12-18-2012, 12:57 PM | #1 |
FRSport Deal of the Day: HKS Step 1 Camshaft Set
FRSport Deal of the Day: HKS Step 1 Camshaft Set 256/256<--click here HKS Step 1 256/256 Intake/Exhaust Camshaft Kit works with OEM valve spring rates and requires no modification to the head for a true bolt on upgrade. HKS Step 1 Camshafts comes in 11.50 mm of lift. HKS SS-Cam are designed to fit unmodified cylinder heads with stock valve springs to be a simple bolt on cam kit that can give added performance without changing any other parts or the valve timing. By changing cams, cam duration and lift is altered making the ideal valve timing different also. HKS SS-Cams have been tested on the engine bench to find the optimum valve timing and the knock pin has been relocated in a modified position to offer perfect valve timing by simply replacing stock cams with no need for measurement or adjustment. Specs:
Deal of the Day: HKS Step 1 Camshaft Set 256/256<--click here Available for $429.95 *price good while supplies last add to cart to receive discounted price* As always orders over $99 may qualify for discounted or FREE SHIPPING w/ the FRSaver Shipping option. Thanks, FRSport Team AIM: FRSportsales Email: [email protected]
FRSport.com || 18050 Newhope Street, Fountain Valley, CA 92708 (Map link) Store Hours: Mon - Fri: 8:00 AM - 6:00 PM PST [email protected] | 800-321-4747 | 714-515-4001 ext 146 FRSport.com Open Box Clearance Items FRSport.com Weekly Specials |
