11-19-2011, 11:24 AM | #8581 |
PLEASE HELP
i am doing a wire tuck on my s13 and was going to follow this http://zilvia.net/f/chat/407974-tuck...like-baws.html but i have this piece of metal on my s13 (its on the drivers side too) that the other one doesn't have. am i suppose to cut that off as well? http://i1116.photobucket.com/albums/...in_s13/cut.jpg Last edited by machuca212; 11-20-2011 at 08:13 PM.. |
11-19-2011, 02:38 PM | #8582 |
Trader Rating: (32)
Feedback Score: 32 reviews
Ok, I've been searching and searching. Looked on rimtuck and am stuck between two tire sizes.
Heres what I'm looking at: RUCA Fortune Auto Coils 17x9+15 all around S13 Hatch No fender mods yet, but plan to roll front and rear as needed. Don't plan to slam rediculous low, but obviously want no fender gap (tuck tiny bit of tire) I see alot of people run something close to 215/40r17, but can i get away with a 225/40r17 all the way around or even a 225/45? The wheel size and tire threads have much more aggressive fitment than what sizes I have, so I thought I might ask here first.. |
11-19-2011, 02:52 PM | #8583 |
sr20det expert needed
This is my first time working with an SR
A headgasket blew a while back and had a water/oil mix issue. Got a new headgasket, got the heads rebuilt and resurfaced, bolted down w/arp head studs. I still have a water/oil mix issue. Now to the question: Is this happening because I didn't resurface the block since its also aluminum? Or is this a result of a cracked water jacket? I'm thinking of just getting another block. Last edited by doomviillain; 11-19-2011 at 11:17 PM.. |
11-19-2011, 04:10 PM | #8584 | |
Trader Rating: (58)
Feedback Score: 58 reviews
With that said, be sure that if you are going to run a different fluid that you have some and or it's easily accesible in the event you need to top it off. Also make sure it can 'play well' with other fluids. S14K in japan was only s14 IIRC to have larger calipers.
11-19-2011, 08:05 PM | #8588 | |
street dancer. GLEAM |
11-19-2011, 08:43 PM | #8589 |
Ok... I have searched but can't find the answer I'm looking for, I've asked friends but I'm hearing different things... (Can I run 15mm bolt on spacers with battles?). I have heard I'm gonna have to cut my studs I've heard they fit fine... Someone even told me to run a 5mm slip on between the hub and 15mm bolt on to avoid cutting studs? I'm all assed up now and don't know what to do-spacers will be here Monday any advice?
RELAX BITCHES-IT'S THE FUCKIN INTERNET |
11-20-2011, 02:54 AM | #8590 |
no offense dude but thats a perfect screen name.
Battles + 15mm slip on + stock studs = your golden. What is this stud cutting nonsense? How would that EVER be beneficial?
S.P.P.S. Member #00 **CoUpe LOve** Member #00 Last edited by Wake; 11-20-2011 at 04:03 AM.. |
11-20-2011, 03:15 AM | #8591 | |
Trader Rating: (68)
Feedback Score: 68 reviews
Late Night Crew... #02 <3 Bought anything from me? Please leave me a review! http://zilvia.net/f/private-sellers/...meistah21.html |
11-20-2011, 11:59 AM | #8592 |
215/40/17 federals = 225/40/17 lol
11-20-2011, 12:42 PM | #8593 | |
there not slip ons bud-I forgot about the all the douch fuck Internet tough guys on this forum who sit In front their computer screen all day waiting to get stupid with someone when half of you shit dicks have probably NEVER got in someone's (face) with an opinion, now I'm not offended just pointing that out "no offense" let me clarify my situation. The adapters I ordered are bolt on... They bolt onto my hub and the wheels bolt onto the adapter, I'm sure you know what I'm talking about-my question is... Will my studs be longer than the adapter? If so that will restrict the wheel from sitting flush with it, leaving me in a situation where I would cut them correct? I have looked at the battles and there are no slots for this, like I have seen on other wheels. If this is the case is there a simple NON SARCASTIC solution? Now fire away
11-20-2011, 05:06 PM | #8594 |
I'm having a problem at lower rpm's getting much power, the car jerks and stutters some times. it almost sounds like its misfiring. if anyone has any advice that would be great
11-20-2011, 05:09 PM | #8595 |
Can someone post a picture of what the A/T pilot bearing looks like for a ka? I'm doing a five speed swap and want to know what to remove to install the manual pilot bearing.
