![]() Join Date: Oct 2009
Trader Rating: (38)
![]() Feedback Score: 38 reviews
Sr20det crank not spinning freely after build
What's up guys . Got a sr20det built last year by a shop. Engine ran fan before stock but decided to build to get to 450 to 500 reliably with a gtx3076r . Did pistons, rods , new all ARP hardware. The whole 9. Tried to get it going last week with a tuner etc . Did the proper break in procedures and that crank wont really budge. Spins maybe a 1/4 turn by hand and then just stops. . Engine ran for 10 seconds and shut off. Drained the oil and no shavings . Undid the trans , starter etc and still hard to turn by hand with a 2 foot breaker bar. So yanked the engine out and having another shop take a look at what's wrong . Is it possible for that engine to be complete crap?
I'd appreciate any feed back or similar related issues. Sent from my SM-N960U using Tapatalk |
#3 | |
Trader Rating: (38)
![]() Join Date: Nov 2005
Yep, sounds like the mains were too tight. If you're lucky it'll just require a polish on the crank and resetting the main clearance. If you're unlucky they did some wonky machining and the engine will need a line hone and a new crank.
#5 | |
Sent from my SM-G965W using Tapatalk |
#6 |
![]() Join Date: Jun 2003
Trader Rating: (130)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 130 reviews
Pull the spark plugs and make sure the cylinders aren’t full of fuel.
I bought a car that the previous owner said wouldn’t run, turns out he replaced the injectors but there was an old oring stuck in the fuel rail causing raw fuel to fill cyl 2. It would crank about 2 revolutions then stop dead. |
#7 | |
![]() Join Date: Nov 2010
#8 |
if nothing in cylinders, check with bore o scope that nothing has contacted piston and see if spins freely, if doesn't check timing too before pulling motor apart
#9 |
1) Either the main clearances are too tight (which is why you ALWAYS spin the crank by hand once you bolt up the mains and after every conrod install)
2) Piston to valve contact Confirm if they align honed when they rebuilt the engine if using stock main bolts. If using aftermarket make sure they align hone correctly and have them issue you the spec sheet before and after align hone. If they did it incorrectly, the engine will have to be torn down. And make sure they also give you always the measurement bearing clearances and which bearings they used (mains and rod bearings) |
#10 |
![]() Join Date: Jul 2008
Trader Rating: (32)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 32 reviews
is someone seriously recommending plastigauge? lol
crank bearing clearances could have possibly been too tight. tear it apart and if it only ran for 10 sec. your crank could be ok. Get a new shop to redo the whole bottom end. |
#11 | |
![]() Join Date: May 2019
But plastigauge is a very useful tool and many if not thousands of motors have been built using it and ran perfectly |
#13 |
imo plastigauge is a great tool to use to make sure someone didn't put the decimal in the wrong spot when trying to use a dial caliper.
i'm still amazed at how many people can't properly use one, but claim to be engine builders. ![]() |
#14 |
Nothing wrong with plastigauge for a DIY to double check.
However, youtube mechanics who have no idea how to use their $800 dial calipers need something to blame...... |
#15 |
Trader Rating: (38)
Ended up taking it to another shop so they can tear it down and check everything .I have a feeling he didnt line hone since they were Arp main studs and or tight clearances. Just found out hes known for leaving tight clearances through another customer smh.
#16 |
Trader Rating: (38)
Sooo look what I found guys . Head and cams are shot. Smh. Crank spins smoothly still after head is off. So it was the head all along
![]() ![]() ![]() ![]() ![]() ![]() Sent from my SM-N960U using Tapatalk |
#19 |
![]() Join Date: Jul 2005
you would notice something like that during installation
which means those parts went in looking fine which means they were ruined within that 10 second time frame which means they were installed without any oil (my guess) |
#20 | |
#21 | |
#22 |
I am leaning this direction. However, the photo with the cam cracked right at the cam gear seems like the shop installed the cam caps with a 500lb torque wrench as it looks like a fracture vs a fatigue (no oil) failure.
#23 |
JEEZUS FUCK.
Dude that sucks. Looks no oil pressure was getting to the head. Why the cam cracked I don’t know, but FUCK. |
#24 |
Possibility that the caps were over torqued or the cam shaft was bent. I had a shitty shop drop one of my cam shafts and bend it. Cam would install fine but tough to turn, ended up having to pay for a new set.
#26 | |
![]() Quote:
Also yeah I’ve never seen a cam bend. They crack. |
#27 |
Cams can certainly bend. The hardening on iron camshafts does make them brittle but as long as they are they will easily bend. The can chip or have a piece break off that is partially due to hardening and also partially due to the metal characteristics of iron. The hardening is also just case hardening, meaning roughly the outer .020" of their surface is much harder than the rest. They are not made of carbide...
#30 |
Trader Rating: (38)
Yea engine is getting completely overhauled fellas/ladies . Had shavings in the pan. Reached out to the original builder and he is dodging me. Had to buy a new head , get it machined and of course tear had the engine tore down to fully inspect any further damage smh. Would it be right or wrong to put the shop out on blast with these pictures I have to save someone else's engine in the future?
