12-01-2012, 10:59 AM | #12122 |
So I'm installing a new shift boot and knob in my car.
The OEM shifter bezel I guess came apart over the years into 2 pieces: There's a bunch of glue in the second pic, previous owner wrapped it in carbon-look fabric, but you can see the two different pieces. I'm trying to figure out how they went together |
12-01-2012, 01:46 PM | #12124 | ||
Trader Rating: (58)
Feedback Score: 58 reviews
12-01-2012, 03:30 PM | #12126 | |
Trader Rating: (32)
Feedback Score: 32 reviews
Looks like an automatic shifter trim with a boot and trim piece glued to it. |
12-01-2012, 06:40 PM | #12127 | ||
12-01-2012, 07:46 PM | #12128 |
Trader Rating: (53)
Feedback Score: 53 reviews
the factory 5-speed shifter trim comes with two pieces of plastic and one leather boot. there are these little shitty plastic posts molded into the main piece of the trim that go through holes in that second piece. They are then held on by these little clips. The plastic posts break off extremely easily and then you end up with the two separate pieces of plastic like you have pictured.
where did you get those little screw inserts? i need to fix my trim piece too. |
12-01-2012, 08:32 PM | #12129 |
Ah, yeah I did a little more looking and found those little plastic clips you're talking about, mine were long gone haha. Shitty design, and the plastic gets brittle.
And I just got them from ace hardware, nice place like 2 mins from my house. Any larger hardware store *should* have them. |
12-02-2012, 08:29 AM | #12132 | |
Doesn't the water barrel fit if you move the battery to the trunk or get rid of the air box? I know Summit makes a shit ton of different sized stainless or plastic 'catch cans' and every zenki or kuoki has space for one or two of them under the hood once the intake is swapped out and the battery is moved to the trunk DAVID, RE STARTER ISSUE The bendix drive relay in the starter should not only move the gear to mesh with the flywheel, it should turn it to start the vehicle. If this is not happening there are two possibilities: 1: The flywheel is bad and is missing teeth 2: The bendix is worn and will not hold power to move the weight of the central reciprocating mass of the motor If the bendix gear is moving to mesh, but not turning, the starter is no good. Monkeys at AutoZone can put a starter on a test board and make it turn, but unless their machine has a load set up, they cannot truly duplicate the movement a starter makes once it is meshed with the flywheel. It sounds like your starter does not have it's ability to push the weight or you have an afu flywheel that has worn teeth
12-02-2012, 08:36 AM | #12133 |
Would I be okay with just buying a new solenoid and putting it on one of the starters? Or should I just buy a whole new starter? I don't think it has anything to do with worn/missing teeth. It's gotta be electrical.
12-02-2012, 08:45 AM | #12134 |
For the amount of time and effort your going to be putting into swapping the starter, it may be more beneficial to just swap in a new assembly. It's a wear item and they do to bad over time. There are some shops still around that can and will refurb them. I can't remember if this is for your daily or not, but I would purchase a new one to save the headache of having to uninstall/reinstall/spend more money if the solenoid is not the problem.
12-02-2012, 08:59 AM | #12136 |
I swapped in one from another car I had laying around which was bad, then I bought the 3rd one from a friend for pretty cheap, so it doesn't bother me too much. I'll probably buy a whole new one just for the peace of mind.
And for the record I'm down to 1 s14, no more S13s lol
12-02-2012, 09:29 AM | #12137 |
Trader Rating: (58)
Wrench or socket with extension? 1/4 drive IIRC fits in there easily.
12-02-2012, 12:39 PM | #12138 |
It would be nice if someone with ganadors can help me or can answer this question:
Anyone know the spring length of ganador mirrors so it will settle back into position?
12-02-2012, 10:24 PM | #12139 | |
The length of the barrel won't fit where you mentioned. Basically it is going to be placed right in front of the motor. I use a chase bays rad so mounting stuff on that section isn't important. |
12-03-2012, 09:55 AM | #12142 |
I have a r32 gts-t driver seat... the left rail front mount (I guess was cut an rewelded)
won't mount .... is the rail interchangeable with schassis rails?? or do I need another r32 rail? |
12-03-2012, 02:26 PM | #12144 |
zeals were amazing on my evo. didn't go that low though. they aren't really known to slam cars. but they're superb coils.
Team Taylor Swift - Retired |
12-03-2012, 02:34 PM | #12146 |
12-03-2012, 02:42 PM | #12147 | |
Trader Rating: (53)
12-03-2012, 09:15 PM | #12148 | |||
Just in case anyone encounters my starting problems through searching, I finally found out what it was. I have a bad battery cable, apparently.
12-04-2012, 06:09 AM | #12149 |
echo G Corp, adding copy of 270R front, and 270R sides. Overfenders can't remember the name but they seem to be getting heavy use on JDM stuff right now...Vertex?
12-04-2012, 09:14 AM | #12150 |
I am 6' 2" and 150lbs and my last seat was a Bride Vios III. Which was a little short for me and uncomfortable but got me the head room I wanted. So my question is, sticking with Bride what would be a better option for a bucket seat? Would the zeta III L still give me decent head room? Anyone else in my position have any experience with this?
