Old 06-30-2015, 10:05 AM   #1
alex300
alex300 is an unknown quantity at this point
s14/A no blinkers or hazards
Hello guys, i have an s14 which has been converted to kouki and i have a problem with that the blinkers and hazards dont work
Does anyone have any idea? ive changed the fuses just in case but no difference
alex300 is offline   Reply With Quote
Old 06-30-2015, 10:30 AM   #2
the head
the head's Avatar
the head is making a name for him/her selfthe head is making a name for him/her self
Low fluid.
check all relays and flasher modules, also make sure bulbs are in all of the lights, lack of resistance will cause them to not work.
I never knew you could do that with an eggplant
the head is offline   Reply With Quote
Old 06-30-2015, 10:36 AM   #3
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
Faulty hazard switch at least in s13 if you disconnect the hazard button the blinkers don't work
S-Nation S13 is offline   Reply With Quote
Old 06-30-2015, 11:16 AM   #4
yzrider450f
yzrider450f's Avatar
yzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of light
True for s14's as well. Make sure it is plugged in.
yzrider450f is offline   Reply With Quote
Old 06-30-2015, 01:56 PM   #5
kooky
kooky's Avatar
kooky is an unknown quantity at this point
This happened to me, check the turn signal fuse in the interior fuse box and replace it even if it looks like its fine. The only other thing is the actual hazard switch, all the wires for the turn signals run through that switch.
kooky is offline   Reply With Quote
Old 06-30-2015, 01:59 PM   #6
alex300
how do i check if its plugged in? do i have to pull out the center console?
blinkers, hazards, problems
