Old 09-10-2015, 09:48 PM   #1
arlrat
arlrat's Avatar
arlrat is an unknown quantity at this point
240sx for sale or trade
1992 s13 hatchback 240sx for sale or trade car runs and drives awesome il get sideways with anything if u want it too, motor runs strong not looking to sell it so im in no rush what to so ever i love the car ihad it for 3 years.. will trade for a nice bobber or a harley or even a streetbike, car wise il take anything you got to offer worth my money if i dont like it il just say no.. contact me if serious located in riverhead 11901,
PRICE IS FIRM
Alex 631-680-4749
engine: SR20DET REDTOP
-powder coated valve cover
-Nismo oil cap
-ACL main & rod bearings
-arp head studs
-aftermarket metal head gasket
-new timing chain set up (tensioner, guilds, chain, cam gears, crank gear)
- new piston rings
-replaced oil pump/front cover
-after market pulleys
-oil was changed after 1 min of running, then again after taking it around the block, then again after driving 1 mile, oil changed either every 1500 miles or every other month
-new rear main seal
chassis/drive train/mic. things
-AEM UEGO wideband gauge
-92 s13 hatchback
-glowshift boost gauge
-gauges on steering wheel column (mickey mouse gauge pod)
-godspeed coilovers
-godspeed full suspension arms
-godspeed sway bars (front and rear)
-5 lug hubs
- wheels tires have about 50% life left
-welded diff
- hood spacers
-Spec stage 3 clutch
-stainless steel braided brake lines
-q45 front calipers/rotors
-b&m short shifter (shortened oven more)
-isis power steering steel braided line
-two row aluminum radiator
-electric fans and shroud
-huge tredstone front mount intercooler
-3 inch full exhaust (turbo elbow to tips)
-dual tip exhaust
-after market steering wheel hub
-grant after market steering wheel
-front and rear strut bars
-JDM gauge cluster
-s14 front seats (driver and passenger)
-suede door panels
-suede glove box
-full interior
-pioneer speakers (front and back)
-trunk is painted with rhino liner
-pignose front bumper with quick release clips
-sleepy eye mod
-clear corner lights
M1-103 oil filter Mobil 1
-98 q45 brake caliper front
- Shaved engine bay
- tubs engine bay for more clearance
- Full aero body kit rivet on
-hella horns from a Subaru
-Spec stage 3 clutch (installed month ago not broken in)
-Push to start switch
-Brand new axles
Needs
Paint job got primer on.
Rear Upper control arms (goodspeeds are done)
Break in the clutch (500 MILES)
Alignment (rear toe is off)
finish the tubs or do tube front end
Price is $6500
Text or call 631-680-4749
arlrat is offline   Reply With Quote
