Old 05-01-2016, 01:01 PM   #1
roninwon
roninwon's Avatar
roninwon is an unknown quantity at this point
Send a message via MSN to roninwon Send a message via Yahoo to roninwon
The everything cd009 swap thread.
With the ever growing popularity of the z33 swap option I thought that it was time for its own dedicated thread. This page will entail specifics on every available option for swapping in the trans. My build is ongoing so I will rely on other members to help build this page.
Adapters:
There are several on the market to choose from
Maverick motorsports
http://www.maverick-motorsports.com/...-adapter-plate
COST: $430
I personally own this plate and I can say the quality and precision is spot on
Collins
http://collinsadapters.com/index.php...ter-plate.html
COST: $350
Mazworx
http://www.mazworx.com/srvq-bellhousing.aspx
COST: $900
The price is high on this one but it doesn't require you to use an adapter plate. However you do need to cut your bell housing to use this. Keep that in mind if you have a warranty.
Autotech
http://www.autotechmotoring.com/prod...dapter-plates/
COST: $295
I thought JWT had an option but I can't find it. Their website feels encrypted sometimes.
Slave cylinder option:
Internal or external. My opinion external is the way to go with these transmissions due to the amount of negative reviews on the internal. From what I've read Nissan didn't quite fix the internal slave problem till the later model 370z's. Another downside is if your slave fails you'll need to pull the trans off just to correct the issue.
Clutch fork, carrier, bearing, pivot ball
I can't speak for other kits but the Maverick motorsports kit requires you to use the z33 clutch fork, extended pivot ball and clip. I bought the upgraded version from z1motorsports.
https://www.z1motorsports.com/trans-...it-p-5400.html
Will you need to use the sr20 carrier and throw out bearing.
Cross members.
Again there are a few options
COST: $100
Collins
http://collinsadapters.com/index.php...and-mount.html
COST: $175
Xcessive
http://www.driftmotion.com/N-S-VQ-TCM-S1-p/dm3301.htm
COST: $128
This kit allows you to use the z32 trans mount only.
Driveshaft.
Only option I'm aware of that you can buy directly from is shaft masters. They have an ABS and non ABS option.
http://shaftmasters.com/aldrni2419wi.html
COST: $398
Shifter modification.
Everyone who has looked into this swap know about the terrible shifter placement that requires cutting into the chassis. Well after a ton of research looking into Ive found 2 companies that are now building custom shifters for various application with the cd009.
First is Jason Farmer at CBF Performance. I've personally talked with him about his product and offered what solution would be best for my platform which is his rear mount set up. His products can be purchased for around high 200- mid 300.
Currently on sale for a group buy at $185
http://www.cbfperformance.net/store#...egory=19722030
https://youtu.be/mYsGvVwlySE
The other is SERIALNine. From the amount of info they put out it looks like they will only be releasing a mid mount set up which MIGHT bang against the body. They are currently in production and should be available late May. Heard the retail will be about $350 US. Will post link when available.
https://youtu.be/Z-0pZXw04r0
If there's anything missing or you just have questions just let me know.
Here's a link just for the transmission FSM
http://boredmder.com/FSMs/Nissan/350z/2003/MT.pdf
Torque chart on MT22
roninwon is offline   Reply With Quote
Old 05-01-2016, 05:15 PM   #2
rbs14kouki
rbs14kouki's Avatar
rbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to all
autotech motoring as a plate too (sr to vq and ka to vq)
i went with the mazworx kit since i plan on running a tripple plate on my set-up ... just a heads-up , the g37/z34 and g35/z33 dont have the same outside diameter input shaft bearing (g37 smaller vs 350z bigger) ... so mazworx is sending me a little centering ring for it to compensate for the samller bearing and for it to work 100%
AV FABRICATION
Built thread sr20vet s14
http://zilvia.net/f/showthread.php?t=535574
rbs14kouki is offline   Reply With Quote
Old 05-01-2016, 05:18 PM   #3
rbs14kouki
rbs14kouki's Avatar
Mazworx made a video to help out
https://www.youtube.com/watch?v=nkyRquTwNoE
on my set-up i tried cutting before the second ridge ... to limit the gap in between the bellhousing and the transmission . it doesnt work its to tight
you need to cut right after the second ridge for it to get my result .. in the mazworx instruction they say to cute 1/4 pass the second ridge but i dont realy like the result ...
it was cut with a grinder
ill be running an internal release bearing from Tilton .
https://tiltonracing.com/wp-content/...XXX-Series.pdf
AV FABRICATION
Old 05-01-2016, 05:22 PM   #4
roninwon
roninwon's Avatar
Fantastic addition to the thread.
