Old 04-14-2014, 10:46 PM   #1
delado
delado's Avatar
delado is an unknown quantity at this point
SR20DET running lean at WOT? what's up?
Hello lads,
So I finished swapping a red top sr20det into my kouki about 2 weeks ago.
Car runs great and have absolutely no problems. I installed a brand new AEM UEGO wide band a couple days ago and started to worry a bit because my AFR's seem off.
Idle numbers are good ~13.4
Cruising numbers are good ~14.5-15
WOT ~12.5.-12.8 <---- WTF?
I'm running stock boost ~7-8 psi sometimes spiking at 9 when cold out.
What could be causing this?
Mods (all parts are brand new):
stock 62 ecu with the correct skinny O2 sensor.
Walbro 255
FMIC (no BOV)
WS engine harness
PBM cobra DP
HKS hi power exhaust
test pipe.
Things I have checked:
No exhaust leaks
swapped out my SOHC maf with a friends SOHC maf (no change)
Any ideas as to why this may be happening?
Is 12.5 a danger zone? Like for serious danger zone? I'm confused because I'm pretty sure stock SR's with a walbro and stock FPR run pig rich,.
I usually do pulls in second and third gear and by the time I get to top end the lowest number I'll see is about 12.5
Motor was pulled from a automatic front clip with like 36,000 km
Originally Posted by G240 View Post
I'm glad the Zenki Unite thread isnt lame like this one. Sheesh bunch of girls in here.
Originally Posted by silviaks2nr View Post
That's because everyone with a zenki feels sorry for themselves and they find commonality in the fact that there's no hope for making them look remotely good.
delado is offline   Reply With Quote
Old 04-14-2014, 11:17 PM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Did you double check the base timing? Maybe the CAS got bumped....
CLICK HERE!!!
Old 04-14-2014, 11:24 PM   #3
delado
delado's Avatar
Didn't check timing but I will say that the bolts that hold the CAS still have the sticker on them with Japanese writing on them (i'm assuming they slap those on to ensure nobody is messing with the CAS).
But if timing was off wouldn't the car run like balls all over the place? Like mentioned, if I didn't install the wideband, I'd think everything is fine and dandy.
Old 04-14-2014, 11:39 PM   #4
fliprayzin240sx
Double check your base timing, 12.5 AFR is high. If it was 12 on WOT, I wouldnt be too worried about it. What fuel pump are you running?
CLICK HERE!!!
Old 04-14-2014, 11:50 PM   #5
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
Dboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-known
Feedback Score: 18 reviews
Your wiring for your fuel pump can also cause this issue.
I would suggest you check the voltage for the power wire going to the fuel pump.
If I recall correctly the voltage should be a solid 12V.
Any thing like 11.5v and under will cause it to lean out.
Dboyizmlg is offline   Reply With Quote
Old 04-15-2014, 08:47 AM   #6
delado
delado's Avatar
I'm gonna check the voltage today. And the pump is a walbro 255.
Old 04-15-2014, 09:14 AM   #7
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
I wired in a relay just for the fuel pump on my S13.
Here is a link for you.
http://www.ka-t.org/forums/viewtopic.php?f=12&t=59949
You're S14 might be a little different though
Old 04-15-2014, 10:40 AM   #8
delado
delado's Avatar
Well I went and picked up some MAF cleaner and sprayed the maf. Getting 11.2 at WOT.
Old 04-18-2014, 08:08 AM   #9
Boostd2
Boostd2 is an unknown quantity at this point
ahh, the classic dirty MAF trick.
Probable time to replace the air filter?
Boostd2 is offline   Reply With Quote
