Old 02-03-2020, 10:24 PM   #1
Donedreamin
Donedreamin will become famous soon enoughDonedreamin will become famous soon enoughDonedreamin will become famous soon enoughDonedreamin will become famous soon enoughDonedreamin will become famous soon enough
Help! 180sx speedometer failed, next step?
Hello,
I own a 93' 180sx, SR20DET.
Prepping the car for a safety and I can't seem to get the speedometer to work. I tested the ecu for faults, no errors. I pulled the speedometer sending unit out of the transmission and benched tested it serviceable. I swapped in a 240sx cluster, not only did the speedometer not work, but now the tach also didn't. I swapped over the speedometer unit from the 240sx cluster to my 180sx cluster. Once again the speedometer and tach don't work. I don't have a wiring diagram, I'm thinking of checking continuity between the pins outs coming from the cluster plugs and the sending unit. Would be lovely to have a spare 180sx cluster to slave in but it's an expensive piece and I'm not even sure it would fix it.
Anyone have any recommendation? I'm not against just slaving in a temporary speedometer to pass this safety..
- Seb
Donedreamin is offline   Reply With Quote
Old 02-04-2020, 01:49 AM   #2
My!
My! will become famous soon enoughMy! will become famous soon enoughMy! will become famous soon enoughMy! will become famous soon enoughMy! will become famous soon enough
if you find out you need another cluster, i have one in good condition. only the top mounting tab is missing
My! is offline   Reply With Quote