Old 05-01-2016, 05:34 PM   #5
rbs14kouki
rbs14kouki's Avatar
shifter option ...
mazworx billet bracket ... with there kit you need to get the Stock shifter spring and reverse lock plate (nissan part num : 32822-cd00a and 32879-cd00a)
gktech is about to release this one ... im waiting for this one for my set-up
AV FABRICATION
Old 05-01-2016, 05:45 PM   #6
rbs14kouki
rbs14kouki's Avatar
Jim wolf tech kit
https://conceptzperformance.com/jim-...kit_p_3285.php
AV FABRICATION
Old 05-01-2016, 07:22 PM   #7
rawgarage
Banned from the Marketplace
Trader Rating: (75)
Feedback Score: 75 reviews
Serial nine shifter....
https://www.facebook.com/gerard.depe...7626303596674/
Old 05-01-2016, 07:38 PM   #8
roninwon
roninwon's Avatar
I wonder if the gktech one maintains the reverse lockout?
Old 05-01-2016, 07:53 PM   #9
roninwon
roninwon's Avatar
Just reading into the gktech and it will have reverse lockout. Still looking for a projected price though.
Old 05-01-2016, 08:08 PM   #10
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
In to see if anyone can perfect the shifter setup when mated to a JZ motor.
Sent from my iPhone
https://instagram.com/e_lemonation/: @e_lemonation
Old 05-01-2016, 08:21 PM   #11
roninwon
roninwon's Avatar
Sent from my iPhone
What's it going in?
Old 05-02-2016, 07:28 AM   #12
2muchboost
Trader Rating: (33)
2muchboost is an unknown quantity at this point
Feedback Score: 33 reviews
Fantastic info here. The CD009 related swap information was scattered throughout different resources. Not much to contribute but will be following this thread.
Cheers gents....finally something worth reading again.
2muchboost is offline   Reply With Quote
Old 05-02-2016, 07:54 AM   #13
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Originally Posted by roninwon View Post
What's it going in?
If i decided to go this route, it would be in my S14. All of the pics ive seen of these shifters have been with the z tranny mounted on an SR.
Old 05-02-2016, 08:15 AM   #14
roninwon
roninwon's Avatar
I know that Maverick motorsports has a ka to vq trans plate.
Old 05-02-2016, 08:22 AM   #15
roninwon
roninwon's Avatar
Old 05-02-2016, 08:38 AM   #16
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Finding the adapter for a JZ setup isn't the issue; the tranny is too long. As far as I know, no one has a guaranteed shifter solution for the JZ/CD combo that places the shifter in a stock location.
Sent from my iPhone
Old 05-02-2016, 08:46 AM   #17
Kylepaschke
Kylepaschke is an unknown quantity at this point
I personally went the Mazworx route as well
[/IMG]sneak peak of the shifter that Jason is making for me
Kylepaschke is offline   Reply With Quote
Old 05-02-2016, 08:47 AM   #18
Kylepaschke
Does anyone know what the best transmission fluid to run is??
OEM Nissan?
Torco?
Redline?
Old 05-02-2016, 08:54 AM   #19
roninwon
roninwon's Avatar
I used to have a 350z and when I redid the trans fluid I went with Motul. It made it a lot quieter.
Old 05-02-2016, 11:08 AM   #20
Jorgs_7
Jorgs_7's Avatar
Jorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really nice
Sub'd. Bout time someone made this thread.
Jorgs_7 is offline   Reply With Quote
Old 05-02-2016, 12:20 PM   #21
LuckyX2
LuckyX2's Avatar
LuckyX2 is an unknown quantity at this point
I'd expect the GKTech stuff to be competetively priced as with their other parts. Plus the exchange rate favors anyone buying in the US.
