07-01-2020, 09:55 AM | #4171 | |
Trader Rating: (130)
Feedback Score: 130 reviews
LMGT4 did come in 17x9 +22, and those def look like at least 245/40 tires. |
07-01-2020, 09:59 AM | #4172 |
Yeah the fronts I?ve got figured out, more concerned with the rear. Was thinking maybe it was that specific tire that made it look so meaty. If I can?t track down the owner I?ll just have to do it by trial and error.
07-01-2020, 11:43 AM | #4173 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
im 17x9.5 +38 245/40R17 in the rear (i THINK, not 100% on sidewall). i run -1.5 deg of camber to fit properly (which is -0.5 deg camber over factory). NOT hyping my own products, only recent pics i have that can be posted due to hosting them on my dorkidori web server... im rolled with no pull |
07-01-2020, 12:05 PM | #4174 |
Thanks for the pics and info!
Currently the fenders/quarters are virgin metal. The plan is to have someone roll/pull before paint to allow maximum clearance Another one of the same car with regas...drool https://i.imgur.com/Uot9pGX.jpg |
07-01-2020, 01:34 PM | #4175 |
Seeing as I was asking for pics with specs or personal experience, I can't answer my own question.
It is difficult to find stock body + extended LCA fitment pics with specs. Usually people just say 'extended LCAs' and neglect to mention how much they were extended, or what base arm was used (S13 or S14.) Guess I'll just figure it out myself. |
07-01-2020, 05:11 PM | #4176 | |
07-20-2020, 02:57 PM | #4178 |
Thinking of getting some new wheels on my car and wondering how the following would fit.
Car has no rolled or pulled fenders. It is on lowering springs but I do not know which brand because I bought it like this. Other suspension components are stock. Currently on base 350Z wheels F:17x7.5 +30 215/45/17 R:17x8 +33 225/45/17 Looking at some different Rays wheels and want to know if they would fit fine in a square setup at 245/40/17 17x9 +22 or 17X9 +17 Otherwise I might just stick with R32 GTR wheels. |
07-28-2020, 02:26 PM | #4180 |
Trying to achieve the same exact fitment. Anyone know what shock clearance would be like with d2 air shocks and gktech front angle and rear knuckle double wilwood/lca setups? Willtheyfit shows the inner face sitting 4mm in from oem position (15x6+40). Work Meister S1 3P 18x12.5-39 o disk. For reference the spirit rei demo 180 runs an 18x11-20 with a 50mm spacer. Should i step down to 18x12-33 or more and use a spacer? Fronts are 18x10-20 r disk, willtheyfit says they sit 9mm further out from suspension
https://zilvia.net/f/showthread.php?t=658046 |
07-28-2020, 02:51 PM | #4181 |
U linked the part out thread, so u know exacy what the car was running as wheels, body panels and suspension.... as for clearence ask the manufacture if they know the diffrence between there airride and oem struts and ull have u answer.....
As for fitment/stance wheel spacers are dumb...fit the biggest wheel u can |
07-28-2020, 02:58 PM | #4182 |
I know what the parts are because i searched like mad and reposted so i could get help [read page one post one for the rules bc u clearly havent]), but i dont know what the clearance will look like with the maximum fitment i want, and Im not trying to waste $3300 on wheels that bind my suspension or brakes. I might need to run spacers to get the fitment and clearance which affects width and offset. The guy that made that thread was on coilovers and hes out of the game, hence why i asked the fitment gurus. So help or back off.
07-28-2020, 03:20 PM | #4183 | |
Build the car and take measurements to see what will fit..why the fuk is it that hard? Everyone else does that Fyi...spacers dont effect the width of the wheel... |
07-28-2020, 03:40 PM | #4188 |
Yep. Hit the nail on the head so hard with that one it actually kinda scared me. Actually gonna use the ignore list on someone for the first time. I wont see your posts so dont bother responding.
07-28-2020, 05:38 PM | #4190 |
07-28-2020, 10:55 PM | #4192 |
Hi everyone, new 1995 s14 owner here. Quick tire question currently i'm running a stock setup
205-55-16 6.5Jx16 ET45 5x114.3 I'm looking at getting a Sport Edition SE16 set of tires for a really good price (350 rims and tires) the size is as follows 215-50-17 7Jx17 ET50 5x114.3 I'm wondering what the fit will be like, I dont want any "Poke" I want them sitting flush and looking at stock as possible. Do you think there will be any fit issues/rubbing/problems? I know a bit about tires but would appreciate fit advice from experts here who know more than me. Thank you |
07-28-2020, 11:20 PM | #4193 | ||
07-29-2020, 01:02 AM | #4194 |
Ill try to be more clear. The spirit rei demo car uses 18x11-20 and then a 50mm spacer to get flush. I dont want to run the spacer and instead order a wider wheel 18x12.5-39. My major concern is having the inner barrel lip/tire contact at the air shock with camber and aired out.
Is there a better size front youd recommend for me to get the most steering angle out of my gktech lca/knuckle set up? |
07-29-2020, 09:38 AM | #4195 | |
you cannot be flush AND stock as possible at the same time. They're two totally different things. the only issue you may run into is the wheel contacting the shock/spring, due to that +50 offset. is it possible to test fit before purchasing the new wheels? there is a massive wheel and tire fitment thread here on this site, full of very useful information on the topic. |
07-29-2020, 02:03 PM | #4196 | |
i'd suggest a 9.5 up front with a 225/35, but it's really the offset that is going to cause issues and because of how wide the fenders are, i don't think you can really do much about it other than break out the sledge hammer or get to cutting and welding.
08-04-2020, 05:27 AM | #4198 | |
08-04-2020, 01:29 PM | #4199 | |
08-12-2020, 05:23 PM | #4200 | |
Will I be able to fit work vskf A disk(med disk) for my front. Running z32 brakes on my s14. Thanks!
Sent from my SM-G973U using Tapatalk