11-20-2011, 06:32 PM | #8596 |
I just recently bought a SR20DET for my 1991 240sx threw my local performance shop. When it comes in It will be stand for a couple of months while i replace and upgrade some parts.
I've made a whole spreadsheet of my engine rebuild and this is the maintenance part of it. Here is the list and if you feel like some I should add something please let me know. I've done research and research and I would just like to know if I'm missing something. Thanks Dont mind the prices, I have sourced parts from 3 different websites and i just copied from my spreadsheet. Everything is OEM Maintenance Parts Full Rebuild Gasket Kit OEM $148 OEM Nissan Thermostat $22.18 S13 SR20DET Timing Chain Kit(w/water pump) $325 OEM SR20DET PCV valve $12 OEM SR20DET OIL PAN $84.00 Complete Belt Set for Nissan SR20DET OEM $59.99 300zx Fuel Filter Nissan SR20DET $19.99 NGK Iridium Spark Plug $39.99 NISMO Motor and Tranny Mounts $249.99 WIRING SPECIALTIES HARNESS $399.99 OEM SR20DET OIL FILTER $18.99 OEM Front Cover Oil Pump Assembly $239.99 *ISIS Radiator Cooling Package $299.99 So if you think i should add anything to my "Maintenance" parts. Please let me know. Parts came from Z1 Courtesynissanparts Enjukuracing |
11-20-2011, 06:49 PM | #8597 |
Trader Rating: (39)
Feedback Score: 39 reviews
i know what you kinda mean, i had something similar happen to me a while back, i changed the plugs/wires and the car ran perfect after, you could check your plugs if you haven't already, my best guess , but then again it could be something else.
IG - allen.kerose |
11-20-2011, 09:52 PM | #8599 | |
Sorry for calling you retarded when you labeled yourself that with a screen name. In no way, shape, or form, did I act tough or call you out. To answer your stupid ass question, NO Looks like theres 2 sets if holes, the studs in the spacers should fit into the second set of holes. Have fun with the rest of your stay on the internet.
S.P.P.S. Member #00 **CoUpe LOve** Member #00 |
11-20-2011, 10:12 PM | #8600 |
To add, some wheels have actual slots on the back of the disk for studs to fit into if you have spacers
11-20-2011, 10:19 PM | #8601 |
Your a fucking idiot... That's two different lug patterns. Someone clearly don't work on their own shit..... And the battles don't have the slots : / that's why I'm having this problem to begin with.
11-20-2011, 10:22 PM | #8602 | |
Trader Rating: (22)
Feedback Score: 22 reviews
^^^ look familiar?
11-20-2011, 11:35 PM | #8603 | |
Edit: If you're gonna cry that "Zilvia is full of internet douche bag tough guys" get the fuck out and go use Google or NICO.
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
11-20-2011, 11:45 PM | #8604 |
Its not the dumbest thing IVE ever heard.
I have battles and PSM 15mm bolt on spacers. When the wheel goes on the OEM studs are too long and hit the back of the battle and causes it to not bold down correctly. You can physically see the stud hitting the back of the wheel through the "weight savings" holes. Dont be stupid and cut your studs... What i did was put the slip on 5mm on, then bolted down the 15 on top of it. Which made less of the stud stick out, letting the wheel go on correctly. |
11-20-2011, 11:54 PM | #8605 |
Thank you lukass-this is all I wanted to know man, someone told me to do that with the 5mm but it sounded a little sketchy... I'll give it a shot and go back to lurking now since ppl here can't share correct info without being bitches.
11-21-2011, 12:03 AM | #8606 |
You're welcome.
I don't have any problems with the 15mm on top of the 5mm. Both are Parts Shop Max spacers. No vibrations in excess of 90mph. But I cannot speak for any other spacer. Good luck. |
11-21-2011, 12:27 AM | #8607 | |
now THAT is the stupidest shit i've read
11-21-2011, 12:52 AM | #8608 | ||
11-21-2011, 01:48 PM | #8610 |
hey okay, should my distributer be centered or should the timing be more advanced or retarded? mine was full retard for as long as ive swapped this engine in but what makes more power on a stock ka? and not make it detonate or anything else bad happen?
