Old 04-09-2014, 06:20 PM   #1
Carnifex
Carnifex is an unknown quantity at this point
Not getting spark/fuel ... ???
Bought this s13 coupe. sohc ka. had a rough idle / ran shitty at low rpms
recently the car shit out on me and wouldnt start, cranks but doesnt turn over. at first i thought it was a fuel issue, then i checked the spark.
friend let me borrow/test a coil and control module, no difference.
took off a fuel line and didn't get any fuel either.
tried an ecu diagnostic and lights wouldn't flash..
figured this is either the EGI or a faulty ecu.
dont have much experience with this stuff so give me your input.
thanks
Carnifex is offline   Reply With Quote
Old 04-09-2014, 06:23 PM   #2
Vegass13
Vegass13 is an unknown quantity at this point
check your fuses? and if you get it running check the timing...it might help the shitty drive at low rpms
Vegass13 is offline   Reply With Quote
Old 04-09-2014, 06:30 PM   #3
Carnifex
it wont even start at this point lol
checked fuses didnt see any problems
Old 04-09-2014, 06:41 PM   #4
Vegass13
You said no fuel came out of the sending line when you took it off? I don't think it would squirt out but if you tried priming with it off and none came out then I'd start with the fuel pump
Old 04-09-2014, 06:42 PM   #5
Carnifex
not getting spark either. don't think that'd be the best place to start
Old 04-09-2014, 06:44 PM   #6
Vegass13
Why don't you switch your ecu with your friends and see if it's that?
Old 04-09-2014, 06:50 PM   #7
cotbu
cotbu's Avatar
Let you friend borrow your ecu, test it in his car. if it works check over your wiring if it doesn't work, borrow his ecu test it in you car.
Old 04-09-2014, 06:57 PM   #8
Carnifex
his is a dohc =\ lol i gotta meet peeps out here
Old 04-09-2014, 07:02 PM   #9
Vegass13
If you wanna buy mine it's off my 89 sohc and I know it works $40 shipped
Old 04-09-2014, 07:08 PM   #10
Carnifex
i'll be able to find one here, lol this is my daily so i don't really have time to wait a week for shipping to hopefully fix it.
but i'm not sure if it would be the ecu. I'm thinking it MIGHT be a relay, but i already switched the EGI and EGI pump relays and it didnt make a difference. Going to buy a new one to be sure.
Symptoms of a bad fuel pump, but i'm not getting spark so i'm seriously doubting its the fuel pump, unless all this shit is just getting dumped on me at once lol.
Old 04-09-2014, 07:17 PM   #11
Vegass13
I get it and ya I doubt they both go out at the same time haha I would assume it's gotta be whatever powers them both...try using a multimeter on the pinouts for the pump and ignition coil to see if the power is getting sent to the ecu...I'm assuming all the dash lights come on and what not when you put the key in the start position and it's cranking correct?
Old 04-09-2014, 07:19 PM   #12
Carnifex
like the 4 lights that work in this car lol yeah
Old 04-09-2014, 07:24 PM   #13
Vegass13
Well see if power is going to the ecu and if it is my best guess would be to try a new ecu
Old 04-09-2014, 07:33 PM   #14
Carnifex
word. gonna check that relay first
Old 04-12-2014, 07:03 PM   #15
4pegs
4pegs is an unknown quantity at this point
hey man I was wondering if you ever figured out that problem you had? because I'm having the same problem but with a ka24de
4pegs is offline   Reply With Quote
Old 04-12-2014, 07:21 PM   #16
Carnifex
My 75a engine control fuse was blown. Check that, alt fuse, egi pump relay.
The 10a fuses as well.
Make sure your ecu is getting power turn the key to on and it'll blink in diagnostics mode.
Is your fuel pump priming?
Old 04-12-2014, 07:26 PM   #17
4pegs
Yeah I've recently have had the fuse blow and already changed that.. and also checked all the fuses in the car.. it turns over but it doesn't start.. but no haven't checked the ECU.. and how would you check for fuel priming? Also how do you put the ECU in diagnostics mode?
Old 04-12-2014, 07:30 PM   #18
Carnifex
Listen to your fuel pump may when you turn the key to on. Should make a noise for like 5 sec. Check your ecu there's a screw on it turn it to diagnostics mode with the key on. There's a guide for it. If the lights dont blink the ecu isn't getting power. But if the fuel pump primes it probably is
Old 04-12-2014, 07:31 PM   #19
4pegs
Sick man ill check that out now... ill let you know..
