07-09-2013, 02:50 PM | #1 |
Hid kit conversion.. Any issues?
Anyone running hids on thier s13?
are you having any issues with your alternator? what kits are you running... been blowing through alternators im thinking its the hid kit im running...so i have taken it off... im now skepitcal on putting another kit on.. any imput will be great thanks |
07-09-2013, 06:50 PM | #2 |
I do, and have no alternator problems, also oem or came with swap aprx 8yr old alternator.
I bought it from a vendor on here, i believe it was Sonic Motor, brand not sure.
07-20-2013, 01:54 AM | #8 |
Super Moderator
Trader Rating: (73)
Feedback Score: 73 reviews
I am selling a Nissan Quest alternator. $85 shipped and it's yours. I think I can fit it in a big flat rate box.
Best way to do business with me? Make your best offer FIRST. |
07-21-2013, 11:13 AM | #14 |
I got the quest alternator to fit my kade w/ minimal bracket modification... used a drill bit to widen the slot a bit towards in the engine side. Slides like factory.
07-23-2013, 02:30 AM | #15 |
Check your positive lines come off the battery and make sure they are not shorting out at all and all grounds are good. I had a similar problem killing batteries and alternators and every time I had them test it it was ok. I have a 95 so not to sure how similar the wiring is but my bet is they're close in those respects.
07-25-2013, 05:48 AM | #16 | |
what exactly did you do to fix your problem? was your positive line shortening out? is there a relay i should check? im not sure but i tink the hid kit i had on could of been the culprit... i have since taken it off but im still only reading 12.5-12.6 voltage while the car is on... |
07-25-2013, 05:49 AM | #17 |
07-29-2013, 07:48 PM | #21 |
Yea one of my positive lines had a bad connection, heated up because of the resistance then melted the plastic connector and totally lost power. All my dash lights turn, signals and brake lights went out and the car wouldn't go higher than 3rd gear. Oh and the ac didn't work. Now it's all fixed ill try and get a pic.
08-08-2013, 05:58 PM | #22 |
I had a relay to the hids I was running...took those off because I thought they were the cause but now I'm getting the same issue...and it's seems like instant..and my battery meter never pass 12.7....
08-08-2013, 06:01 PM | #23 |
I had a relay to the hids I was running...took those off because I thought they were the cause but now I'm getting the same issue...and it's seems like instant..and my battery meter never pass 12.7....volts...I check the connection that goes to the battery and that reads 14.3
08-08-2013, 06:58 PM | #25 |
Man w/ CTSV & a Car Seat
Shitty alternator...its not uncommon to get shitty alternator from Autozone. SOme folks had to replace their Autozone alternator 3-4 times before they got one that worked.
08-09-2013, 03:47 PM | #26 |
lol thats what a shop told me... im thinking bout just ordering one from somewhere else..smh.. anyone got suggestions?
i had bad corrosion on the terminal also.. smh.. cleaned that up.. im just curious why the connector reads 14 but the alt reads 12.5 |
08-25-2013, 01:31 AM | #29 |
so i went to oriellys and got another alty.... when i bought it i realized the pulley is smaller than the one from autozone.. which is not a bad thing..smaller puller more amps.. which is good.. so put it on had to get a shorter belt and cleaned up the corrosion that was built up on the batt... got that charged too by the way... and i also realized that the ground for batt was loose as hell.. so i had to put that in a different spot... so now im seing 14+ volts.. when i turn my hids its around 13.5 or so./
now the issue im having is one hid always goes out.. im thinking i need to put a relay on it/. any body else running a relay? |
08-29-2013, 08:19 PM | #30 |
Anyone? Im wondering if I need to order a relay harness off ebay.. I'm not too sure about them though cause they only have one plug for the power source... Any one have any input
