02-16-2009, 03:48 PM | #32 |
Nah, not expensive at all. What state do you live in? I recommend going to a shop that has a dyno and seeing what they charge. When they strap that car on, you can play with the gas and see where the noise is coming from, since the dyno will simulate load. It has to spin a giant cylinder after all. Think about that for a sec. Since you can't have anyone sitting in your engine bay while you are driving down the street...
For example, RT Tuning in PA charges $60 for 3 runs w their wideband O2. So how much can a shop charge for diagnosing a noise? Only take a few minutes. If you're a customer at a shop, most will do it free. None should charge you more than $50 for playing with the throttle on a dyno.. You could also put the ass in the air, car in gear, and play with it while it's in the air, but I really don'y recommend it. -Bart |
02-20-2009, 04:03 PM | #33 |
Okay so I did some diagnosing, and I found the source of the noise, I listened to it with a stethoscope and its definitely coming from the circled area.
So what can it be? I was thinking maybe the chain is hitting the chain guide? Anyone have any idea? and how would I go about fixing this. Thanks for any input you have. |
02-21-2009, 11:02 AM | #37 |
AFC #1
Safe to remove the one on the top between the cams. If the chain hits the valve cover after this you need a new tensioner and possibly a timing chain job/kit.
02-21-2009, 11:34 AM | #38 | |
Thanks everyone for your help, ill be back with updates. |
02-21-2009, 03:02 PM | #40 |
thats what i meant my bad!
no no dont worry im not gonna take no tentioner off :P I was told by someone its not safe to remove the guide because it keep the chain from skipping? anyone can confirm this? |
02-22-2009, 07:30 PM | #42 | |
Thanks so much for the info, and I'll be back with updates. Cheers |
