Old 09-04-2008, 10:09 PM   #1
theianmcdougall
theianmcdougall's Avatar
theianmcdougall is an unknown quantity at this point
is it possible for the sr20det ecu to go in safe mode?
i have a red top sr20det swapped in a s13
the motor is pretty much stock except for a walbro 225 and fmic
kinda wierd question but im just wondering?
its just not running good
its fuel cutting and bogging out if i get on it or try and rev it past 3k
and its running super rich
already checked the MAF
theianmcdougall is offline   Reply With Quote
Old 09-04-2008, 10:19 PM   #2
flip3d
flip3d's Avatar
flip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond repute
Send a message via AIM to flip3d
Does the pope shit in the woods?
Check coolant temp sensor. There should be two. The two wire sensor on the left is the one you want.
flip3d is offline   Reply With Quote
Old 09-05-2008, 10:03 AM   #3
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
pull the codes from the ECU, sounds like knock sensor..
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 09-05-2008, 10:54 AM   #4
redclaw05
redclaw05's Avatar
redclaw05 is a glorious beacon of lightredclaw05 is a glorious beacon of lightredclaw05 is a glorious beacon of lightredclaw05 is a glorious beacon of lightredclaw05 is a glorious beacon of lightredclaw05 is a glorious beacon of lightredclaw05 is a glorious beacon of lightredclaw05 is a glorious beacon of lightredclaw05 is a glorious beacon of lightredclaw05 is a glorious beacon of lightredclaw05 is a glorious beacon of light
Send a message via AIM to redclaw05
ive gone to safe mode on my sr20det s14......basically wont rev past like 3k......all you gotta do for me is turn off the car and return it off.....but i usually let it cool down and sit for 10 minutes.
since you are running rich how are you using for fuel management?
and what else are your mods
stock injectors? 370cc?
stock maf?
everyone says stock sr20....but theres diff definitions for it.
1995 S14 NonSunroof.
redclaw05 is offline   Reply With Quote
Old 09-05-2008, 11:51 AM   #5
steve shadows
steve shadows's Avatar
Sounds like classic MAF wiring to me....
Like Me on FaceBook !
Old 09-05-2008, 12:32 PM   #6
theianmcdougall
yea, stock injectors, stock regulator, stock MAF
and no its not the maf wiring, ive checked that like 3 times
and even if the wiring was messed up the car wouldnt run at all
Old 09-05-2008, 01:36 PM   #7
SHIFT_*grind*
SHIFT_*grind*'s Avatar
SHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfection
Check your IC pipes. Are you sure one of them didn't just pop off? Because that will cause exactly the problems you're having. Black smoke, too?
My seller review thread
SHIFT_*grind* is offline   Reply With Quote
Old 09-05-2008, 02:44 PM   #8
theianmcdougall
its not that because sometimes if i get it past 3 grand in 1st gear and get on it, it will get full boost and pull all the way, but then when i shift into second it bogs out and get nasty fuel cut
Old 09-05-2008, 02:46 PM   #9
theianmcdougall
but yea black smoke and lots of backfiring
Old 09-05-2008, 07:13 PM   #10
HalveBlue
HalveBlue's Avatar
HalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond repute
Could be lots of things.
Does this happen intermittently or all the time?
Check timing yet?
HalveBlue is offline   Reply With Quote
Old 09-05-2008, 09:33 PM   #11
theianmcdougall
oh i kno
pretty much all the time
yea checked the timing, the motor is stock and the timing was never messed with anyways
Old 09-06-2008, 05:52 AM   #12
HalveBlue
HalveBlue's Avatar
STEP 1: Check codes - if you haven't already.
The shit thing about bogging issues is that it's due to something fucking your air/fuel ratio, which, unfortunately, means it could be a lot of different things.
Old 09-06-2008, 08:03 AM   #13
sr20drifter
sr20drifter's Avatar
sr20drifter is an unknown quantity at this point
I've had similiar problems with my s13 and my roomates b13 bluebird swap. I'd guess temp sensor like stated above or your o2 sensor. good luck with figuring it out. also check all your intercooler couplers. one could have a small tear.
sr20drifter is offline   Reply With Quote
