Old 08-14-2020, 05:50 PM   #1
spacemonkey
spacemonkey is an unknown quantity at this point
Ignition/starting question
Greetings!
My S13 (SR20DET blacktop) only starts about once in every 5 times the key is turned. 4 out of 5 times the engine doesn't crank, starter motor doesn't make noise, only the dashboard lights light up. I suspect it's an electrical problem. Battery is pretty new (12.6V when car is off) and the negative terminal has a good ground connection to chassis.
Any tips on how to troubleshoot this problem? Should I check continuity/resistance from battery to starter motor or something else?
Thanks.
spacemonkey is offline   Reply With Quote
Old 08-14-2020, 06:04 PM   #2
zombiewolf513
zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513
Hi, welcome Californian.
Dont mean to be rude but this topic was covered a few times this past few weeks. Please try to use the search features first, and if youre still having trouble try posting in the small questions thread. Youll get help, just have to ask the right way around these parts
zombiewolf513 is offline   Reply With Quote
Old 08-14-2020, 06:29 PM   #3
S14rebuild
https://zilvia.net/f/showthread.php?t=532020
Old 08-14-2020, 06:56 PM   #4
spacemonkey
will do, thanks
