Old 08-30-2015, 10:07 PM   #1
04BlueBeach
04BlueBeach is an unknown quantity at this point
Rod Bearings Loose During Assembly.
Hey guys. I'm rebuilding my KA, had a bad rod bearing. I replaced the bearings and noticed that they seem loose! Plasti gauge was within spec I believe. Is this just because there is little lubrication? I did use a little assembly lube. I'm really hoping that they aren't suppose to be oversized bearings. I've tried searching with no prevail. Here's a video: View My Video
Sent from my 0PJA2 using Tapatalk
04BlueBeach is offline   Reply With Quote
Old 08-30-2015, 11:24 PM   #2
Hoffman5982
Hoffman5982's Avatar
Trader Rating: (25)
Feedback Score: 25 reviews
No that is not right at all. Did you have an machine work done on the crank? If so, you definitely need oversized bearings. Ive never seen any play like that unless it had a spun bearing
Hoffman5982 is online now   Reply With Quote
Old 08-30-2015, 11:42 PM   #3
04BlueBeach
Nope, never had any machine work done, last owner must have! I have a friend with a stock crank, should o switch cranks instead of going switching rod bearings? Or should I measure and get correct bearings for my crank?
Old 09-01-2015, 10:57 PM   #4
04BlueBeach
Bump? Would like to know wether or not I should get a stock crank, or buy oversized bearings.
Old 09-02-2015, 07:18 AM   #5
dreimers
dreimers's Avatar
dreimers is an unknown quantity at this point
Up to you... either way will solve the problem
This is a site ran by the US government, not some crazy biased organization
dreimers is offline   Reply With Quote
Old 09-02-2015, 08:47 AM   #6
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
Yes, and no.
Truthfully, I'd be measuring that rod end too, if it's egg shaped may as well use it for a door stop
Old 09-03-2015, 01:16 AM   #7
Hoffman5982
Trader Rating: (25)
If the other crank is in good condition I'd go that route
Old 09-04-2015, 07:06 PM   #8
04BlueBeach
Awesome thanks for all the replies. Got the crank, will start doing a bunch of mesurments and I'll let you guys know how it goes!
