06-13-2022, 12:56 AM | #1 |
[S14] clutch losing pressure
I had an issue that the pedal is falling to the floor (and staying there).
After bleeding everything works fine for several days and it happens all over again. Replaced master and slave cylinder, done the bleeding process, and it's still exactly the same. I was not able to find any leaks Any thoughts on what else should I check? |
06-13-2022, 09:42 AM | #2 |
Wild guess but check the clutch dampener (if s14’s even have one). I had similar issues on an S13 and that box thing was the culprit. I think the loop got bent upwards and air pooled in it.
