Brakes Skyline R33 1993
I'm looking for rotors front and rear with pads for this car.
front 295 x 30mm rear 290 x 18 mm What is the Nissan has those rotor and pads? |
IIRC the 93 Skyline has those...jk lol just go to the parts store and tell them you need to measure some rotors then you will have part number...if not I'm sure a google search will show alternate options with slight possibility of needing to have them shipped to you
![]() Join Date: Jun 2003
Trader Rating: (130)
R33 GTS and GTST are 296x30
I haven't found any skyline that uses a 290x18 rear |
#5 | |
![]() Join Date: Jun 2007
R32 GT-R (non-VSpec) front rotors are 2mm wider IIRC, but still work perfectly with the R33 GTS/GTSt 4-pot calipers.
R32 GT-R and R33 rear rotors are the exact same as 300ZX (Z32). Pads: Z32 all the way around.
To illustrate, this is my setup.
Front: R32 GT-R (Non-Vspec) 296mmx32mm rotors, R33 GTSt calipers, Z32 pads: ![]() ![]() ^^This^^ image shows the 32mm width of the GT-R rotor does not interfere with the R33 caliper. Rear: R32 GT-R rotors, R33 GTSt calipers (same as R32/Z32), Z32 pads ![]() Hope this helps. Mike
5 LOCH -> 5 HUB
![]() Z32 26mm Aluminum (1990 NA 300ZX) 280mm x 26mm (5 Loch) Z32 30mm Aluminum (1990-1992.5 Turbo 300ZX und 1991-1992.5 NA 300ZX) 280mm x 30mm (5 Loch) Z32 30mm Eisen (1992.5-1996 Turbo und NA 300ZX) 280mm x 30mm (5 Loch) Infiniti J30 1990-1994 280mm x 22mm (5 Loch) Infiniti Q45 1990-1996 (G50) 280mm x 28mm (5 Loch) Nissan Sentra 2003~ V-Spec (B15 - Brembo) 305mm x 27mm (4 Loch) Skyline 1989-1993 GTR (R32) 296mm x 32mm (5 Loch) Skyline 1993-1994 GTR V-Spec (R32 - Brembo) 324mm x 30mm (5 Loch) Skyline GTS 1993-1998 (R33) 280mm x 26mm (5 Loch) Skyline 1993-1998 GSTS (R33) 296mm x 30mm (5 Loch) Skyline 1993-1998 GTR (R33 - Brembo) 324mm x 30mm (5 Loch) Skyline GT 1998-2002 (R34) 296mm x 30mm (5 Loch) Skyline 1998-2002 GTT (R34) 310mm x 30mm (5 Loch) Skyline 1998-2002 GTR (R34 - Brembo) 324mm x 30mm (5 Loch) 350Z 2003~ (Z33, non-track) 296mm x 24mm (5 Loch) 350Z 2003~ (Z33, Track) 324mm x 30mm (5 Loch) Hinterachse: Z32 (1990-1996 300ZX) R32 (GTS, GSTS, and GTR 1989 - 1993) R33 (GTS and GTST 1993-1998 ) R34 (GT, GTT 1998-2002) 297mm x 18mm (5 Loch) mit integrierter Handbremse in der Trommel S14 240SX Rears (1988-1998 S Chassis) 258mm x 9mm |
