08-25-2014, 05:59 PM | #1 |
MEGA GO FAST SALE! Turbos▐ Coolers▐ Wastegate▐ Eagle▐ Arias▐ ARP▐ Walbro▐ +MORE
IF READING THIS I AM STILL ADDING MORE AS I CLEAN.... Hate to do it but selling off all my 240 parts. Just have other things going on in life I need to focus on. Please text (preferred due to work) or call (714) 305 4895 for fastest reply. Feel free to hit me up with any and all questions or ask for more pics. Need to get these parts gone! PARTS:PARTS:PARTS:PARTS -KA24E (sohc) Front mount intercooler set up. BIG bar and plate intercooler. Set up was used with top mount and z32 MAF in blow through configuration. has turbo xs RFL bov shimmed to hold higher boost. Set up can be modified to work with ka24de or even sr20. (i have extra piping i can include) comes with all couplers and t bolts that might not be pictred. $sold just piping -CX Racing top mount turbo exhaust manifold. With bracing across runners and to wastegate. Titanium heat wrapped. 38mm wastegate port. WITH TurboSmart 38mm UltraGate @7psi spring. (comes with box, two extra flanges and authentic no shitty ebay gaskets) Custom fabbed hood exit screater pipe.(check last pic for fitment...can be cut down to be less rediculous) absolute most badass single cam set up possible. $500 full kit (manifold, wastegate, custom screamer pipe) $180Just wastegate and everything that it comes with $50 Screamer pipe. Assume would only work with a very very similar set up $300 just manifold &wrap -5-bolt down pipe with bungs wleded for o2 AND wideband. And down pipe / cat delete to main exhaust pipe *damaged on bottom check pic* $sold -HUGE permacool oil cooler. no leaks. Works. baller racecar shit bro. rated at like 600hp. $85 -Mishimoto radiator for ka (single or dual cam...or sr with cross over hose) no leaks. with Mishimoto cap $185 -Cx Racing? Big n thick radiator. With high power dual fans and wiring. Cool like a champion. $180 -Greddy style swirl pot. Comes with lines and fittings (not pictured) and unpressurized cap (goes on your radiator) needed for install. $sold -Walbro 255lph Fuel pump. Authentic great shape and low miles. Can include s13 wiring if needed Sold - Cx Racing t304e turbo. has some shaft play. still booooosts fine. Good temporary or mock up (turbo on right) $50 -Holset he351ve vgt THIS IS THE FUTURE OF TURBOS Spool like a t25 but pack the punch of bigger then a hx40. Vanes controlled via wastegates set at 10-11 psi then total boost will be set via external wastegate. Comes with flange to weld. Zero shaft play. Will have all fittings and stainless lines (turbo on left) $700 - HKS filter. Authentic. Has crack on neck which is covered by coupler $sold -T3 turbo blanket. Used but in good working order. $sold -OEM timing chain kit for ka24e. BRAND NEW. 90% chance your timing chain guards have blown up and are in your oil pan. Fix it with quality parts and not ebay shit. $100obo -BRAND NEW Forged Lightweight Arias Pistons for KA. 10.6 comp. 89.5mm (. 20 over) Pistons, rings, other little things i dont know what to call. EVERYTHING needed to drop into your motor. $400 - ARP headstuds for KA24. Brand new. Comes with everything. Boom $100 -Eagle forged Rods with ARP2000 haqrdware. For ka24 Brand New comes with everything. $Sold -Percision/MSD/EVERYOTHERCOMPANYTHATUSESTHESE INJECTORS 52lb. or about 525cc. Were apparently cleaned and reflowed by RC engineering but no paper work to prove $95 -Gates Racing Ka24E (i believe will work on de as well) radiator hoses. MUCH BETTER AND STRONGER THEN SILICONE. Yet still come in ricer blue. Best of all worlds. Comes with adapters for temp gauge or swirl pot on both top and bottom hoses. Super low miles before pulled pending $ 60 -Long an16 stainless line. Long enough to cut and use for top and bottom radiator hoses and add fitting for the ultimate baller $sold -Z32 fuel filter like 10miles on it $sold -Oil feed line with 90degree an fitting to oil restrictor. $sold -NGK blue plug wires for KA24E $sold -Oil cooler. perfect for power steering or small easy to hook up oil cooler $25 -OEM Z32 MAF and pigtail. top expoyed to strengthen to be run in blow through configuration $65 -Turbo XS RFL Blow off Valve. Shimmed to hold higher boost. comes with flange adapter so you can bolt to greddy or hks style flange....Really fucking loud. Let your inner rice out $90 -Big front mount intercooler. Bar and plate style. 3inch inlet. Super lower miles and works great. $140
Braaap Last edited by zeebrah; 09-16-2014 at 04:26 PM.. |
08-25-2014, 06:10 PM | #2 | |
GM2 (SW/AW)
Guessing the intercooler piping is 2.5"?
KA-T for life! Current for sale advertisement |
drift, sohc, turbo, walbro, wastegate |
