishy going on in the PFC. It is quite odd that you cannot get the CAS to line up. Are you positive you're at TDC on cyl1? I'm not sure why everyone makes it out to be so complicated to set up. It's pretty damn simple really.
