Old 11-07-2011, 01:53 PM   #8461
Origin
Origin is an unknown quantity at this point
Fixed transmission problem (kinda), but now I forget which coolant hose goes into the heater core and which on the return is. Which one is which? I'm thinking the one that comes out of the block goes to the bottom hose. And the upper hose goes to return. Can someone verify this?
Origin is offline   Reply With Quote
Old 11-07-2011, 04:41 PM   #8462
igreek
igreek's Avatar
igreek is an unknown quantity at this point
SR20DET cutting out at boost, possibly bad MAF?
I've finished my S13 SR20 swap and I'm having problems. As I described in this thread, it breaks up when it gets into boost. Bought new plugs, gapped them at 0.28, adjusted TPS, did a boost leak test and didn't find anything. Plugged out coilpacks, one by one and engine bogs a bit with each one. Plugged out injectors one by one and does the same thing. So, those seem to be fine. Otherwise, double checked everything else.
What is making me think that it's the MAF is how it reacts when I mess with it. If I unplug it, it'll bog down for a second but then build up and have a better idle then when it's plugged in; plugged in it revs, but cuts out when it hits boost, and plugged out, it hits that normal no MAF wall. Also, when it's plugged in vacuum is at 18-19 and 22-23 when plugged out. Doesn't something seem strange there? Decided to pull ECU codes and I'm getting 12; which I'm reading is the MAF. Does all this point to a bad or going bad maf?
It works fine WOT, until it hits boost and then everything cuts out. Could it be that the MAF is going bad and it messes up during boost? I'm pretty much stuck at this point. Do you guys think it could be the MAF?
igreek is offline   Reply With Quote
Old 11-07-2011, 06:28 PM   #8463
1on1
1on1's Avatar
1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all
Has anyone purchased ChaserAero's s14 Zenki hood + rear over fenders? I requested for photos, but he does not have any photos with them installed.
instagram
1on1 is offline   Reply With Quote
Old 11-07-2011, 08:15 PM   #8464
oligator20
oligator20 is an unknown quantity at this point
Another question that sounds more like it wants opinion.
You want the lowest?
You want the cheapest?
You prefer side/bottom mount?
You want the brand that matches your seat?
You want someones opinion on what they think is best?
Come on people you gotta work with us with these questions.
I need the lowest position as possible. I dont see no answer on any forum or google... Some guys say they go low and other say they hit the ajustement rod. And yes I want my bucket to go side mount because it can go more lower... Any answer will be apreciate.
oligator20 is offline   Reply With Quote
Old 11-07-2011, 08:46 PM   #8465
ZenKi_373
ZenKi_373's Avatar
ZenKi_373 is an unknown quantity at this point
where can i find that s13 rear wing that looks like the 180sx wing but oversized?
ZenKi_373 is offline   Reply With Quote
Old 11-07-2011, 08:53 PM   #8466
WERDdabuilder
WERDdabuilder's Avatar
if so..
http://zilvia.net/f/interior-exterio...nly-1-iir.html
When the power of love overcomes the love of power, the world will know peace
Old 11-07-2011, 08:55 PM   #8467
ZenKi_373
ZenKi_373's Avatar
Originally Posted by WERDdabuilder View Post
i love you no homo
Old 11-08-2011, 09:15 AM   #8468
Origin
Originally Posted by Origin View Post
I forget which coolant hose goes into the heater core and which one the return is. Which one is which? I'm thinking the one that comes out of the block goes to the bottom hose. And the upper hose goes to return. Can someone verify this?
After looking at it, it looks like the coolant that goes out of the block goes to the upper heater core hose because that upper hose can't reach the return hose under the manifold. Is this right?
Old 11-08-2011, 10:40 AM   #8469
proxx
proxx is an unknown quantity at this point
is there anywhere that sells a stock exhaust id sized test pipe, or am I being retarded?
proxx is offline   Reply With Quote
Old 11-08-2011, 02:48 PM   #8470
1jzjoey
1jzjoey's Avatar
1jzjoey is an unknown quantity at this point
anyone know what this is called? or where to get one?
1jzjoey is offline   Reply With Quote
Old 11-08-2011, 04:28 PM   #8471
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
Originally Posted by azsr20det View Post
this is going to sound stupid as fuck,
but i just disassembled my extra s13 rear subframe/ suspension.
now i have the axle/axle housing/ hub/ lower control arm still together.
i want them apart
HOW THE HELL DO I GET THIS DAMN AXLE NUT OFF?!??
the axle keeps spinning and i obviously cant break it loose with the pos spinning,
i tried to get crafty and bolt my fender roller to it so i could use my legs/ weight to hold it and my upper body with a breaker bar but no luck.
any ideas? i dgaf about everything except the axle housing as id like to cut it for a dual caliper bracker, powdercoat it, replace the bushings, get new axles and components and 5 lug hubs to go with the other new suspendion parts.
ideas? im super frusterated right now, almost to the point of saying fuck it and just ordering some from a sslvage yard.
just seems like a waste because my dumbass couldnt get the perfect ones i got free from the 20 yr old bullshit
at this point only an impact gun will work
take it to a shop if you don't have one on hand
google '180sx bumper guard'
Old 11-08-2011, 04:42 PM   #8472
Irresistible
Irresistible's Avatar
Irresistible is an unknown quantity at this point
Bride or Nagisa/Nams. I assume you're talking about seat rails.
