Old 07-03-2022, 07:07 AM   #23761
skidmarks14
skidmarks14 is an unknown quantity at this point
Window regulator 95 240sx s14
Anyone know where to buy a passenger side window regulator and guide? Any pointers welcome, not being able to roll down or up my passenger side window is killing me.
skidmarks14 is offline   Reply With Quote
Old 07-03-2022, 08:32 PM   #23762
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
facebook groups, ebay, reddit 240sx community.
https://www.ebay.com/sch/i.html?_fro...lator&_sacat=0
Old 07-12-2022, 01:21 PM   #23763
Rustys14
Rustys14's Avatar
Rustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of light
Does anyone know the thread size/pitch for the firewall AC connections? I want to 3d print some caps instead of removing them to make things a bit easier if I decide to add AC back in the future, but don't have any way to measure the pitch currently.
Originally Posted by bossin240 View Post
I have a pretty badass neon.
Rustys14 is offline   Reply With Quote
Old 07-13-2022, 10:31 AM   #23764
AKADriver
AKADriver's Avatar
Is the second pin on the Z32/R32/S12/S14 Silvia/etc oil pressure sender a low pressure warning light switch? The wiring diagrams for the Z32 and S12 show it as NC but they don't have oil pressure warning lights, just gauges. The S14/S15/RNN14 with center gauge pack have both I think but not sure if the gauge pack disables the warning light.
Edit: yes, it is, just confirmed with the R32 GT-R factory service manual.
Old 07-13-2022, 11:31 AM   #23765
tuzzio
tuzzio's Avatar
If you can tell me what you need for measurements, I have a S13 HVAC system out of the car I may be able to help you with.
Old 07-13-2022, 02:34 PM   #23766
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Feedback Score: 18 reviews
Yes, on that unit one pin is a basic dummy light and the other is a variable pressure signal. On the S14 with the din gauge pod, both wires are used. One goes to the cluster for the stock light, the other goes to the gauge pod.
Old 07-16-2022, 03:52 AM   #23767
that_one_coupe
that_one_coupe's Avatar
that_one_coupe is on a distinguished road
not that i'm really RECOMMENDING it, but this exists.
(note that it has "kouki" marker lights instead of chuki)
https://www.extremedimensions.com/19...r-1-Piece.html
you wouldn't happen to know anyone that makes a version with the chuki signals would you?�� I emailed carbonetics about it because they sell with with the kouki signals as well but they weren't willing to make a chuki version. Worst comes to worst I'll settle for this one.
BTW this was the most recent link I've run into lately: http://www.ktm23.com/flow_gallery/ga...348-80849.html
that_one_coupe is offline   Reply With Quote
Old 07-16-2022, 11:49 PM   #23768
Lehr98
Lehr98 is a well-known jackass
Hey, I have a 5 speed swapped 89 240sx with a SOHC that idles at 750rpm but I can't get the ignition timing past 10* when I unplug the tps. I've tried restabbing my distributor and making sure I'm at tdc by lining up the timing mark on compression stroke and checking the cam marks. Its a CA model that I'm trying to pass smog with and currently have no ecu codes. I've been following the manual to a T and starting to pull my hair out at this point. Any help would be appreciated, thanks!
Lehr98 is offline   Reply With Quote
Old 08-15-2022, 07:29 AM   #23769
Hdezauche
Hdezauche is an unknown quantity at this point
Clutch Pedal Pin and bushing
Trying to finish up the 5speed swap on my kouki. Found the previous owner did not leave the clutch pedal pin and bushing, that attach it to the rod for the master cylinder, in the car. Anyone have a pair or know where I can get pair? If you have a s14 pedal that has them im not opposed to buying that either.
Hdezauche is offline   Reply With Quote
Old 08-15-2022, 08:31 AM   #23770
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
https://www.nissanparts.cc/oem-parts...ore-46123h850a
Old 08-16-2022, 02:48 PM   #23771
AKADriver
AKADriver's Avatar
Almost every manual transmission Nissan made since 1979 uses the same pin FYI.
Old 08-16-2022, 03:12 PM   #23772
AKADriver
AKADriver's Avatar
On the SOHC you have that distributor/oil pump driveshaft thing that stabs in from the bottom. It's REAL easy to get this one tooth off. If you can, get someone to look down from the top to make sure it's not turning as it goes in.
Old 08-16-2022, 03:27 PM   #23773
nick_d_240sx
nick_d_240sx's Avatar
nick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymore
Also do not stab the distributor and then try to stab the oil pump. I did this when I was young and dumb and destroyed my distributor.
Set engine to TDC, stab oil pump with marks lined up and then the distributor.
S13
nick_d_240sx is offline   Reply With Quote
Old 08-16-2022, 05:20 PM   #23774
Lehr98
I just ordered a 10 pack of oil pump gaskets, the oil pump spindle key looks like its more towards 12oclock instead of 11oclock.
Old 08-31-2022, 03:16 PM   #23775
1on1
1on1's Avatar
1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all
SR
Anyone know the hose size of the coolant line that connects from under the intake manifold > back of the engine > stops at the oil drain to the block on a s13 sr20det?
Not sure if it's a 1/4 or 3/8 ID coolant hose.
instagram
1on1 is offline   Reply With Quote
Old 09-03-2022, 01:41 PM   #23776
ZenkiKid
ZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud of
Is there any RECENT 5 lug vehicle which their spare tire would fit the s13 spare tire location and is actually usable on 5 lug s chassis?
