Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Engine
Old 08-04-2010, 09:45 AM   #1
Chops@MVP
Chops@MVP's Avatar
Chops@MVP is just really niceChops@MVP is just really niceChops@MVP is just really niceChops@MVP is just really niceChops@MVP is just really niceChops@MVP is just really niceChops@MVP is just really niceChops@MVP is just really niceChops@MVP is just really nice
Send a message via AIM to Chops@MVP
AEM Tru-Boost Controller and 5 Gal Meth Kit PRICE REDUCTION!!! MVP Motorsports
SALE PRICE!!!!!
$271.82
AEM’s TRU-BOOST Gauge-Type Controller is an electronic boost controller that combines the simplicity of a manual boost controller with the added ease of adjusting boost levels through a gauge interface. There is no external interface required for set up, and it is fully functional right out of the box. There are no gimmicks or special software programs included. If you want more boost press the button on the right of the gauge face, and if you want less boost press the button on the left of the gauge face. It’s that simple, and IT WORKS!
AEM’s TRU-BOOST Gauge-Type Controller includes everything you need, including an on-board 29 psig pressure sensor, built-in Overboost protection with two timed shutdown levels, a scramble boost setting and a low-side output for a warning light. AEM offers a 75 psia boost sensor for high boost applications (sold separately).
AEM’s boost control solenoid (included) is the only one specifically manufactured for automotive boost applications, which means it won’t corrode and stick from exposure to rich fuel mixtures, it is pressure tested to 100 psi and includes -4 AN fittings to eliminate any chance of leaks.
SALE PRICE!!!!!
$395.10
The Water Injection Kit is an economical, complete install kit with no extra parts needed, user-friendly setup solution for reducing air inlet temps and increase charge density in boosted vehicles. Allows the user to safely run higher boost pressures and suppress detonation allowing the utilization of more timing and boost. Performance will no longer be compromised when running lower octane fuels. Features a high-pressure pump with progressive controls, a 5 gallon tank with integral fluid level sensor, interchangeable nozzles for easy flow adjustment and an integrated system status dash light with easily identifiable error codes including short circuits, battery voltage problems and low fluid warning.
Key Features:
* Complete kit, everything is included
* Progressive controller driven 150 PSI pump
* 5 gallon tank with integral fluid level sensor
* Dash light for system status and low fluid warning
* Alcohol Compatible (up to 50% in solution with water)
* Progressive controller, provides boost dependent variable flow
* Provides output to either decrease timing or boost if the system runs out of fluid or detects an error
* Kit includes three jets to match your power requirements
Regards,
Robert
940-683-8282 x20
Robert Del Angel
CLICK HERE FOR OUR FACEBOOK PAGE!!!
FOLLOW US ON TWITTER!!!
Master Distributor for : RPS, Tein, Seibon, Haltech, HKS, Greddy, Cusco, Blitz, Koyo, AEM, Map ECU, Eibach, Tokiko, Power Enterprise, Work, Volk, Fidanza, Defi, ....and so many more!!!
Chops@MVP is offline   Reply With Quote
Old 08-04-2010, 06:47 PM   #2
R33E8
R33E8 is an unknown quantity at this point
Do you have any discount on the meth kit with the smaller reservoir?
R33E8 is offline   Reply With Quote
Old 08-05-2010, 09:54 AM   #3
Chops@MVP
Chops@MVP's Avatar
It is the same price shipped anywhere in the 48 states!! We have plenty in stock and can ship immediately!!
Regards,
Robert
940-683-8282 x20
Robert Del Angel
