11-12-2010, 02:58 PM | #1 |
GT3071r/Haltech/DEFI gauge set/lots of S14/SR parts!
All parts located in Gainesvile, FL. I regularly visit Orlando and Tampa though, and can deliver the parts after a deposit has been made via PayPal.
Pictured: Brand new, never used Garrett GT3071r with polished compressor housing, 4" inlet - $1000 T3 or T4 topmount ramhorn manifold, braced runners and no cracks. Flange works for T3 or T4 turbos. 38mm wastegate. - $150 DEFI BF boost gauge, with sensor. reads in PSI. $150 DEFI BF EGT gauge, without sensor, reads in degF. $80 Full set of DEFi gauges with sensors, control unit, and seven 60mm gauge pod - Boost, EGT, Oil press, Oil temp, Water temp, Fuel press. All sensors are loomed and protected. With fiberglass molded gauge housing, $1000 Aftermarket Fog Lights, used - $20/pair Z32 MAF, $80 each ONE LEFT. ARP Rod Bolt kit - $40 Timing Light - $25 SR20 CAS - $100 SR20 OEM pulley set - $20 3" Test Pipe - $30 Not Pictured: Cobra ESD-9550 Radar Detector w/suction cups and harness - $40 S13 SR Exhaust cam - $20 Window motor - $20 S14 door handle - $20 S13 SR Alternator - $100 S14 ignition lock w/key, you will need to save the non-keyed half of the assembly, i cut mine to get it off. - $20 S14 ignition switch, uncut pigtail - $20 OEM SR20 HG, never used - $40 4x SR20DET Coilpacks - $50 S13 Speed Sensor - $35 Last edited by greenman100; 01-13-2011 at 05:28 PM.. |
12-24-2010, 03:17 PM | #4 |
Can i get more info on Haltech Platinum Sport 1000. Would it work on 95 Ka24de OBD1. Do i need any other senors to run this standalone and is this plug and play unit.
12-27-2010, 12:24 PM | #12 |
12-27-2010, 01:53 PM | #13 |
More pix of the gauges and the gauges mount in day light w'd be nice. also are you firm on the 1K$ or is't obo?
you will include the mount right?
'95 S14 Se With HKS's - BREMBO's - ES/SPL. |
01-08-2011, 11:08 AM | #14 |
01-08-2011, 01:25 PM | #16 | |
tyt, but don't forget
01-10-2011, 06:16 PM | #20 |
