Old 08-15-2020, 01:55 AM   #1
nisileighty
nisileighty's Avatar
nisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of light
SR20DET CAS failing?
Can anyone tell me if they think this is symptoms of a failing cam angle sensor?
I have a 91 Silvia with a blacktop S13 SR. It originally had this hesitation/breaking up issue, and when I put my timing light on the car, it was reading base timing at 0?, so about 15? off. I retimed it to the FSM procedure, it drove great and pulled hard. Next morning, started it and it had the same issue. I put the timing light back on it and it had somehow jumped to ~25?. So I timed it back to 15? again and now it still has the same issue except base timing checks out at 15?.
Is this symptoms of a failing CAS? Or does the CAS just stop working all together when it?s going out? Unless there?s something I?m seriously overlooking, I?m stumped. Thanks!
nisileighty is offline   Reply With Quote
Old 08-15-2020, 04:31 AM   #2
S14rebuild
Cas going bad, a bad harmonic balancer, and loose bolt on the camshaft sprocket. Seen them all cause issue like this
