Old 04-30-2013, 07:20 AM   #1
rumblz
rumblz is an unknown quantity at this point
[SOLD] 1988 RX7 FC Turbo II
I am selling my 1988 RX7 Turbo II. This is a 10th Anniversary Edition FC (I know its black, its been painted over, engine bay is still white in the picture, windshield is yellow). Car only really needs a new paint job. Here's a list of details about the car:
-Tags are still current
-Clean title, pink slip in hand
-178,XXX miles on chassis
-JDM Engine+Transmission (5,000 miles since the swap)
-5 speed manual
-Currently running and ready to drive
-Starts up every time no problem whether cold or hot
-Idles fine
-Does not smoke at any point of operation
-Does not overheat
-Does not flood
-Heater and air blower works perfect
-A/C compressor was replaced with the JDM one that I got with my engine swap because the original one on the car had a blown clutch. It is installed, but I never had the time or money to get it leak tested and recharged with R12. I'm only assuming it may work, but its not a guarantee.
-NO RADIO INCLUDED
The following parts were installed at the time of the engine swap:
-NGK Spark Plugs
-NGK Spark Wires
-All Belts
-Fuel Filter
-Rear Main Seal
-Resurfaced stock flywheel
-o2 sensor
-Rtek 1.7
-Apexi SAFC-II
-720cc Denso High Imp Injectors (as secondaries, stock 550cc primaries)
-Walbro 255 Fuel Pump
-Innovate MTX-L Wideband
-Autometer Boost Gauge
-Dual Gauge A-Pillar
-Ksport Kontrol Coilovers
-Exedy Stage 2 Clutch
-3" Down/test pipe, ebay midpipe and muffler
-Polyurethane Engine+Tranny Mounts
-Shifter Bushings (Mazdatrix)
-stainless steel braided clutch line (Mazdatrix)
-Front Diff Mount Competition (Mazdatrix)
-Clutch Slave Cylinder (Mazdatrix)
-Clutch Master Cylinder (Mazdatrix)
-Ceramic Brake Pads and Slotted Rotors (both front and rears)
-Stainless Steel Brake Lines (Mazdatrix)
-Alternator Dual Belt Pulley (Mazdatrix)
-130 amp S5 alternator (with proper fixed fused wiring done)
-Optima Yellow Top Battery
-Godspeed Aluminum Radiator
-17x8 Stock Evo 9 Rims /w Dunlop Direzza 101 235/45 Tires (1,000 miles)
-Work RS-R Type Open Ended Blue Lug Nuts
-S5 Turbo+manifold
-S5 Tail lights
I WILL INCLUDE THE FOLLOWING PARTS WITH THE PURCHASE OF THE CAR! It has everything you need to put the car back to stock if you want minus the exhaust piping.
-N333 ECU
-JDM N340 ECU
-Fuel Cut Defender (FCD) 11570 (I'm assuming this is the one from Mazdatrix as it has the same model number)
-(2) 720cc Injectors
-(2) 550cc Stock Injectors
-(4) 550cc RC Engineering
-S4 Turbo N326 Crank Angle Sensor (CAS)
-(2) S4 Turbo Shield Sets
-S5 Turbo Shield Set
-S4 Turbo Oil Cooler
-Sequential Flap Actuator
-(2) Turbo Manifolds (both have a crack on it somewhere)
-S5 Turbo Oil Lines
-S4 Turbo Throttle Position Sensor (TPS)
-S4 Turbo Bypass Air Control Valve (BACV)
-Stock S4 Turbo Downpipe
-Stock S4 Turbo Oil Filler Neck
-Stock Primary Fuel Rail
-Stock Secondary Fuel Rail
-Stock Fuel Pump
-Stock S4 Turbo TMIC
-S4 Turbo Inlet Tube (this is where the stock bov connects to)
-S4 Turbo Rats Nest
-Oil Feed line from the engine to turbo (has a vacuum line connected to it)
-Lower Intake Manifold (LIM) with EGR
-Stock Crank Pulleys
-Water Pump Housing
-Water Pump Pulley
-Coolant Filler Neck
-(2) Stock S4 Alternators
-Emissions Solenoid Rack
-OMP with connecting rod
-Air Control Valve
-AWS Solenoid/Valve
-Hot Start Assist Solenoid (goes on the backside of the UIM near the firewall, one wire is broke)
-(2) Air Pumps
-Airpump Brackets
-Bracket (mounts on top of the engine. the tb and sensor plugs mount onto it)
-Accessory Bracket (where the ps pump and ac connect to)
-Split Air Pipe
-Strut Mount Rubber Covers
-Cargo Lid
-Undercarriage Shields
-Stock Intake Snorkel
-Radiator Fan Shroud
-Ash Tray
-Windshield Fluid Hose Lines
-Black Mazda Emblem
-Shifter Bushing Set (new, never used)
-Cabin Fuse Cover
-S4 Taillights
-JDM S4 Turbo N318A Bypass Air Control Valve (BACV)
-JDM Air Control Valve (ACV)
-JDM N327 Leading Coil with Ignitor
-JDM S4 Turbo N318 Pressure Sensor
-JDM Transmission Sensors (they dont plug up to the USDM harness)
-JDM Engine Harness
-JDM Fuse Harness
-JDM Upper Manifold
-JDM Throttle Body with compression tube
-JDM Stock S4 Turbo Pressure Plate and Clutch Disc
-JDM Clutch Fan (wasnt spinning when I tried it, could be fixed?)
-JDM Sequential Flap Actuator (bolts on the opposite side with a different mount and has a different line on it)
-Stock Pontiac Fiero E-fan
-Lightweight chromoly flywheel with counterweight
-"3 Magnaflow Cat
-Ebay Intake Cone with AFM Adapter
-Thermowax
-TB linkage left over from tb mod
-Light and Turn Signal Switches (they were left from the previous owner, dont know if they still work)
Price is $4,000 FIRM in cash for everything! Not looking for trades, sorry. I am not parting it out at the moment either, but willing to sell the car without the extra parts. PM me if you're interested!
rumblz is offline   Reply With Quote
Old 06-06-2013, 12:58 AM   #2
rumblz
Car sold a few weeks ago. Thanks for looking!
Old 06-07-2013, 02:10 AM   #3
s1392
s1392's Avatar
s1392 is an unknown quantity at this point
do you still have the 550cc injectors? or was it sold with the car?
car-dash'n-em
s1392 is offline   Reply With Quote
fc3s, rx7, turbo