ZenkiKid is offline   Reply With Quote
Old 09-07-2022, 02:17 PM   #23777
AKADriver
AKADriver's Avatar
Depends on your brakes. There was a recent thread I think in Tech Talk where someone was looking for a spare to clear big brakes in a Stagea and I pointed him to a company that makes large diameter alloy spares for cars like GT-Rs. But if you just have like Z32 or R32 brakes you should be able to use a 16" wheel. '02+ Altimas have a 16x4 steel spare with a high disc face and 135/80R16 that should fit in the well.
Some Quests (mid-2000s?) have an alloy spare the same size. Probably not as easy to find but cool looking and probably lighter. Altima Hybrids have it too.
'13+ Sentras have a 16" 5-lug spare with a slightly smaller tire (125/70), I think this is pretty much identical to the diameter of the S13/S14 spare. But I'm 95% sure the 135/80 should fit in the well since it's the same spec diameter as the stock 195/60R15, which fits, just not width-wise.
Old 09-13-2022, 12:01 PM   #23778
seaninc
seaninc is an unknown quantity at this point
Anyone know the length of S13 clutch pedal studs? I bought an R32 pedal set, but the studs are gone.
Pedals are RHD from an R32 and going in my Cefiro, if that matters.
seaninc is offline   Reply With Quote
Old 09-15-2022, 10:50 AM   #23779
LoSt180
LoSt180's Avatar
Trader Rating: (18)
S15 SR20DET - car sat for about a year and a half at a body shop getting the whole car repainted. Got the car back recently and on a cold start, or even after sitting for a few hours, it makes a really loud rattling sound. The sound fades after about 5 seconds, so I'm thinking it's related to oil pressure building up. I did change the oil but didn't help the noise.
What are typical things I should be looking at? So far my thoughts are timing chain tensioner, or valve lifters needing to be bled. The VTC cam was fairly new when I refreshed the engine about 2 years ago.
Details on engine: S15 SR, only internal mod is Tomei Poncams, everything else is stock, before installing in the car I refreshed all the gaskets with a Nissan gasket kit to avoid any leaks, etc.
Old 10-26-2022, 06:21 PM   #23780
Future240
Future Moderator
Future240's Avatar
SR20 bearings. I was watching a video of a guy rebuilding one (S13) and he said that the block has numbers on it that correspond to bearing sizes and you have to match the bearing sizes to each number listed on the block. Over the years I have seen many of you talk about building SR20's and have never seen this bearing thing mentioned.
video I am talking about starts at 3:40
https://www.youtube.com/watch?v=BdvnIPHNKM8
I guess my question is, is this correct? He literally says you cannot just buy a set of ACL race bearings and throw in their yet I see a lot of builds doing just that.
Originally Posted by ThatGuy
Old 10-26-2022, 06:22 PM   #23781
Future240
Future Moderator
Future240's Avatar
Old 10-27-2022, 09:30 AM   #23782
Agamemnon
Agamemnon's Avatar
He's correct. I just checked my S14 SR manual and the same procedure is listed in the FSM.
Old 11-02-2022, 11:44 AM   #23783
Snilssson
Snilssson is just really niceSnilssson is just really niceSnilssson is just really niceSnilssson is just really niceSnilssson is just really niceSnilssson is just really niceSnilssson is just really niceSnilssson is just really niceSnilssson is just really nice
My apologies if this has been asked far too much but what options do someone in Europe have of buying S13 Kouki aero and taillights that’s not thousands €€€€?
Cheapest taillights I can find for example are more than €1500.. Pretty steep for some lights
Snilssson is offline   Reply With Quote
Old 11-03-2022, 09:56 AM   #23784
Agamemnon
Agamemnon's Avatar
Originally Posted by Snilssson View Post
My apologies if this has been asked far too much but what options do someone in Europe have of buying S13 Kouki aero and taillights that?s not thousands ?????
Cheapest taillights I can find for example are more than ?1500.. Pretty steep for some lights
Nissanparts.cc has them on sale for $999. I know they ship internationally too. Give them a shot. We just have to go forward knowing that restoration of a 30+ year old Japanese car is expensive.
Old 11-03-2022, 10:24 AM   #23785
AKADriver
AKADriver's Avatar
Probably cost about the same but MIGHT have cheaper shipping ordering from nengun or amayama since it'll be direct JP->SE (Amayama also ships some stuff from UAE).
Old 11-03-2022, 12:52 PM   #23786
Snilssson
Still $1500++ to get them here unfortunately. Guess you are right Thanks though, haven't seen that site before.
I'll check it out, thanks!
Old 11-04-2022, 08:03 AM   #23787
Future240
Future Moderator
Future240's Avatar
I forget, which S14 SR cams retain VCT?
Those with 264's cams, how is driveability, idle?
Old 11-04-2022, 08:03 AM   #23788
Future240
Future Moderator
Future240's Avatar
Old 11-05-2022, 01:02 PM   #23789
burnsauto
burnsauto's Avatar
Cheapest, but not cheap, is just buying straight from Japan. I used an proxy service to purchase my kouki aero parts off Yahoo Auction Japan. There are a few different companies that do it, but I've always used Buyee. They ship to most places in the world, and their fees are pretty cheap. Aero will be expensive to ship, so just plan ahead. No matter what you do, it will wind up costing you 1000's for OEM.
Old 11-06-2022, 09:45 PM   #23790
Future240
Future Moderator
Future240's Avatar
Huh. Never heard of Buyee till now. Been looking through it. I am really wondering what kind of shipping one would pay for an engine.
Also am I tripping or is this a NEW SR20?
https://buyee.jp/item/yahoo/auction/...search_suggest