My S13 SR Street Mod Build
LuckyX2 is offline   Reply With Quote
Old 05-02-2016, 12:31 PM   #22
Black240Ct
Black240Ct will become famous soon enoughBlack240Ct will become famous soon enoughBlack240Ct will become famous soon enough
Send a message via AIM to Black240Ct
OEM Nissan?
Torco?
Redline?
I run redline light weight shock proof. replace it once a year with drifting.
Black240Ct is offline   Reply With Quote
Old 05-02-2016, 02:10 PM   #23
rbs14kouki
rbs14kouki's Avatar
Collins as a ka / rb plate as well . Autotech motoring just release is ka plate couple weeks ago .
I had the autotech one before going to mazwprx bellhousing ... i did the change because of clutch option ... with a plate style your limited to single plate clutch . On A multi plate clutch with those plate style your second disque doesnt have full spline engadment
AV FABRICATION
Old 05-02-2016, 02:18 PM   #24
roninwon
roninwon's Avatar
I dug a little deeper and found gktech is doing a group prebuy here soon starting at $175 😱. You'll need to send an email to [email protected]
Old 05-02-2016, 03:40 PM   #25
S-Verteen
S-Verteen is an unknown quantity at this point
Collins plate to ka requires a little trim at the bottom to clear the flywheel. I believe 14mm off the bell housing and a hole in the bell housing for the nose cone of the starter. the gk shifter requires no mods to the chassis. The driveshaft shop did my driveshaft. Also the locating pins are removed must be for the rb. and a custom dust shield was made to cover the bh.
S-Verteen is offline   Reply With Quote
Old 05-02-2016, 04:16 PM   #26
Juan@Fontananissan
Juan@Fontananissan has a spectacular aura aboutJuan@Fontananissan has a spectacular aura aboutJuan@Fontananissan has a spectacular aura aboutJuan@Fontananissan has a spectacular aura aboutJuan@Fontananissan has a spectacular aura aboutJuan@Fontananissan has a spectacular aura about
ATS & HKS Clutch kits use a center hub type clutch system on their twin disk. I'm using the ATS Twin disk with the Maverick adapter on my SR CD0009 setup works fine with full engagement.
Competition Engines & Dyno Tuning.
(951)708-1648 | [email protected]
Juan@Fontananissan is offline   Reply With Quote
Old 05-02-2016, 05:40 PM   #27
Joobie610
Joobie610's Avatar
Joobie610 is making a name for him/her selfJoobie610 is making a name for him/her self
I'm using a local kit for SR20 to z33 in Australia by Insane Drifters. They're on fb.
https://facebook.com/InsaneDrifters/
Paid AUD $2350.00 including shipping.
It came with:
- Adapter plate
- Bellhousing machining
- Test fit to ensure everything fit without further modification (no chassis mods)
- Shifter w/ Reverse Lockout
- Gearbox crossmember adapter plates (suit s15 gearbox crossmember and factory mount)
- All required bolts/nuts/washers
- Braided clutch line to suit RHD s13 master to z33 slave
- Single piece tailshaft to suit abs housing
I haven't fit it to the car yet, but he uses the same setup in his ADGP s13 and his old man's daily s15. Looks the goods, comes out in factory location with no need to modify anything.
I believe he would be willing to sell components separately, I just couldn't say no to having it test fit before I coughed up dough.
Edit: I'm using the factory z33 throwout fork and pivot with a Nismo Super coppermix twin plate. I've been told that it will work - another customer has used it before I think.
Joobie610 is offline   Reply With Quote
Old 05-02-2016, 06:12 PM   #28
roninwon
roninwon's Avatar
Holy sheet nice setup. A bit heavy on that wallet though. I should look into their clutch line cause I also have a RHD.
Old 05-02-2016, 06:48 PM   #29
Joobie610
Joobie610's Avatar
Yeah, bit exxy, but when everything is made to order and test fit by a guy who does this and builds sr20 engines for a living, you know you're getting quality.
They will custom make the line for you to suit the application (I.e. Correct fittings and length for any master/slave combo).
Sent from my E6653 using Tapatalk
Old 05-02-2016, 07:07 PM   #30
roninwon
roninwon's Avatar
Gotta pay to play dawg! Thanks for the heads up. I messaged them so I'll just have to wait.
