08-07-2010, 06:00 AM | #32 |
Fuel management, and cooling are your best friends. You should def spend time on head work. You can make over 400 whp on stock cams...It's been done a billion times. And depending on the shape of the motor you could prolly get away with it ona stock bottom end but I wouldnt push my luck if I were you . Just do some looking around, find someone with a similar set up that your lookin for then ask em questions!. In most case's people are pretty humble about that and will help you out with trouble shooting and all that crap.
08-07-2010, 07:15 AM | #33 |
well, there are 2871s with different inlets and outlets... turbine...etc.. setups. If you'll notice the inlets/outlets, of the compressor, on the stock t25/t28 bolt onto the turbo. The stock t25 and t28s also have a 5 bolt flange exhaust side and a t2 flange to the exhaust manifold. If you want the 2871r to bolt right up with no modifications then you'll need to get a 2871 with that same turbo setup: 5bolt/t2 flanges and one where the inlet/outlets bolt on. Otherwise you'll have to custom the elbow or downpipe and your intake/intercooler piping. Look around for 2871 turbos, you'll know what I mean. They have the bolt on(for sr20), theres a vband flange style turbine, one where the compressor inlet would need a coupling, and more...If I was on a budget, I'd just get the one that bolts right up.
08-07-2010, 09:12 AM | #34 |
I have another good question. When i bought the car the guy said its a SR20det blacktop. Besides the color between the red or black on the SR20det. Is there a way to tell which one you have. The valve cover on mine has been painted. So im just wondering how you can tell the diff between the 2. Any info on this will also be helpful. Thanks
08-07-2010, 01:01 PM | #35 | ||
08-07-2010, 04:26 PM | #36 | ||
There's no timing change with regard to RPM. You end up running 27deg timing at 750RPM/0 psi, which is wayyyyy too much. You'll get knock pretty easily if you spend much time in those cells. Lets move on to his fuel map: When I got the map, it misfired terrible under boost. Coming into the image, I get on the throttle, plateauing at about 65% throttle. RPMs rise to 4800, and boost is about 7psi at this point. Unfortunately, the engine is running so rich (9.6:1) that it begins misfiring. Misfires show up as lean, which is why the AFR begins to increase as the Injector Duty Cycle holds steady. The engine holds this continuous misfire condition until I get off the gas a second later. Steve said it was because my injectors suck. I had to trim out more than 30% of the fuel to get it right. Been great ever since, perfect AFRs. On top of all that, Steve was more than a week late on his promise to have the map done. My gut feeling is that most of Zilvia doesn't know better - no one datalogs, most people don't own widebands, etc. Remote tuning is a tricky, iterative process... Steve is probably a decent tuner on a physical dyno, but I am not impressed with his remote services. Others on here have had bad experiences, too. He's far from the God of SR20s. |
08-07-2010, 04:39 PM | #37 |
oh, and this is what I ended up building my timing map with:
http://forums.freshalloy.com/showthr...ghlight=timing |
08-07-2010, 09:57 PM | #38 | |
08-07-2010, 10:55 PM | #39 | |
LOL. I'm telling you guys, this joker's not all he's cracked up to be. I withheld my build specs so that someone can't come along with the same specs and copy the map, but I can guarantee less than 1% of all SR owners have my setup. (Displacement, cams, manifold, TB, etc) |
08-07-2010, 11:07 PM | #40 | |
E92 M3 19" wheels for sale///JWT Cams and Springs +30whp for sale... cheap. |
08-07-2010, 11:57 PM | #42 |
Im not a mod but posting your dealing with Steve is not going to be helpful in this thread. Staying on topic and using, his review thread is a better for everyone. The people doing their research on his buisness aren't going to look here.
http://zilvia.net/f/businesses/16350...veshadows.html
08-08-2010, 08:04 PM | #43 | |
08-09-2010, 12:49 PM | #44 |
Have any of you guys tried to email me for the support?
I start witha base map and then you are supposed to send me logs so I can help you adjust the map? + You have to have basic knowledge of your EMS to use my service. If you don't know how to do the "LOCK TIMING" fucnction or change the axis of your EMS config it is going to be very hard for me to explain or teach you how to use your EMS I am not here to TEACH you how to tune EFI or use an EMS I am here to offer you a good starting place for your timing map and direction for you fuel map, for an extremely cheap rate, compared to the time I put into it. MY basic diagnostic support IN PERSON is 100 dollars per hour. Mapping and back and forth over the web take a lot more of my time than that. If you actually follow my step by step instructions to the T you will have great results. EFI and EMS tuning is not something you can pay 60-80 bucks for and magically have everything working right. There are thousands of things that can go wrong with the EMS, the build, even the sensor placement that I have no contorl over. You have to get this sh*t together first on your end before any of my advice, mapping or web support will help.
Like Me on FaceBook ! |
08-09-2010, 01:05 PM | #45 |
PS
You will not KNOCK at 26 degrees with 0 rpms, in fact you wont knock with 40 degrees at 0 rpms, just look at any base map from a JDM Power FC You have to have LOAD to cause any sort of Knock, base TIMING should be 20 degrees. at fire up, you can run higher though. If there is something that looks off to you, and you are a client of mind just contact me via web and I will get back to you within 12-24 hours. Try seeing how long it takes for Jim Wolf or Enthalpy, or Haltech or AEM to get back to a detailed request
08-09-2010, 01:49 PM | #46 | |
knocking on someone because they took 24 hrs to reply is rediculous imo.
08-09-2010, 05:12 PM | #47 |
08-09-2010, 05:32 PM | #48 | |
Anyways, I live in Wilmington NC and used to work at National Speed. Go there anyways and ask about anything you want to know. I've seen quite a few SR's pull those numbers. I've got a 2871r myself and with Cams/IM/Exhaust manifold and a basemap from steve shadows, I pulled 299whp with a boost leak. With more tuning and no leak it should be at like 330whp or so. I'd say go with a 3076 or something if you are looking for more. edit: Also, as I said, I have a basemap put together by steve shadows remotely, and my AFR's are nearly perfect and with really low knock. |
08-09-2010, 05:49 PM | #49 | |
Trader Rating: (22)
Feedback Score: 22 reviews
Driftphreak87 |
