Old 10-16-2020, 04:02 PM   #1
mikecampafool
mikecampafool is on the path to ruinmikecampafool is on the path to ruin
My 1991 240sx Track Build
I'm finally in a position to own and maintain a track car!
I've also looked forward to starting a thread on here since I joined in 2010. So here we finally go.
I'll start with the current mods and follow with some pictures and continue to add updates.
All advice is welcome!
First things first I'm not starting from scratch. To save money I found something priced fairly well (at least I think so)
Chassis/Suspension
NISMO POWER BRACE
ES HYPER FLEX BUSHING KIT
ES SUBFRAME BUSHINGS
MEGAN OUTER TIE RODS
DIF SOLID STEERING BUSHING
MEGAN TRACK COILOVERS Any thoughts/recommendations on these?
ICHIBA FRONT 5-LUG HUBS
STEEL BRAIDED BRAKE LINES
MOOG REAR BALL JOINTS
OEM Z32 BMC
HAWK HP+ PADS
Z32 CALIPERS
ENGINE/TRANS/ETC
NISMO CLUTCH SLAVE
FIDANZA FLYWHEEL
WALBORO 255 FUEL PUMP
TOMEI OIL BLOCK
MISHIMOTO SNEOSR ADAPTER
WIRING SPECIALTIES ENGINE HARNESS (CHEAPO ONE)
N65 MAF W/ PIG TAIL
S13 SR20DET SWAP
GREDDY OIL PAN
750CC JECS INJECTORS
HALTECH ELITE 1000 ECU + ADAPTER
CIRCUIT SPORTS FILTER RELOCATOR
EARLS OIL COOLER
S13.4 VALVE COVER
ISR V2 MANIFOLD
MISHIMOTO OIL CATCH CAN
MISHIMOTO COOLANT RES
5353 COMP TURBO W/ .018 RESTRICTOR SCREEN
TOMEI FPR + GAUAGE
AEROMOTIVE FPR
CXRACING INTERCOOLER KIT
B&M SHIFTER
3" ISIS BLAST PIPES
Engine build sheet: Thoughts appreciated
Things i'd like to tackle first:
(Please send any advice)
1. Wiring; the wiring in the engine bay hurts my eyes. I'd love to clean it up a bit.
2. Paint; I've purchased the necessary equipment to be able to paint and would like to give it a go. I hate red paint.
This list and pictures will grow I wanted to get this started though
mikecampafool is offline   Reply With Quote
Old 11-13-2020, 04:43 PM   #2
mikecampafool
Purchased my seat rails from Street faction and they came in today. When I backed my car out of the garage (garage is a mess no room to work) I noticed a drip from under the trunk. Found a fuel leak.
Never had to tackle a fuel leak looks simple but looks can be deceiving i'll be searching the forums and youtube for some assistance.
Old 11-16-2020, 12:31 PM   #3
relaxamigo
relaxamigo's Avatar
relaxamigo is an unknown quantity at this point
Not sure what type of track you'll be doing, I assume drift? If so, I'd go with fortune auto coilovers over the megans. For steering, run a slightly lengthened s13 FLCA (maybe like 15-20mm), maxima inner tie rod, and an OEM style outer S14 rod end. If you already know how to drift, get a cut knuckle. If you're going to learn how to drift, run stock knuckles until you master the basics, then switch to a cut knuckle. The rest of your suspension/chassis looks great.
Regarding your leak, check for cracks in the hardline and tears in the rubber. Make sure you're running J30R9 rated rubber fuel injection hose and using proper fuel line clamps, and not the ones you have there.
Have fun with your build
relaxamigo is offline   Reply With Quote
Old 11-17-2020, 06:05 PM   #4
mikecampafool
Originally Posted by relaxamigo View Post
Not sure what type of track....
Really appreciate your response. I'll go through and swap out the hoses and fuel line clamps.
Definitely will add the items you mentioned to the list too.
