09-13-2019, 10:30 PM | #1 |
Toyota Celica GT-S 3 Owner PowerPlant 3sgelc 1st Gen
Price TBD at the moment I'm open to honest offers.
1989 Toyota Celica Gts Black on Black special edition Clean Title No Accidents Fully Loaded with Leather interior and everything electric including drivers seat. New 3sge JDM Spec engine imported from Japan with 0 miles On D2 36 way adjustable coilovers "Very Rare" not made anymore Still have oem usdm spec motor and transmission LSD Equipped Both tires make power OEM Paint still shines Vin numbers matching front to back stickers are all present. 3 owner car since new All images are to current Date. Rear seats are torn and dryed out probably won't be fixing that #racecar Everything else is minty fresh. I have 1 new driver's side fender not installed in OEM Black. Added Cold air ram intake New. Added dual core Radiator New. Dual Core Rad installed with OEM electrical fans attached. Replaced ignition switch Replaced Distributor Replaced TPS sensor Replaced Cv axels x2 Replaced Control arms x2 Replaced Ball Joints x2 Replaced with Reman Starter Replaced Fuel pump & Strainer Replaced Fuel filter Replaced Rack and pinion Replaced inner and outer tie rods Replaced Klutch SL1's Replaced Falken 205 45r 16 tires Full tune up done since new engine install. Replaced Cap and Rotor Replaced NGK wires Replaced Spark plugs Replaced Valve cover gasket with install IAC Valve Serviced Intake manifold Serviced Always running full synthetic oil and 91 premium fuel. If you have watched some of my videos on youtube. The driving videos are from the same day. Went on 1 touge run to test out the dual core radiator. Since that very day I parked it. Put it on non op. Reason for that is she had a bad starter, thermostat, and fuel pressure regulator. 1 of 3 issues has been fixed. I have always garaged Rocket Sally and have put lots of care into her. Anyone who get's her will be very lucky to have her. The only other issue is 2nd gear pops out does engage very well regardless of that. I'm never in 2nd long enough to be bothered by that issue. I do have another transmission you can make 1 great 1 out of. I'm not a transmission specialist so I haven't tryed to dismantle either one. I've cared for her for the last 5 years and as you can see it shows. I'm open to RWD Trades especially an MR2. Cold Start Video https://youtu.be/XI3hHRYqy28 You can see pictures on my instagram @jefesgarage Last edited by Jayce; 09-14-2019 at 05:00 PM.. |