326 Power wing. Not sure where to find them new exactly.
Check eBay. I bought my 3" test pipe there and it's good quality stainless steel. There might be something stock sized on there.
GLEAM//★☆Street Dancer☆★
IG: streetdncr // tumblr: steve-strtdncr
Irresistible is offline   Reply With Quote
Old 11-08-2011, 07:21 PM   #8473
89clubk
89clubk's Avatar
89clubk is an unknown quantity at this point
This may be a dumb question, but will a 1990 300zx starter work on my ka24e?
89clubk is offline   Reply With Quote
Old 11-08-2011, 07:29 PM   #8474
dontxploitme
dontxploitme's Avatar
dontxploitme is an unknown quantity at this point
is there a write up somewhere on how to make these fogs? i don't wanna mess up my grills lol
dontxploitme is offline   Reply With Quote
Old 11-08-2011, 07:32 PM   #8475
chiboy002
chiboy002 is an unknown quantity at this point
To echo Irresistible,
Bride FG and Nagisa Double locking rails are the only rails aside from custom work that will go the lowest.
All other ones have the under-seat style slider locks which, yes, do his the seat.
Old 11-08-2011, 08:17 PM   #8476
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
godrifttoday is an unknown quantity at this point
Feedback Score: 82 reviews
What to get. Budget enough for kw but nothing else
Kw clubsport coils $2630
Or
Fortune auto coils and driftwork front knuckle and pbm rear knuckle
$2200 or so
NEED Bolt kits for your car?
http://i48.tinypic.com/6gx5e0.jpg
godrifttoday is offline   Reply With Quote
Old 11-08-2011, 08:38 PM   #8477
Irresistible
Originally Posted by dontxploitme View Post
http://i99.photobucket.com/albums/l292/willbreakforrice/frontend1.jpg
Kouki fogs. Just gotta cut out the right size I guess in the little grille things.
Or
$2200 or so
I'd go with the latter. Then get whatever other links/bushings I need with the saved $430.
Old 11-08-2011, 08:39 PM   #8478
1jzjoey
1jzjoey's Avatar
just drill into your plastic covers and put them in.
Old 11-09-2011, 12:16 AM   #8479
rat240
Trader Rating: (87)
Feedback Score: 87 reviews
Has any one used an auto zone slave cylinder for the 240
I need to replace my blown one
Old 11-09-2011, 12:26 AM   #8480
Edwin562
Edwin562's Avatar
Idk if they come from the same mfg, im using one from NAPA. $37 if i remember... I rather use NAPA products over autozone. just my .02 cents
Old 11-09-2011, 12:39 AM   #8481
Drunken Drift Monkey
Drunken Drift Monkey is an unknown quantity at this point
I tried a search, but came up short.
Is there any DIY on how to install HID's for an S14 Kouki? I know it's pretty simple, but I was just wondering.
Drunken Drift Monkey is offline   Reply With Quote
Old 11-09-2011, 09:23 AM   #8482
ma.jomaa
ma.jomaa's Avatar
ma.jomaa is an unknown quantity at this point
Ka24e Maf Wiring
I'm trying to wire up a ka24e Maf to my sr20, Any body with Info about that is greatly appreciated.
P.S The wire colors on the KA24e pigtail do not match the car wires.
Please help.
ma.jomaa is offline   Reply With Quote
Old 11-09-2011, 09:24 AM   #8483
BlackZenkiS14
BlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond repute
Send a message via AIM to BlackZenkiS14
If I am adding an AFPR, but dont have a fitting, can I run it in line with my OEM FPR, because I am increasing fuel pressure?
-Kyle
BlackZenkiS14 is offline   Reply With Quote
Old 11-09-2011, 09:42 AM   #8484
bova17
bova17's Avatar
bova17 is an unknown quantity at this point
Here you go
bova17 is offline   Reply With Quote
Old 11-09-2011, 09:50 AM   #8485
killer skittle
killer skittle is an unknown quantity at this point
That was pointless seeing as tho he doesn't have that wiring harness....durr
killer skittle is offline   Reply With Quote
Old 11-09-2011, 01:17 PM   #8486
Wake
Wake's Avatar
What are you talking about? thats a HID kit.
S.P.P.S. Member #00
**CoUpe LOve** Member #00
Old 11-09-2011, 02:55 PM   #8487
Irresistible
Order the HID kit, install. If you can't figure it out you have a problem. Every plug only has one plug it matches up to.
Old 11-09-2011, 03:31 PM   #8488
chiboy002
this
an autozone employee told me that he never shops there because even with his employee discount (~25%) its still priced higher than other places.
Napa pricing is always pretty low and quality is usually great. Napa oil is made by the same company that makes the Valvoline oils, except Valvoline uses different specs.
Old 11-09-2011, 05:37 PM   #8489
dontxploitme
i'm using the duralast slave and master. the slave works perfectly fine and i'm pretty sure it's cheaper than $37. but the master is crap. catching point is practically in my knee after hours of adjustments
Old 11-09-2011, 06:31 PM   #8490
machuca212
machuca212 is an unknown quantity at this point
NEED OPINIONS!
whats the best way to relocate the wiring harness in the wheel well on a s13?
just started to rub the wires about to rub right through a couple of them. could you possibly post a link for a how to as well. thanks
machuca212 is offline   Reply With Quote
