Old 05-06-2011, 11:15 PM   #1
Darth & Vader
Darth & Vader is an unknown quantity at this point
Small A/C condensor recommendations?
I've been trying to search around for an A/C condenser thats smaller in size than the S14 one (27in x 14in). I've had my radiator support modified to fit my radiator "inside" the core so the stock A/C condenser location is now taken up by the radiator. So I plan to have the condenser sit between the radiator and the headlight brackets, but need to know what car uses a smaller ac condenser than the s14 one. I plan on purchasing that smaller A/C condenser and using it on my s14 and having the lines made. All that is no problem, its just finding the A/C condenser. Thanks for the help.
Darth & Vader is offline   Reply With Quote
Old 05-07-2011, 06:58 AM   #2
MrFairlady
MrFairlady's Avatar
Trader Rating: (31)
MrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant future
Feedback Score: 31 reviews
Send a message via AIM to MrFairlady
HPI makes an amazing condenser for the S14.
But get ready to pay...though not super expensive..Its half the size of the OEM.
z-tERty-2
MrFairlady is offline   Reply With Quote
Old 05-07-2011, 08:51 AM   #3
MrJdmEh2
MrJdmEh2's Avatar
MrJdmEh2 is an unknown quantity at this point
Maybe you can use a civic condensor they are about half the size
MrJdmEh2 is offline   Reply With Quote
Old 05-07-2011, 10:43 AM   #4
UNITEDMASTER
UNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to all
Yea Honda cars is what i was thinking too. Or go to your local junk yard & have a look around,see what will work then order a new one.
MR JACKSON.
UNITEDMASTER is offline   Reply With Quote
Old 05-07-2011, 11:01 AM   #5
Darth & Vader
Sounds pretty good. I was thinking Honda as well but just wanted to confirm with the pros. I don't really have too much time but i will manage to make it down there.
Old 05-07-2011, 11:21 AM   #6
MrJdmEh2
MrJdmEh2's Avatar
I have one from my old civic ill take the measurements for u when i get a chance
Old 05-07-2011, 11:25 AM   #7
Darth & Vader
Awesome! I would really appreciate that man. And if you're willing to get rid of it i wouldn't mind taking it if the price is right.
Thanks
Old 06-05-2011, 10:01 AM   #8
str4g63
str4g63's Avatar
str4g63 is an unknown quantity at this point
Send a message via AIM to str4g63 Send a message via MSN to str4g63
Let me know what you find I was planning the same thing was thinking the chase bays Tucked Rad. But wanting to keep a/c. That's a good idea on using a Honda one..ill look into it also and let you know if I come up with it first..
str4g63 is offline   Reply With Quote
Old 10-20-2011, 11:24 PM   #9
MR_GUTTI
MR_GUTTI's Avatar
MR_GUTTI is an unknown quantity at this point
Any updates?? Planning the same ^^^
MR_GUTTI is offline   Reply With Quote
Old 04-18-2020, 11:10 PM   #10
XgoldzenkiX
XgoldzenkiX is an unknown quantity at this point
Any update since 2011?
XgoldzenkiX is offline   Reply With Quote
Old 04-20-2020, 11:35 AM   #11
2muchboost
Trader Rating: (33)
2muchboost is an unknown quantity at this point
Feedback Score: 33 reviews
Sanden makes a compact unit that I have seen used in LSx swaps. Unit seems to work well even with the brutal down here in Tx.
2muchboost is offline   Reply With Quote
Old 04-20-2020, 11:53 AM   #12
ADIDASilvias
ADIDASilvias is a jewel in the roughADIDASilvias is a jewel in the roughADIDASilvias is a jewel in the roughADIDASilvias is a jewel in the roughADIDASilvias is a jewel in the roughADIDASilvias is a jewel in the roughADIDASilvias is a jewel in the roughADIDASilvias is a jewel in the rough
Other than the major thread necro, I agree this topic needs more discussion. I'm finally getting back to my RB25 Neo Zenki build after a 2 year hiatus. I got a little bit burnt out and had other projects lined up to complete for various other hobbies, but now it is time to get back to it with gusto.
This is one of the last things I need to figure out for the planning stage. I have a Griffin Scirocco radiator I am planning on tucking, which should work fine, but I want to keep A/C and was looking for a smaller condenser for mounting elsewhere in the bay. I'm not sure where I'll mount it yet, but without a size, it is difficult to determine where it will fit best. I was thinking instead of trying to feed air through the front bumper, I would just mount an electric fan to it and wire it to the compressor relay. Anytime the compressor kicks on, the fan should be pushing air through the condenser.
I will definitely be running custom AC lines, which with the right tools, are not that difficult to make. AC systems really aren't that complex, so as long as you run the lines correctly and have all the required components the lines can be routed wherever works.
2muchboost - any idea on the Sanden Part number? Or intended application vehicle?
Edit: Here's a smallish parallel flow from ColdHose - It is actually 12"x16" dimensions:
https://coldhose.com/parallel-flow-c...nser-1692.html
ADIDASilvias is offline   Reply With Quote
Old 04-27-2020, 05:34 PM   #13
2muchboost
Trader Rating: (33)
I lost the notes on the Sanden Unit but had this link saved in that folder. I would give them Sanden a shout with this part # and see if that would work.
https://www.dirtydingo.com/shop/mobi...oducts_id=1720
Old 04-27-2020, 05:46 PM   #14
silviaks2nr
silviaks2nr's Avatar
I have a build thread I'm doing a tucked radiator/condenser setup that may be of help. I spec'd out the radiator and condenser there and I'll be doing the custom lines soon.
'98 240sx 5spd
kouki 2jz t56 swap build
