08-14-2008, 11:12 AM | #1 |
Trader Rating: (40)
Feedback Score: 40 reviews
Q45 fuel pump
Well guys just thought i'd share my experience with you, I just installed the Q45 fuel pump and holly shit, previously I was using the stock fuel pump which I dialed in my AFR to ~11.5 WOT.
After installeding the Q45 fuel pump my AFR went to 9.2 AFR, and now I have to dial it in all over again or I might just get a nismo FPR since my fuel pressure jumped up alot. S13 fuel pump psi (vacuum) ~36ish psi Q45 fuel pump psi (vacuum) ~45psi holly shit! psi (no vacuum) 56psi damn almost 4bar Must be a beast of a pump I said to myself, but then again there is no FPCU on a S13 so the pump runs in High Output mod 24/7. Just for comparison sake i'll show what the required litre per hour would be for S13 Z32TT Q45 @ 100 duty cycle: # of Inj x cc/min x 60min ÷ 1000cc = Lph S13 = ~65 Lph Z32 TT = ~133 Lph Q45 = ~177 Lph Last edited by UNISA JECS; 08-14-2008 at 07:58 PM.. |
08-14-2008, 12:00 PM | #3 | |
Trader Rating: (40)
You have to modify the stock sock. You need to modify the rubber seat at the bottom of the pump also so it fits like stock. You need to cut the fuel outlet pipe, this is the pipe the that connects to the fule pump outlet port. |
