Old 10-23-2020, 05:25 PM   #23491
shobotan
shobotan's Avatar
shobotan is an unknown quantity at this point
Is the interior floor carpet the same fit for s14 and S13 hatch?
MECHANICAL INJURNEER
shobotan is offline   Reply With Quote
Old 10-23-2020, 07:11 PM   #23492
S14rebuild
Not even close
Old 10-24-2020, 03:34 PM   #23493
coupesallday!
coupesallday!'s Avatar
Trader Rating: (18)
coupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the rough
Feedback Score: 18 reviews
Send a message via MSN to coupesallday!
Figured it out........
Throw some glitter flake and crazy glue in there.
coupesallday! is offline   Reply With Quote
Old 10-24-2020, 04:00 PM   #23494
coupesallday!
Trader Rating: (18)
Double post.....
Old 10-25-2020, 12:56 PM   #23495
Agamemnon
Agamemnon's Avatar
Originally Posted by Future240 View Post
It is listed weird. A distributor on eBay actually showed me his distribution list and it lists the dryer I bought for the 97?s. Though clearly not.
I doubt I would be able to drill it right. Anyone got the correct drier? 97 de factory manual w/sunroof
The correct OEM 97-98 A/C drier part #92131-6P160
I found the website that also supplies Rockauto.
https://www.uacparts.com/legacy/Sear...rs-NISSAN.html
Hopefully the pics are accurate so you can see which incorrect part you keep getting.
Old 10-26-2020, 04:01 PM   #23496
TheRealSy90
TheRealSy90's Avatar
Originally Posted by S14rebuild View Post
Not even close
Uh s14 carpet fits decently in s13 i've done it before.
Such a good signature.
Old 10-26-2020, 06:22 PM   #23497
S14rebuild
S13 wont fit s14...its to small on the edges....
Unless u want a shitty looking interior..
Old 10-27-2020, 05:56 AM   #23498
Rivey123
Rivey123 is an unknown quantity at this point
So does anyone know where to find the actual connector to the brake fluid reservoir sensor mines melted and I cant seem to find it (s13)
Rivey123 is offline   Reply With Quote
Old 10-27-2020, 07:11 AM   #23499
Future240
Future Moderator
Future240's Avatar
Dude thanks a bunch!!!
Originally Posted by ThatGuy
Old 10-27-2020, 10:58 AM   #23500
burnsauto
burnsauto's Avatar
just to clear it up, are you looking for where the pigtail exists on the chassis harness, or are you looking for a replacement pigtail..?
Old 10-27-2020, 12:02 PM   #23501
Rivey123
I'm looking for a replacement
Old 10-27-2020, 02:25 PM   #23502
burnsauto
burnsauto's Avatar
head over to www.wiringspecialties.com
Here's there connector selection , https://www.wiringspecialties.com/chco1.html
If they don't have it listed, you can always send them a message, they may be able to help you out.
Old 10-27-2020, 05:54 PM   #23503
Pacman
Pacman's Avatar
Pacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura about
Do 2008-2015 STi rear Brembos fit with an adaptor?
Pacman is offline   Reply With Quote
Old 11-01-2020, 09:54 AM   #23504
afishysilvia
afishysilvia's Avatar
Trader Rating: (31)
afishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfection
Feedback Score: 31 reviews
Does anyone know of a aftermarket hub that allows the s14 to retain clock spring/horn? I want something to bolt my quick release too, not a direct mount huh like boss. Works bell? Circuit sports?
Dont be a pussy...Leave your name
afishysilvia is offline   Reply With Quote
Old 11-01-2020, 11:11 AM   #23505
Agamemnon
Agamemnon's Avatar
HKB boss kit.
Old 11-01-2020, 12:32 PM   #23506
Xaser
Xaser is an unknown quantity at this point
Hi, i have a electrical issue, and need the wiring.
I saw is a S13 Full HD version ( huge pdf) with all connection and stuff, but is a old links and all downs
I have registered in 6 webs and no one have i ( damn clickbait)
Anyone perhaps have it?
Xaser is offline   Reply With Quote
Old 11-01-2020, 12:36 PM   #23507
Xaser
like this but in pdf or good res.
Old 11-04-2020, 05:30 PM   #23508
DJTTon
DJTTon's Avatar
DJTTon is on the path to ruinDJTTon is on the path to ruin
Hi gang,
Ive been troubleshooting an intermittent misfire issue on my S14 SR, and wanted to ask for some guidance. The issue is on cylinder 3 and I have determined the coilpack, spark plug and injector to be fine by swapping components between cylinders.
One additional check Ill be performing tmrw is visually verifying spark by taking the spark plug out and grounding it while cranking with no fuel pump.
Whats interesting is that when I crank the engine to start the SR runs on all 4 cylinders and after a couple seconds you can hear the cylinder drop out, and once in a while itll come back.
IF there is spark on that cylinder, could it be possible that something is wrong with cylinder 3 valvetrain components like rocker or shims or guide or lifter? If so, what could it be?
Skurr Skurr
DJTTon is offline   Reply With Quote
Old 11-04-2020, 10:45 PM   #23509
inopsey
Originally Posted by DJTTon View Post
Hi gang,
first check compression
Old 11-05-2020, 05:47 AM   #23510
DJTTon
DJTTon's Avatar
@inopsey I forgot to mention that was the first thing I did. Tested all cylinders 3 times, and they all held up at 120 across. This hasn't changed since I last tested a year ago. Thanks for bringing that up
Sent from my SM-G950U using Tapatalk
Skurr Skurr
Old 11-05-2020, 07:53 AM   #23511
inopsey
did you upgrade to z33 coils and bypass the oem system or use the OEM/ISR igniter? how close were the compression numbers across all cylinders?
Old 11-05-2020, 08:01 AM   #23512
inopsey
................ double
Old 11-05-2020, 08:19 AM   #23513
DJTTon
DJTTon's Avatar
Im still using the OEM igniter setup, if I determine the spark system crapped out Ill upgrade it with Z33 coils. Compression is 120 across, within 1-2 psi of each other.
Skurr Skurr
Old 11-05-2020, 04:52 PM   #23514
S14rebuild
Pull valve cover.....check for cracked valve springs...
Old 11-05-2020, 05:28 PM   #23515
DJTTon
DJTTon's Avatar
Spark checked out fine today, but Im down to the last wire here other than possibly a busted ignitor.
Pulling the cover Saturday and gonna poke around cylinder 3
Skurr Skurr
Old 11-05-2020, 05:42 PM   #23516
mechanicalmoron
mechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nice
Hi gang,
How do you know it's on 3?
mechanicalmoron is offline   Reply With Quote
Old 11-05-2020, 06:03 PM   #23517
S14rebuild
Username fits here
Old 11-05-2020, 07:06 PM   #23518
mechanicalmoron
Username fits here
Did he say? I must have missed it.
Or is there something wrong with inquiring about the source and content of the diagnostic data? That's usually a good direction when you want to diagnose something.
Old 11-05-2020, 08:02 PM   #23519
DJTTon
DJTTon's Avatar
I swapped coil packs and spark plugs between cylinders 2 and 3, replaced injector 3 with another flow-tested one with new o-rings, and problem stayed at 3. Id say normal process of elimination
Skurr Skurr
Old 11-05-2020, 08:21 PM   #23520
mechanicalmoron
I'm asking how you know it's three, not what you did to move it.
