Old 03-18-2019, 07:15 PM   #1
silicasilvia
silicasilvia is an unknown quantity at this point
SR s13 sr20det starting issue
i have a 1990 silvia with a s13 sr20det, and im having a issue where the car starts, and does the normal start up and then dies after about 2-3 seconds. It started with the revs bouncing between 500-1000 and it started up and ran fine after, then it died while putting it away in storage, but now does the normal start up and dies. I checked for vacuum leaks and replaced iacv. Im thinking tps now, but has anyone else had this issue or know a solution to it?
silicasilvia is offline   Reply With Quote
Old 03-19-2019, 07:41 AM   #2
jedi03
used to...i gave it a little gas to help it up like old carb vehicle...check timing, tps, iacv, compression, etc
Old 03-22-2019, 06:32 PM   #3
silicasilvia
Any anount of throttle automaticlly kills the car i wouldnt mind it if i could get it to stay running longer than 3 seconds
s13, sr20
