04-15-2009, 08:19 AM | #1651 |
Yeah, I did those about a year back. They bolt on to the door hinges, but its welded on at the upper frame rail. Made a HUGE difference.
Ha thanks, I've been working on the car since november. Got into a accident and have been rebuilding the car since. I'm just now getting the motor back up and running after the rebuild. This is what it looked like 5 months ago: |
04-16-2009, 04:45 PM | #1653 | |
... and I was wrong lol. The trunk area definitely needs to be braced. I'm going to use 3/4" square tubing to go from the strut towers around the 'floor' to brace it... eventually it'll make its way into this thread I can definitely tell you that it needs to be braced though ~
04-16-2009, 04:51 PM | #1654 | |
04-19-2009, 11:02 PM | #1658 |
That welding cart is badass.
One thing I wanted to say is that almost every car I see has no sort of intercooler/rad ducting. So here is a teaser pic of what I will be finishing up next week. Proper ducting coming to a Turbo Ls1 s14 next week.
04-20-2009, 02:42 PM | #1659 |
haven't posted on this thread for a while. looks like some people have been pretty busy lately . have some free time so i thought i'd contribute some okay fab work i've done since the last post.
custom exhaust for a lexus sc430. i forgot to take pics of it on the car....... i/c piping for a ma70 supra a little vacuum manifold (first thing i ever made on a mill) battery tray and tie down (tie down is the second thing i've made on a mill) welds are kinda crappy since i don't have 1/8" gas lens or collets and the 3/32 kept wanting to drop I still need to work on my welds |
04-20-2009, 05:21 PM | #1660 |
savage work, the welds dont look to shaby to me.
"Racing is life. Everything else that happens before or after is just waiting." ~Steve McQueen [Le Mans -1970] |
04-20-2009, 06:17 PM | #1662 |
How the hell do you guy guys weld aluminum so nicely?
I tried this weekend and I failed miserably. I welded like a .05" thick piece of aluminum with my schools tig welder, and When I tried to get the puddle started like I would do on steel it just made a FAT hole in the aluminum and the aluminum was turning charcoal black around it. Set the amps to about 65A and A/C, with the green tungston. |
04-20-2009, 07:31 PM | #1663 | |
Trader Rating: (29)
Feedback Score: 29 reviews
The reason aluminum needs A/C is because it oxidizes so fast. Aluminum oxide is second to diamonds in hardness and take a tremendous amout of heat to burn it off. Aluminum oxide melts at 3632 F where as aluminum melts at 1220 F. The more crap you have on your aluminum the harder the A/C wave has to work cleaning it off. This can melt you base material before you burn off the oxide, and the base will not puddle. |
04-20-2009, 07:40 PM | #1664 |
what did you have the a/c balance on? try learning on thicker Al. it is much easier to not burn a hole through. .050 is pretty thin stuff for a beginner. if you could get closer to .090 it would be easier. also practice by doing padded beads (don't try to fuse to pieces together, just run beads on a single piece in the middle). also, do you know if the alloy of the metal is weldable? some aluminum alloys have a D grade for weldability.
04-20-2009, 08:01 PM | #1665 |
Thanks for the suggestion guys.
I believe the A/C balance was on( I assume thats the diagram that has the graph of a square starting at positive then going to negative. I tried .05 because that's the only scap aluminum we had lying around at the shop. I'll have to give it another go then with a thourough cleaning this time. |
04-20-2009, 09:16 PM | #1666 |
try putting a/c balance at like 5 or 6 if it's a syncrowave
edit: duffman, just read your post about 4130 on the last page. i would just leave the welds, heat treating isn't something most people can just "eyeball". unless you can get the whole chassis heat treated precisely, i would just leave it, you probably wouldn't be doing any good using an oxy-fuel torch to heat it up and letting it cool down naturally, just let it cool down naturally after you weld and that should be sufficient. heat treating to relieve stress usually means letting the metal cool down slower than naturally. also, your project probably won't be subjected to the same life expetancy and stresses aerospace applications would so i wouldn't worry about it all that much. john forces chassis were all heat treated and look how much it helped him in that crash a while ago. if you didn't put too much heat into the weld you should be fine. Last edited by fakts13; 04-20-2009 at 09:39 PM.. Reason: don't want to double post |
04-20-2009, 09:46 PM | #1668 |
did you weld the Al. with the balance set like it is? if so that probably is your reason you're having problems.
the balance is the knob above the power switch. set that between 5-7 for 6061 |
04-20-2009, 09:53 PM | #1669 |
OoOo I'll try that then when I get to welding again. Thanks!
Hopefully I can get this down so I can fabricate my own intercooler piping and other stuff in the future. |
04-23-2009, 01:20 PM | #1675 |
Didn't want to run the rear down bars back to the strut towers? Most S14 cages connect the strut towers with a cross-bar, and have the rear down bars cross and connect to that... gives you quite a bit less angle - how close to 45* are those down bars?
04-23-2009, 02:13 PM | #1677 |
What kind of welders do you all have? I'm looking to buy, but I dont know enough about it to know what I should get. I was thinking of spending $500 or so on a MIG that says it can weld up to 1/4" steel? Would that be good enough for welding exhaust piping, roll cage tubing, some brackets, etc?
04-23-2009, 03:05 PM | #1678 | |
I have a Millermatic 210 (using an 80lb wire spool and and 230 or 244cf cylinder of 75/25) It last for a long time before I need wire or gas. Also have a Millermatic 135 with a little bottle of 75/25 and run .025 wire in that one. (use it for sheet metal or small jobs) |
04-23-2009, 05:47 PM | #1679 |
I too am thinking about getting a welder. Right now I'm looking at the Miller Diversion 165. I don't know (or maybe care) if it is dumb to jump straight into TIG welding first, but I mainly want to be able to do aluminum, etc.
