Old 04-09-2019, 12:03 PM   #1
coolwhipdrift
coolwhipdrift is an unknown quantity at this point
1989 Nissan 240sx S13 Silvia LS1 Drift Car
https://sandiego.craigslist.org/nsd/...860408490.html
Runs great! Sounds amazing! 425hp
https://vimeo.com/album/5465304
NOT STREET LEGAL IN CA.
The original build of the car was featured in Super Street Magazine.
http://www.superstreetonline.com/fea...san-240sx-s13/
Original copy of the magazine comes with the car, although it's in pretty bad shape.
Car was professionally built at Togue Factory in Chicago.
-LQ9 6.0 iron block with 37k miles
-Comp Thumper Torque Cam
-Ported throttle body
-Walbro 255 fuel pump
-Champion radiator
-Stage 3 T56, less than 2500 miles. SSR 32 spline mainshaft, CTSV gearing, pads, forks, keys, etc. Will handle 1000rwtq
-Stage 2 competition clutch
-Competition 12lb flywheel
-Hurst short throw shifter
-Welded R200 diff with 4.09 FD
-300zx turbo brakes, 4 calipers in rear
-Nameless hydro E-brake
-Holly engine mounts
-New subframe with welding bracing for extra support
-Stance GR coilovers
-Stance upper/lower control arms
-New tie rods, ball joints, and bearings
-Cusco front strut bar
-Nagisa front fender braces
-Aluminum subframe bushings
-Tube front
-Sparco steering wheel
-Sparco racing seat - drivers side only
-Stock passenger seat
-4 point seatbelt harnesses
-Version Select sideskirts/bumper
-Enkei RPF1's, 9.5in front, 10.5in rear (rough) with new tires
-Set of 4 extra wheels blue (rough) with new tires
-Trunk mounted fuel cell
-Trunk mounted battery
-Villains angle kit
Speedo does not work
Currently no roll cage
Also available:
2018 Innovative Car Trailer 83" x 16'
Douglas Fir wood deck, triple reinforced tongue, one-piece wiring harness, under-chassis 5' ramps with storage, 3500# axles with EZ-lube hubs, electric brakes on rear axle, boxed sealed LED taillights, 15" radial tires, mounted spare, LED running lights.
$2500
coolwhipdrift is offline   Reply With Quote
Old 05-15-2019, 05:56 PM   #2
Godzilla35
Godzilla35 is an unknown quantity at this point
CL ad is expired... sold?
Godzilla35 is offline   Reply With Quote
Old 05-17-2019, 03:05 PM   #3
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
pix of trailer?
