Old 06-23-2019, 11:38 PM   #1
XiaoAZN
XiaoAZN is making his/her stupidity well-knownXiaoAZN is making his/her stupidity well-knownXiaoAZN is making his/her stupidity well-knownXiaoAZN is making his/her stupidity well-known
Inner Tie Rods Question
What inner tie rod do you suggest?
Car: S13
Knuckle: PBM Drop Knuckles
FLCA: S14's w/ S13 Ball Joints
Outer Tie Rods: SPL
XiaoAZN is offline   Reply With Quote
Old 06-24-2019, 07:45 AM   #2
jedi03
tein with their spacers!
Old 06-27-2019, 07:34 PM   #3
crash n' burn
crash n' burn's Avatar
crash n' burn has a spectacular aura aboutcrash n' burn has a spectacular aura aboutcrash n' burn has a spectacular aura aboutcrash n' burn has a spectacular aura aboutcrash n' burn has a spectacular aura aboutcrash n' burn has a spectacular aura about
Discontinued ^^, plus s13 are not the correct size for SPL.
SPL lists what inner tierods you need for their ends..and eve suggestions based on what knuckles you have (Z32/Z33/S14)
Key'd Performance
@jz_2tone
crash n' burn is offline   Reply With Quote
Old 07-04-2019, 08:40 AM   #4
gaz_moose
gaz_moose is an unknown quantity at this point
id just run s14 inner and outer.
gaz_moose is offline   Reply With Quote
Old 07-16-2019, 01:27 PM   #5
duballstar37
duballstar37's Avatar
duballstar37 is on the path to ruinduballstar37 is on the path to ruinduballstar37 is on the path to ruin
Car: S13
Knuckle: MA Awesometron 5000 (initially S14)
FLCA: S14's w/ S14 Ball Joints
Outer Tie Rods: SPL v5
Inner Tie Rods: S14 w/ GKtech Offset Rack Spacer
I used to run Z32/Z33 inner tie rods before my knuckle setup. I also used to run Tein inner tie rods, but they are "stronger" than OEM style tie rods. I'd prefer that my tie rod is the giving point (and not my rack) if/when I hit something, which is why I stuck with OE style (also much cheaper).
Good luck and enjoy 2nd gear!
P.A.T.T.
duballstar37 is offline   Reply With Quote
Old 07-16-2019, 01:37 PM   #6
duballstar37
Delete.... msg length
P.A.T.T.
Old 07-17-2019, 08:57 AM   #7
jedi03
mine gave before my rack on one of my setups...they just hold up better, but if they are discontinued that's unfortunate...
