01-17-2012, 08:32 PM | #571 | |
so 245/40/18 fronts and 275/40/18 rears? |
01-17-2012, 09:37 PM | #572 | |
OR GO 265 in the back if you want a slight stretch. |
01-18-2012, 07:43 AM | #573 |
I have tein coilovers and I was planning on running 245 or 255 tires with 225's up front. I had spacers when I ran stock suspension with Z32 tt wheels and was able to loose the spacers when I installed the Tein coilovers.
01-18-2012, 08:31 AM | #574 |
So, I bought a set of CE28Ns for my S14 a few months ago (then came the Swedish winter, no place to work on my car = storage) so haven't tried mounting them yet. All four wheels are 18x9.5 +15, and I'm planning on running 225/40s (Federal 595s maybe?). Got coilovers and camber arms of course. Two Q's:
Rear: Am I good with just a tight roll? Some camber too, of course, I just don't want a lot of it. Front: Removing the fender liner, required? Any other issues I could run into up front? |
01-18-2012, 08:38 AM | #575 |
s13. whats the best specs i should run with aggressive wheel fitment WITHOUT SPACERS.
was thinking 17x9.5 +12 those would clear front coils and fit semi flush with maybe a little bit of roll correct? |
01-19-2012, 09:24 AM | #576 |
Quick question guys, I'm looking at getting some 18x11 -13 CCWs and I was wondering if these would fit good under a S14 with 50mm chargespeed rear overs or should I go with something a little wider? Dont want to run lots of rear camber of course...
01-19-2012, 10:17 AM | #577 |
Wondering about some Sportmax (xxr) 526 on a stock body with a fender roll i wanna know if i can fit these under my car without a pull. 17x9 not sure of the offset i think its +35
01-19-2012, 04:23 PM | #578 |
I have a 98 camry xle on 20x8.5 with no problems. I wanted to run 18x10 xxr 521 all around. What do I need to do and what size of tires do I need to put on there. The car is lowered on Eibach springs
01-19-2012, 04:32 PM | #579 |
Planning on lowering my S13 but I refuse to use the se alloys so I need new wheels, and I'm broke so I'm probably just going to get some steelies for now. Is something like a 225/50 on a 15x9 or 15x10 possible? Suggested offset?
01-19-2012, 06:43 PM | #580 |
Vitzio240sx
* hi, im a complete noob when it comes to tires. I wanted to know whats the biggest tire size i can run on a stock s13? only suspension mods it has are stance gr coilovers and tie rods. Whats the biggest tire size/offset/width/etc i can run with no problems. please let me know and excuse my noobiness thanks
"Men with guts attack those corners!"-Keiichi Tsuchiya |
01-19-2012, 09:52 PM | #581 |
01-20-2012, 03:40 AM | #583 | |||||||
Man w/ CTSV & a Car Seat
Fender liner, again, depends on how low you are. Everybody takes theirs off, problem you'd run into is you'd have to relocate the wiring harness (do a search on fender harness relocation, there should be a couple of guides) and you'll get dirt/rocks crunching by your door/back fender. Quote:
01-20-2012, 12:56 PM | #584 |
01-21-2012, 12:29 PM | #585 |
xxr 526 18x9 and 18x10.5
Could someone tell me what size wheel spacer/ offset i would need to make it look flush.The sizes are 18x9 in the front and 18x10.5 in the rear. I was planning to add 25 mm spacer for the 18x9 0 front and 22 mm 18x10.5-2 for the rear but wasnt too sure of what looked best for what i wanted. im scared 18x9 with 0 offset is gna be too much of a poke.
i drive a sil-eighty( s13 fastback) and my coils are maxed out low in the rear and almost maxed out in the front. i want it to sit like this s13 right here. hes running 18x9 +6 and 18x10 -1. found it on rimtuck. so please help, and sorry if this question was already asked. i searched using the forums tools and thread tools but no luck. |
01-22-2012, 05:47 PM | #586 |
Fuck buying shitty sizing wheels and spend more money on inch wide spacers to make them "flush". There gotta be some other shitty knock off wheels out there that are sized around 9.5j/10.5j +12.
But if you're stuck with the wheels already, why dont you just match the red car's offset with the other spacers instead of slapping the 25mm and 22mm? |
01-22-2012, 07:38 PM | #587 |
Need Help!
Hey, I've been searching but so far all I've seen were stretched tire fitments.
I want to know what the best size rim/tire and offset for the front and the rear of a 1995 240sx? I want it to sit pretty flush with the fenders rolled but no pull or stretched tires. I would also prefer to run like a 245 atleast in the rear for a little traction. For an example can i run 9" all around with 245's, if so what offset would i need? I plan on getting some xxr 521's. |
01-22-2012, 10:22 PM | #590 |
Can a silvia s13 fit 9.5 inch XXR 526 with a fender roll no pull succsesfully without having to pull? i think the offset is like +35 on both. or can any1 find a picture cuz i dont want to look through the 500 pages of wheel fitment crap to find it.
01-22-2012, 11:02 PM | #591 |
Read what I posted up earlier and answered your question...
Again, you wont find anybody rocking those sizing because IT WONT FUCKING FIT!!! Fronts wont clear the suspension...you need lower offset. If you dont want to pull the fenders, read what I posted up before your last post. Lastly, stop asking this same question multiple times and in multiple threads...if you've done some research, you would have already known that 9j +30 doesnt clear the strut without spacers. Think Skyline GTR wheels... |
01-22-2012, 11:07 PM | #593 |
Read up...I already answered what offset you'd need. If you still cant comprehend that...go sell that car and get an accord. Will go perfect with 9j +35.
01-23-2012, 07:31 AM | #594 | |
true that with the accord joke lol. just to clarify once again, no rims will clear coils up front on any 240sx unless the offset is +25 or lower and is at least 8.5 wide. i know 9.5 +15 barely clear coils on a s14 up front. hope this helps |
01-23-2012, 07:42 AM | #595 | |
hope this helps. |
01-23-2012, 11:47 AM | #597 |
Depends on coils but R34 wheels will usually clear coils, clear pbm and stance but megans wont. Ive had all those coils with GTR wheels.
That was with no spacer, I later added a 30mil, with no pull just a roll |
01-23-2012, 02:12 PM | #598 |
What size tires should i run on 18x9.5 +15 battles on my s14? I want to stay super slammed and still have tire performance and not massive under-steer. Also with the battles whats the best size spacer to run all the way around for semi poke? I was planning on 15mm in the front and 20-25 mm in the rear, just a bit unsure, any help would be appreciated thanks.
01-23-2012, 02:29 PM | #599 | |
Trader Rating: (77)
Feedback Score: 77 reviews
